Candy cwb714d When the water comes into the dispenser, it leaks from the drawer. I have taken it out and have cleaned it. There are no visible blockages.
  • 183 Answers
SOURCE: water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Posted on Dec 25, 2007
  • 1294 Answers
SOURCE: LEAKING DISPENSER DRAWER
Refer to your manual regarding the dispenser tray. You could try using a tooth brush to clean out dry detergent, which could be blocking the flow of water. You can take out tray to clean, ref manual.
Posted on Jan 13, 2008
  • 489 Answers
SOURCE: LG WM-1285FHD Leaking from Dispenser Drawer area
There is a problem with the dispenser assembly where the drawer enters.  You will have to have it checked by a qualified LG technician to see what the problem is.
Posted on Apr 28, 2008
  • 82 Answers
SOURCE: water leaking
deafenatly sounds like a blockage or remove soap dispensor and check that there is no damage below it
ie a crack in the plastic allowing water to escape
Posted on Jan 16, 2010
  • 82 Answers
SOURCE: Water runs from out the detergent dispenser on my front loader
Try pulling the drawer out again and look in the hole. Look on the bottom for detergent or softener piled up and allowing the water to come out the door or anything clogging the tube in the back of the hole. Look on the top, there are a bunch of little holes, make sure none of these are clogged, clean with a toothbrush and sewing pin if clogged. Take the drawer completely apart and clean thoroughly, check for any cracks. If nothing is found here Take the lid off with the 3 screws in the back and push the lid toward the back of washer and lift off. Run the washer and check for the leaks with a flashlight. DO NOT TOUCH ANYTHING ELECTRICAL. As there is a shock hazard with the lid off.
Thank you
Posted on Jan 23, 2010
Water leaking from detergent drawer
The first thing to do is take note of what the washer is doing when water leaks out in order to help pinpoint the cause. Does it only leak when filling? Is it leaking during wash or rinses? Or is it leaking only when it goes into spin?
Only leaks when filling
  • Water pressure that's too strong. Some dispensers can't cope with high water pressure. Make sure the washer is level as one leaning forward can leak if combined with high water pressure. Try turning the tap on the washer down. Only suspect this if you know the water pressure is high and it looks like it's gushing in quite fast on fill
  • If there is an optional detergent flap fitted in the drawer for holding liquid detergent make sure it is removed or drawn into the up position if using powder otherwise it prevents detergent running down into the drum
  • A build up of grease and slime in the nozzles at the top of the dispenser where the water flows in causing water to spray at the front and run out when filling. Check this article -black jelly-like substance in soap dispenser and on soap drawer (In extreme cases I've had to replace the dispenser.)
  • A build up of undissolved detergent in the base of the soap dispenser under the drawer (depending on the design). Remove the soap drawer and check the bottom of the soap dispenser for a build up of detergent that could allow water to run over the lip of the dispenser
  • Blocked dispenser hose: Some washing machines can flood water out of the soap dispenser if the hose leading out of the dispenser into the tub gets blocked. Blockages can be something put into the drawer by a child or a chunk of undissolved detergent tablet. Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and it wasn't wide enough. Undissolved powder from a tablet or lumps of detergent through poor water pressure can block this hose solid causing water to back up. Unplug machine, remove lid and feel this hose carefully for obstructions.
  • Overfilling: If the washer starts to fill and never stops it will flood out of the drawer eventually - Washing machine overfills
Leaks out of drawer during the wash or rinse cycle
  • Too many suds? If you can see the door glass is white with foam up to the top it could be foaming out of the dispenser. Too much foam in the washing machine
  • Overfilling: If the washer starts washing but the water doesn't stop coming in it will eventually fill the drum so much it will start to pour out of the soap drawer and other places. If this is the fault you should be able to see the drum is so full of water it's making a different sound, maybe labouring under the load, and the door glass full to the top with water. You should also hear that water is still running into the machine and be able to detect it by opening the drawer. However, in most cases an over filling washing machine should trigger an error code long before it gets to this stage but if you suspect overfilling check this page - Washing machine overfills
  • Surging: There are (often intermittent) faults that can cause the motor to spin out of control on wash or rinses. Instead of turning slowly the fault causes the motor to surge into spin instead which throws the laundry and all the water about violently. Water can then be forced out of the soap dispenser drawer. This fault should be relatively rare these days but if you observe this behaviour call an engineer to diagnose the cause.
Leaks from drawer only when spinning
  • If it only comes out on spin it can be caused by a partial blockage preventing the water being pumped out fast enough resulting in excess water being thrown around on spin and backing up into the dispenser. This fault is similar to the surging fault described in the last list but different in that the problem only occurs when it's on a proper spin cycle and much of the water has been pumped away. Troubleshooting this fault is all about finding out why it isn't emptying the water properly which is usually due to a partial blockage. Follow the same troubleshooting as described for a washer not pumping any water out at all - Washing machine won't empty water
  • If water is being forced out of the drawer when the washer is spinning but it is on wash or rinse and shouldn't be spinning follow the procedure for surging in the previous section above
Dec 23, 2016 | Washing Machines
Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
May 28, 2014 | LG WM-2277HW Front Load Washer
Water leak from front powder/conditioner drawer.
Completely remove the dispenser unit. look inside the recess you have just taken the dispenser drawer from and look up. You will find this is covered in muck. Clean it with an old toothbrush or something but do not use too mush pressure. This should solve your problem. If not then you will need to replace the dispenser unit completely
May 22, 2010 | Whirlpool AWM5125/1 Front Load Washer
I have a kleenmaid top loader washing machine. There is a leak coming from the bottom of the machine - I have taken the fabric softener cup out - but there is no bolt to remove the agitator. any ideas?
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 10, 2009 | Washing Machines
Indesit WIE147 leaking from soap dispenser
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 17, 2009 | Washing Machines
Water coming out the dispenser
Jun 15, 2009 | Kenmore Elite 45986 Front Load Washer
Leaks water from soap drawer
could be a loose hose to the drum from the dispenser or a tape still in the dispenser not taken off.
please check it.
tnx 4 using fixya,
drcool
Oct 27, 2008 | Frigidaire ATF6000ES Front Load Washer
Apr 27, 2008 | LG WD-1280FHD Front Load Washer
Jan 12, 2008 | Washing Machines
Washer Softnener dispenser
remove despenser drawer, by pressing down plastic tab and pulling drawer towards you, use hot water and old toothbrush to clean all compartments, the softer compartment can come apart to clean, use knife or flat screwdriver to take apart .good luck eire.
Dec 07, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
