Question about Acer Aspire 5720 6497 Laptop
Carnt turn on my wireless lan
How do i do it please
  • 315 Answers
As far as I'm aware there should be a button near the screen of your laptop just above the keyboard but below the acer symbol on the screen.
I'm thinking there is a row of buttons just above the keyboard, there should be a button there with what looks like a satallite on it, if its on it coule be either an orange or green light.
Posted on Jan 27, 2009
  • 117 Answers
Usually there is switch or button on side of laptop or you have blue antenna icon on kayboard (usually F2)? If you have that blue antenna icon then you can use it together with Fn (function) button on left bottom side of keyboard.
Happy wireless!
Were is the wireless turn on switch?
It appears that there isn't an external switch to turn the WLAN off on the Everex NC1500 laptop (click here for the full manual). Here is a link showing you how to disable and enable WLAN card in WinXP (click here) if this is what you are trying to accomplish.
According to the manual (if your wireless isn't working) you must first install the WLAN driver before using the wireless connection. Info: "Wireless LAN module is similar to LAN module. You need to install software driver before using it. Please refer to Appendix B on how to install the driver." Appendix B INSTALLING THE WIRELESS LANDEVICE DRIVER Please follow the procedures below for installing the Mini PCI Adapter driver: Installing Wireless LAN driver for Windows XP 1. Click the Start button and then click Run. The Run dialog box appears. 2. Click Browse button and specify the directory as "E:\Drivers\Winxp\Wireless LAN\setup.exe" 3. Click "OK" to implement the setup program to install this driver. 4. Click "Next" twice to continue the installation.
Hope this was helpful.
Feb 01, 2011 | Everex StepNote NC1500 Notebook
Were do i turn on my wireless connection on my laptop?
INSTALLING THE WIRELESS LAN DEVICE DRIVER
INSTALLING THE LAN DEVICE DRIVER
• Wireless LAN Access When LED turns on indicates that the wireless LAN module is activated. When LED lights off, it indicates that the function is disabled
MUST BE A SOFTWARE ACTIVATED SWITCH
Jan 21, 2011 | Everex StepNote NC1500 Notebook
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
VAIO VGN-NS190J/S 15.4-Inch Notebook PC (2.0GHz Intel Core 2 Duo Processor T5800, 4GB RAM, 250G: The wifi light won't turn on when I put the switch...
They issue is due to the corrupted SmartWi Connection Utility Software in the Computer.
You will need to re-install the Wireless LAN Driver, Updates, and the SmartWi Connection Utilities in the Computer to fix the issue with the Wireless.
You can download the Wireless LAN Driver, Updates and the SmartWi Connection Utility from Sony Support Site.
Below are the links.
Wireless LAN Driver
Wireless LAN Driver Update 1
Wireless LAN Driver Update 2
  1. Please download and save each file on the Desktop.
  2. After that double click on the Original Wireless LAN Driver to begin the installation.
  3. Please follow the onscreen instructions to complete the installation.
  4. After that, restart the Computer for the settings to take the effect.
  5. After restarting the Computer, please install the Updates.
  6. Make sure that you restart the Computer after each installation.
  7. Then, please re-install the "SmartWi Connection Utility in the Computer.
You can download the SmartWi Connection Utility from here.
  1. Download and install the SmartWi Connection Utility in the Computer.
  2. after the installation, please turn ON the Wireless Adapter using the SmartWi Connection Utility.
  3. Please click "Start", "All Programs" and SmartWi Connection Utility to open the Program and turn ON the Wireless Adapter.
  4. After that, please re-configure the Wireless Network connection in the Computer.
  5. This should fix the issue with the Wireless Network connection.
May 18, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Where is button to turn on wireless internet connection
see the operating instruction manual here :
http://dl.owneriq.net/d/d94ab07b-788b-41ca-8def-00135155738c.pdf
or read below :
For instructions on settings for wireless LAN and cautions during use, select [start]-
[Reference Manual], and refer to "Wireless LAN".
Before using a wireless LAN, turn the wireless LAN on using the following method (at
the time of purchase, the wireless LAN is set to [Off]).
Double-click on the taskbar.
2 Select your wireless LAN adaptor and select [General].
3 Select [On] for [Switch radio].
4 Select [OK].
The icon will turn to or ��
Oct 04, 2009 | Panasonic Toughbook T2 Notebook
My Toshiba Satellite PSL30A-00100E wont pick up wireless LAN
there is a switch on the front of the laptop on (just under the mouse) on its "face", it just says on off
Nov 28, 2008 | Toshiba Satellite L25-S119 Notebook
Wireless network undetected and problem with wireless lan
first check for whether the wireless switch on laptop is turned on or not u have to keep it turned on .further install the drivers for wireless lan
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
How do I setup my i-mate PDA2k wireless LAN?
The wireless LAN feature on your phone works by default.If you are in a wireless enabled environment,just go to your phone seetings and select connections,then select the wireless LAN manager which you must turn on; check the box and click o.k.The phone automatically detects all available networks in that place.You can now connect via a password or free as the case may be. This should be o.k.At the base left of the wireless LAN screen is the tools TAB click on this to show you the network card configuration menu.Here you can view all the available networks and decide on some other vsettings as you please.Remember that if your wireless internet requires a password you may not be able to browse till you enter the correct password.
Nov 13, 2008 | i-mate PDA2k Pocket PC
Carnt get the wireless connection to work on new laptop
Click Start, then select Control Panel.
Click Network and Internet Connections. The Network and Internet Connections window opens.
Click Network Connections. The Network Connections window opens.
Right-click Wireless Network Connection.
Select Enable to turn on wireless Ethernet or Disable to turn off wireless Ethernet.
May 29, 2008 | Computers & Internet
Connection problem
you need to type 192.168.0.1 into address bar on internet explorer if this does not bring up a password prompt then you need to set your ip addresses on both computers this is done by clicking start - my network places - on left view network connections - right click on wireless for wireless and on normal lan for lan - click properties scroll down to tcp ip sttings - right click - click properties - click use the following ip address - type 192.168.0.2  - click sub mask it will auto fill then default gateway needs to be 192.168.0.1  - then click use the following dns server and type 192.168.0.1 click ok and your done for every computer you add to the network you have to change the last digit of the ip address such as 2 then 3 then 4. go back to internet explorer type 192.168.0.1 you will get the password prompt the user-name is admin and password is password
once done you need to check it is connected to the net it should say on the first page. if you need anymore info msm me moc.liamtohat1202gniksirhc
Oct 27, 2007 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Acer Aspire 5720 6497 Laptop Logo
114 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
