Question about Panasonic SC-HT800V System
Panasonic Active Subwoofer SB WA 330
I have been given the above to connect to my t.v. for surround sound, unfortunately, they have not given me the manual or the main connector cable. I have the plug socket but its the one with the scart lead coming from the main consol to the t.v., can you tell me what one I should get and what it looks like. thank you.
jane preston
2 Suggested Answers
jedweller
  • 21 Answers
SOURCE: Panasonic sb-wa 340 active subwoofer
This is normal operation.. The subwoofer will only play sounds below a set frequency...There may be a crossover setting in your menu that you can adjust the frequency cutoff to your liking.
Posted on Oct 01, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have panasonic active subwoofer
It's not clear if you have the SC-HT800, too, but the manual for the '800 includes the SB WA330.
http://service.us.panasonic.com/OPERMANPDF/SCHT790V.PDF
Thes Theater in a Bx systems are highly proprietary as evidenced by the unique interconnections. Mix n match is DIScouraged if not actually dangerous to the components.
Posted on Feb 19, 2011
How do I connect a new dvd reader with a Panasonic SB-WA340 active subwoofer?
Of the Phillips is not a home theatre system them you can but you will have no volume co trol of the sub. If it is the alot of philips home theater in a box (htib) use special plugs...you would need to change the cable end of the sub to a compatible plug.
Aug 23, 2016 | Panasonic Audio Players & Recorders
I have a Panasonic SB-WA340 Active Subwoofer, and need to know if this is compatible with other Panasonic home theater units?
It should be compatible with other Panasonic equipment that has an output for a powered subwoofer
Dec 25, 2012 | Audio Players & Recorders
I have panasonic active subwoofer sb wa 330.i didnot get the manual.can u tell me where can i get instruction manual. manu manukt76@gmail.com
Feb 19, 2011 | Panasonic SC-HT800V System
How to connect the speakers to the sb-wa342 panasonic subwoofer
I hope I understand you correctly.
As you can probably tell from the very different connector types on the subwoofer and the HTS, they don't match up. That speaker system and this electronics are not meant to be used together.
The SC-BT200 uses passive subwoofer while the SB-WA342 is an active (powered) subwoofer.
http://www.retrevo.com/support/Panasonic-SC-BT200-Home-Theater-Systems-manual/id/23459dj389/t/2/
Jan 21, 2011 | Panasonic SC-BT200 Home Theater Systems....
Panasonic sb-wa 340 active subwoofer has just low freequensy noice from subwoofer ! The other speakers working good and dvd fanction normally !
Oct 01, 2010 | Panasonic SC-HT690 System
I have a Panasonic Surround Sound system model number SB-WA 730 Background music comes thru but we can not hear them talking - it is like it is muffled in a land far far away
Make sure center speaker is connected.Look in owners manual to reset, unit might be in an incorrect surround mode.If listening to a stereo source, take it out of surround.
Jul 21, 2008 | Panasonic Audio Players & Recorders
Connect stereo to panasonic SB-WA310 Active Subwoofer
SA-HT800V yo quiero el cable que conectaal dvd del suruofer to sb-wa310 tel 809 904 2175 ruddy german.
Apr 21, 2008 | Panasonic Audio Players & Recorders
Panasonic subwoofer
Any active subwooofer. I have an HE70 as well and I am using the SONY active subwoofer.
Nov 12, 2007 | Panasonic SB-WA100 Subwoofer
Panasonic SC-HT800V System Logo
2,557 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
