Question about Kirby Generation 3 Bagged Upright Vacuum
Generation 3 light
Belt light, motor noise
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Need more info about fault !
Posted on Jan 28, 2013
Kirby vacuum g3 green light on roller assembly
belt will be stretched fit new gen kirby belt, copy belts are not worth fitting
Jun 18, 2012 | Kirby Generation 3 Bagged Upright Vacuum
My dyson is making a loud scweeky noise
www.sewvac.com Remove the bottom plate and disconnect the belt.If it still makes the noise it is the lower motor that drives the brush that is bad.If it dosent make the noise try cleaning off the hair and debris from the motor pully and replace the belt you will need to take the brush out to do this.While the brush is out check the ends for binding they should turn smoothly with very little resistance also check the area the belt rides on the brush and make sure there is no dirt buildup in the area the cogs of the belt ride in. If it is the lower motor and is less than 5 years old call Dyson and they will generate a work order for a service provider.It may very well be under warranty. !-866-693-9766
Jan 28, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Generation 3 vacuum. I need to know how to repolace the Kitrby Belt. The video online shows the Sentria, but that has not helped me. The problem I have is the arrows and tightening the...
The arrows should point in the normal running direction of the belt. If you have the correct belt, tension should not be a problem as it is stretched during placement of the sweeper head. Start the motor for a moment with the motor shaft exposed to determine belt rotation direction. Check the bearing ends of the brush to make sure they are free of debris, and that it spins freely with the belt off. Hope this helps!
Nov 28, 2010 | Kirby Generation 3 Bagged Upright Vacuum
I need to replace the belt I bought a new belt and I can't get the belt back on
On this page
http://www.totalvac.com/videos/kirby-vacuum-cleaners-videos.htm
there is a video at the bottom on changing belts on a Kirby
Sep 23, 2010 | Kirby Generation 3 Bagged Upright Vacuum
We have a kirby generation 3 and it slows down and speeds up almost sounds like it is going do quit could this be a brush problem in the motor sometimes it will quit.
You may need to service you Kirby. Go this page HERE, fill out Service Request Form and ship to us together with you Kirby. We will inspect it and will call you with an estimate.
Good Luck,
Rocky
Dec 09, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Kirby generation 3 won't vacuum. It runs and
You may have suction but if the belt is worn the roller brush won't spin and therefore won't pick up anything. You can get a replacement belt here:
http://vacbelts.xps.convina.com/kirby-301291-belt.htm
Oct 10, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Noise
What does this noise sound like? If it's a squealing noise, chances are that it is a belt going bad. You can purchase a new belt at your local Sears, or probably even your local grocery/department store. The vacuum belt is easy to replace and inexpensive. Instructions for belt replacement are in the owner's manual, or sometime on the belt's package. Hope this helps... Please take a few seconds to rate how helpful this suggestion was. Thanks and good luck!
Aug 24, 2008 | Kenmore Progressive Bagless Upright with...
Electrolux Hi-light
Burnt smell is probably the belt slipping. Even though it looks OK, either the belt needs replacement and/or the roller needs cleaning and/or lubrication at the ends. Try cleaning the roller ends first and then light lubrication with WD40. If belt works, you are done. If not, replace belt.
Feb 15, 2008 | Electrolux Central Vacuum
Kirby generation 3 fan
You have to take off the top cover, then the handle pivot. Look down at the back of the armature you will see that it has a flat spot, you use a small vise grips or pliers to hold it, turn the belt pulley to the right if I remember right and turn the pulley off. If it won't come free, use a couple of flat blade screwdrivers and pry up to pop the fan off. Then put it all back together.
Feb 11, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Kirby 2hd how do i put the belt on this vacuum thanks
On the Front of sweeper is a Tab Turn it and it will release the Beater Bar assembely Put the Belt around the Bar and put the Belt on the inner tab Turn and the Belt should go around motor Good luck ttech
Jul 24, 2007 | Kirby Generation 3 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
16 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
