Have a portable kerosene heater in my shop. Thermoheat 17,000-210,000 BTU. I get an error reading on the screen E-1 says could be photo cell or spark plug. It starts then goes out with a big puff of smoke. What do you think the problem is and where do i get the parts?TU.
Buffalo12980
  • 625 Answers
SOURCE: Reddy heater 110,000 btu forced air portable kerosene
try this, take off the top cover. plug in the heater and when the humming starts, rotate the fan sharply with a screwdriver. keep your fingers away from the fan. if the fan spins under power your start winding is shot. get a new motor. www dot desatech dot com
Posted on Dec 06, 2007
SOURCE: UNIT LITES THEN GOES OUT BLOWING SMOKE
Pick the heater up throw It at the wall, the heater has been used to heat my uncles home no problem now it wont light, on the day its needed most outside in the freezing cold, so my solution was throw it at wall and go to walmart.
Posted on Jan 15, 2009
heatman101
  • 43501 Answers
SOURCE: 70,000 BTU Reddy heater - runs - but it puffs smoke
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Oct 31, 2010
heatman101
  • 43501 Answers
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
heatman101
dcramer531
  • 1654 Answers
SOURCE: 115 000 BTU Diesel or kerosene// fuel psi 5.3///
There should be some sort of fire eye on this, either a visually operated sensor of a thermocouple that is reading the temperature of the flame. If it senses no flame it will shut the unit off so you don't get poisened by fumes.Does it re-set when you try and start it again or do you have to push the reset button, either way it needs to be re-set before operating again. I suspect that this sensor is causing your problems. These units also have fuel pumps, this may also cause the problem, hard for me to tell without seeing the unit.
Posted on Nov 14, 2010
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Thermoheat dtu torpedo heater reads E1 error
These are some possible causes:
1. Wrong pump pressure
2. Dirty Air Output,Air Intake or Lint Filter.
3. Dirty Fuel Filter.
4. Dirt in Nozzle.
5. Dirty Photocell Lens.
6. Photocell Assembly not
Properly installed.(Not seeing the flame)
7. Bad electrical connection between photocell and MAIN PCB assembly.
8. Defective Photocell.
If all those check out ok, then check these:
1. No fuel in tank.
2. Wrong pump pressure.
3. Carbon deposits on spark plug and/or improper gap.
4. Dirty fuel filter.
5. Dirt in Nozzle.
6. Water in fuel tank.
7. Bad electrical connection between ignitor and MAIN PCB assembly.
8. Ignitor wire is not attached to spark plug.
Nov 29, 2013 | Protemp 125000 BTU Kerosene Forced Air...
Parts
I would try Reddy heater parts google them and there is a whole list of places to order them from. As far as a local distributor I would not have a clue but myself if there is a Grainger store close by you I am sure that they may have parts or be able to send you in the right direction.
Jan 12, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
Hi, I need parts for a kerosene torpedo heater.
You need to call Portable Heater Part in Valparasio,in for replacement parts
Oct 07, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
Portable kerozene heater
If this is a forced air kerosene heater it does not use a wick. If it is a portable wick heater you can get them for all brands at Portable Heater Parts on the web.
Apr 02, 2009 | Reddy HEATER R115 115,000-BTU PORTABLE...
Kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Feb 19, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene Portable Forced Air heater comes on, runs awhile
The unit should have a fuel & air filter. Check that both are clear. Inside the burner tube, there will be a photo-cell, if the lense is dirty it will shut the flame off. The photo-cell needs to see the flame. You can carefully and gently, clean the lens with a tissue, soft cloth, or Q-tip. Please let me know how its coming along.
Feb 09, 2009 | Desa International Reddy Heater R115DT...
Heating & Cooling Logo
110 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
