Question about Panasonic TC-29P22R 29" TV
Stcuk in demo mode for Model TC - 29V2H not shown anywhere here
Hi, i couldnt find my model here quite old i think about ten years, for some reason is stuck in demo mode, ie the sign you have the pleasure of watching a panasonic t.v sign comes up every ten minutes. Can anyone remember back that far on how to get out of this on this model. we do not have the remote. i have read a few and they suggest using the action button together with the up volume botton but this set does not have an action button. The set has a press front tray that slides out automatically at the centre front when pushed with a finger. on this tray it has two line of buttons. on the top row there are 7 buttons that read as follows (0's are the buttons) 0 0 0 0 0 0 0 11 system 1 - + Auto/function Pre (Videosymbol) 0 0 0 0 0 0 Display TV/AV - (VOL sign) + V (arrow down) ^ and next to all that it says "AV operation unit" We also do not have the manual, and if anyone could point us in the right direction as to where to find a manual for this, we would be extremly grateful, thanks so much regards Alastair
  • 1 more comment
  • alastair haydock Jul 25, 2007
    found an old manual and seemed to work on this on e
  • Anonymous Nov 03, 2008
    I have the same problem, stuck in demo mode, I have 2 remotes, both of which are still nonresponsive, even when you hold down channel up and action. I have turned it off and unplugged for hours. Nothing works. Have any ideas?
    I have the same problem. Stuck in Demo mode, neither of my 2 remotes with new batteries get any response, I tried holding down channel up and action simultaneously, and unplugged the set for hours. Anyine got any ideas?
Alasairh,BEST WAY TOSOLVE THE PROBLEM;buy new universal remote and insert the CODE provided by the list of the code.See the result.
Posted on Jul 20, 2007
SOURCE:
Can't figure out how to change the time on the Fujitsu Ten am/fm cassette player in a 90-something model Toyota Camry. Please help!!!
You hold down mode button for 3 seconds then use selector knob to select time ,then adjust time to suit
If you need to turn demo mode off hold down mode button for 3 seconds ,select demo then turn knob to off
Feb 15, 2013 | Car Audio & Video
Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
May 08, 2012 | Microwave Ovens
Toshiba big screen tv wont quit streeming menu options
A model number would assist me in helping but here is a possible reason/s:
If menu keeps popping up may be a defective menu button on the set.
If set is actually going thru a "Demo" mode showing all features that demo has been turned on and needs to be shut off---usually in most sets it is somewhere in the setup or options menu.
Mar 19, 2012 | Televison & Video
When on intermittent they switch on full wipe fore about ten seconds then go back to normal and keep switching for no reason can you help. many thanks.john
i would try changing the intermittant wiper relay ,its in the fuse box area and its a bigger relay than the others but without the model and year i couldnt tell where it is located
Feb 17, 2011 | Volkswagen Polo Cars & Trucks
Alarm Demo mode pops up when we try to put in an address and the
Sometimes these will go into demo mode for no apparent reason. You can access the diagnostics screen by holding the map/music button while powering up. Be careful which buttons you press in this mode - select only the on-screen buttons, not the hard-buttons as they adjust brightness and contrast. Select the correct operating mode and power the unit off, then on.
May 13, 2009 | Lowrance Iway 500c GPS Receiver
Samsung fridge/freezer model SRS73DTA doesnt freeze.
Hi I have the same problem,
did you get an answer to your question..?
Jan 19, 2009 | Freezers
SONY Alpha 200
It's ten years old, mate - I doubt if anywhere on the planet has spares.
Jan 18, 2018 | Sony Alpha DSLR-A200K Digital Camera
TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Nov 30, 2008 | Philips Televison & Video
Demo Mode
Unplug the microwave for at least 3 minutes, then plug it back in, and BEFORE SETTING THE CLOCK, press and hold power level and start for three seconds. This should flash "demo mode off". Set the clock as normal. Enjoy!
Mar 31, 2008 | GE Advantium SCA2000B Microwave Oven
PANASONIC TC-20L3T
My experiance is to not put money into a TV that is over ten years old. TVs stress out their electronic components worse than almost any other electronic product. After 10 years, there are so many parts that are ready to fail that your are probably wasting your money trying to get any more life out of it.
Another option is to wholesale replace the main board by sending it to Module Exchange at 972-298-1212, or PTS Electronics 800-844-7871 ptscorp.com.
Be careful on buying a new one though. Often times, these new technology ones are much worse. Always Google the model number of the set you intend to buy and add the word 'repair' or 'complaint' to see if it is one of the many models that are customer service nightmares being produced by even the most reputable companies today.
Hope ya fix it!
Feb 21, 2008 | Televison & Video
Panasonic TC-29P22R 29" TV Logo
283 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
