Question about Frigidaire Dishwashers
Frigidaire model mdb212rbs0 dishwasher
Dishwasher stops in the middle of the wash cycle
  • 58 Answers
SOURCE: Frigidaire Dishwasher Console/Lights Flashing
which light flashes?
Posted on Nov 02, 2007
  • 1314 Answers
SOURCE: frigidaire dishwasher ultaquiet , model=FDB750RCC1
the first thing that your dishwasher does when you turn it on is drain when you turn it on you hear a motor running then it stops then it fills start the washer when it stops to start filling open the door should be no water in the unit if there is you have a drain problem and in fact are washing your dishes in dirty water can be several things that can cause drain problems a piece of food blocking the line at the sink where the drain goes in if its run to a disposer there is a knockout plug that should be removed just stick your finger in there to see if it was removed get you installation instructions and read the part about not removing the drain loop but just about all the time installers will lol if you cant find the instructions go to www.frigidaire.com under customer support can down load them there let me know what you find
Posted on Jan 17, 2008
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
  • 555 Answers
SOURCE: Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Posted on Aug 30, 2009
  • 127 Answers
SOURCE: kenmore dishwasher has stopped draining.
remove the kick panel below the door, place a pan, etc under where the drain hose connects to the drain extension tube, and slide the clamp back some so you can slide the hose off of the extension tube (white plastic tube) and drain any excess fluid into the aforementioned pan, etc., then unscrew the extension tube and check for plugs, or restrictions.
the sump may also be pluged beneath the strainer assembly, and that requires removing the lower spray arm, the water tube that runs up the inside back of the unit, and the upper parts of the assembly below them to access the drain/pump sump area.
last but not least the impeller is jamed and might be able to be freed by removing whatever has lodged within there..
ya never know...
best of luck,
ttfn
Posted on Oct 25, 2009
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Frigidaire Model FDB780RCB0 I am getting water in the machine but it seems the arms are not turning what can I do to get that fixed?
The pump in the dishwasher is supposed to provide enough water pressure to turn the spray arms and make them rotate. The pump is faulty and not giving enough pressure or the arms are stuck.
Try spinning the arms, if they rotate smoothly, you will need to replace the pump.
Aug 03, 2008 | Frigidaire Dishwashers
Frigidaire dishwasher model # FPHD2491KF
It seems like you are experiencing a faulty door latch and control board communication. This would need to be diagnosed by a technician and the correct part(s) replaced.
Aug 29, 2012 | Frigidaire FPHD2491KF Dishwasher
Ffbd2407lm frigidaire dishwasher stops washing cycle?
Sounds like you need a professional to diagnose the unit for repairs. You are either having a timer issue or a control board communication error.
Aug 24, 2012 | Frigidaire Dishwashers
Dishwasher model FDB52ORHS2 makes terrible noise when filling up
Possible that the inlet valve is chattering as there is dirt or there is problem in the flow tube , You must remove the hose from the inlet and check the flow and if the noise stops. If not disconnect the valve to confirm
Jun 30, 2012 | Frigidaire FDB520RHS Full Console...
My dishwasher will not drain
could be a blocked drain or faulty drain pump or faulty controller.
Do you have a model no.
Also confirm if the wash cycle did start correctly and it ran through it according to the time. Does the dishwasher stop in the middle of the cycle or it completes the cycle with lights turning off but water still inside.
Did the drain pump actually run?
Sep 06, 2010 | Frigidaire Dishwashers
My frigidaire FDB1100 dishwasher will not stop
I have a frigidaire and when I open the door it will not stop and water goes all over my kitchen, please help?????
Dec 14, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Frigidaire washer machine stop in the middle of the cycle
Replace your lid switch.
The machine must have a goodd lid switch to continue timer functions after wash and rinse.
Feb 28, 2009 | Frigidaire FWS833A Top Load Washer
Our bosch diswasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display. What does this mean?
Hello zeviemail
Welcome
You said, your Bosch dishwasher on auto wash will stop functioning in middle of the cycle start beeping and there is an icon of a faucet on the display.
What is your model number and the year of the dishwasher?
Oct 04, 2008 | Bosch Dishwashers
Dishwashers Logo
22 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
