Problems with Samsung LE32C450E1W
Screen goes fuzzy. Double picture
2 Suggested Answers
SOURCE: my t.v screen is fuzzy
The stretching might be due to having the wrong aspect size on your tv. Look on your remote and see if you have a button that says "Aspect" or it could say "ratio" or something to that effect. You can cycle through the different screen sizes to make it not appear to be stretched. As far as your picture being fuzzy, if you are using a standard antenna that may be the cause. If you are using cable, I would contact the cable company and have someone come out and check your signal strength, and possible inquire if you need a cable booster added. If you are running cable through a cable box and are running it straight coaxle then I would recommend trying a different hookup method, e.g Red, white yellow cables, or S-video or even hdmi, whichever your cable/satellite box and tv allows.
Posted on Dec 15, 2008
Anyone have problems with Panasonic TC-P60ST30 with white fuzzy picture mal-function?
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Aug 11, 2017 | Panasonic Viera Plasma TV TC-P60ST30
I am having ongoing problems with Samsung R519 laptop screen as it goes all fuzzy then goes normal then goes fuzzy again I have replaced the screen and screen cable and it still goes fuzzy then goes normal...
Have you updated the video driver in the laptop, there have been cases where the screen gives a variety of symptoms because the driver was outdated, if that fails! as crazy as this sounds do a fresh install of your operational system. I serviced a laptop with a flickering screen, I reloaded windows and got rid of the problem.
Apr 16, 2012 | Samsung R519-53S Notebook
What's your problem?On going problems with Samsung R519 laptop after all the advise I tested laptop on separate monitor and it worked fine with no problems I bought new screen lead and still had p
The external monitor has proven there is no problem with the video graphics card, I'am concerned that customers have complained about faulty screens.
I have changed a lot of displays without issue, there is a major circuit board mounted behind the screen that plays a roll in picture production so if something goes wrong you get all kinds of symptoms from fuzzy images to multi color lines to a blank screen. I would suggest getting your money back because of his track record, also go online to Samsung and contact customer support and the technical department to see if something was over looked. Question! is this a new or used LCD display?
Apr 06, 2012 | Samsung R519-53S Notebook
Samsung LE32C450E1W there's a red thin line going
try tapping your finger on edge of the screen where the line starts/ends... it works for me... its a lose connection normally with the rubber seals that have connections in them that lead to the circuit boards inside.... try it and let me know...
Feb 10, 2012 | Samsung Televison & Video
Picture goes off after a while
Call 1-800-Samsung to set up a warranty service call. They will repair it in your home if they send a Samsung Field Engineer. You probably have a bad Main bd.
Jul 01, 2009 | Samsung 32 in. LCD Monitor TV
Fuzzy Picture
Fuzzy is a funny word. I never use it to describe a picture problem. That because fuzzy can go too many different ways. There is snowy fuzzy, blurry fuzzy, grainy fuzzy, and demodulated fuzzy. If the set goes out of focus intermittently that has something to do with the focus ciruitry. If it goes grainy that is a front end problem, usually tuner related. The other types of fuzzy are generally associated with problems in video processing some where. So, which is it?
Oh, and BTW that unit has three small picture tubes in it, one red, one blue, and one green. It doesn't have a 'bulb'.
Feb 24, 2009 | Mitsubishi WS-65869 65" Rear Projection...
Broken phone
Hi all,
I had simmilar problems ie screen ok when closed but fuzzy when slid open, screen going blank etc.
I replaced the flex cable that connects the screen to the main board and the phone now works perfectly.
Nick
Jul 17, 2008 | Samsung SGH-U600
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
