Question about Toshiba Satellite A135-S4527 Notebook
Toshiba A135-S4527 laptop firewire problem
I have a Toshiba Satellite A135-S4527 and it has an i.Link (4-pin Firewire) port on it. It is identified in Device Manager as Texas Instruments OHCI Compliant IEEE 1394 Host Controller. There is also a 1394 Net Adapter under Network Adapters. I am trying to connect my sony DCR-TRV 250 camcorder usin 4 pin - 4 pin cable, but it is not detected. However, this camcorder works well with my desktop where I connect it using 4 pin-6pin cable as desktop has 6 pin connector. I have already tried different 4-4 pin cables etc. I think the problem is with firewire port as other firewire devices are also not detected. Any ideas how to make this firewire port work?
How to install bluetooth in toshiba satellite A135-S4527
Doenload and install the Bluetooth driver,
You can download the Bluetooth and device drivers for your model laptop from the Toshiba WEB site from theirdownload page. Make sure you enter the model of your laptop so you can get thecorrect drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Mar 29, 2012 | Toshiba Satellite A135-S4527 Notebook
I have a jvc gr-d33 and am trying to transfer mini dv to dvd through my laptop toshiba satellite l355. on my jvc i have the 4 pin dv and know it has to transfer through firewire but on my toshiba i dont...
I'm afraid that there is chatter on the forums that these Firewire to USB convertors don't work properly with video cameras. That doesn't mean you can't try it, of course.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you have a Windows desktop PC, you can fit an add-on Firewire interface card. This will come with a driver for the card. No help on a laptop unfortunately.
Nov 20, 2010 | JVC GR-D33US Mini DV Digital Camcorder
Can I get a memory upgrade?
Here you go:
http://www.18004memory.com/toshiba-satellite-a135-s4427.asp
Aug 16, 2010 | Toshiba Satellite A135-S4527 Notebook
How to remove the cmos or bios password and want to remove the password in booting up, my laptop is toshiba satellite a135-s4527
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Mar 18, 2010 | Toshiba Satellite A135-S4527 Notebook
Where can I find a repair manual for a toshiba satellite a135-s4527?
As in a Service Manual, or Maintenance Manual?
I can give you a link for a disassembly guide, and a link for the specifications.
Specifications:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1700045&rpn=PSAD0U&modelFilter=A135-S4527&selCategory=3&selFamily=1073768663
On the above link click on the - Detailed Specs - tab
This is a disassembly guide that is pictorial, with instructions, for the Toshiba Satellite A135 Series,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-1.htm
Oct 11, 2009 | Toshiba Satellite A135-S4527 Notebook
Does this have a firewire port, if so what does it look like?
Depending on the model, yes it does have a firewire port. The firewire port is also known as a IEEE-1394 connection. There are 2 possible layouts for this port, 6 pin and 4 pin. Below is a link to an image that shows what the 2 different ports look like. The larger 1 is a 6 pin and the small is 4 pin.
http://en.wikipedia.org/wiki/File:FireWire-46_Diagram.svg
Hope this helps.
Apr 20, 2009 | Computers & Internet
Toshiba Satellite- A135-S4477 unable to connect firewire
There are generally three different types for firewire connectors. In the laptops its usually the mini contact(type 2) so is even on the camcorders. on the desktop PCs and MACs however it could be. either type 1 or the type 2. There is a thired type (B) which is less common.
The link shows all the types, male and female:
http://www.l-com.com/content/Article.aspx?Type=N&ID=95
Hope it helped
/BS
Feb 24, 2009 | Toshiba Satellite A135-S4527 Notebook
TOSHIBA LAPTOP SATELLITE A135-S4527 WON'T POWER UP
Not charging . . . And probably the power pin ... where the AC cord connects to thecomputer. That particular component is very fragile. The part torepair it runs between $ 5-$15 but the labor to repair it will costanywhere from $ 100-$250. It can be repaired by you if you are verycareful taking the system apart. Just pay attention to every detail ofyour dis-assembly. I also recommend you get one of these to stop the problem from happening a 2nd time.
Dec 14, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite laptop keyboard driver
i dont have satellite L40 drivers plz provide a link for them
Sep 05, 2008 | Toshiba Satellite A135-S4527 Notebook
Drivers for Toshiba Satellite A135-S4527
Let's try it. http://rapidshare.com/files/57546874/XP_Drivers_laptop_Toshiba_A135-S4527.rar
May 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
519 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
