Question about Tomtom GPS
Tom Tom GO 2435m wall charger instructions will not fit into Tom Tom
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
www.mobilefun.com/blog/the-trouble-with-cheap-chargers/
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ...
www.extremetech.com > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
gaming.stackexchange.com/.../what-wall-plug-chargers-can-be-used-to-c...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ...
Amazon.com: AC Adapter Wall Charger w/6'FT Power Cable ...
www.amazon.com/Adapter-ChargerCity-Manufacture...
Amazon.com, Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | Computers & Internet
Garmin does not work and strange sign appears on screen
The Tom Tom and Garmin chargers are not compatible because they are pinned differently at the plug end.
Mar 21, 2017 | Garmin nuvi 200 Car GPS Receiver
What addapter do I need to charge my tom tom start 55 to household electricity
If you already have the car charger they do not make a wall charger you have to order this adapter to convert from car to household charger they work great i have a few of them. http://www.monoprice.com/products/product.asp?seq=1&format=2&p_id=3526&CAWELAID=1329448387&cagpspn=pla&gclid=CLDRprD19rICFcyj4AodNFwAiA
Oct 10, 2012 | GPS
Says loooking for signal - even when plugged into car charger - could it be the gps battery
Being plug into a car charger (or wall charger) has little to do with not finding a GPS signal and this apply to your gps battery as long as you get power to your receiver.
It is not unusual for GPS to have problem finding suitable Satellites signals especially inside a building or areas where you do not have a clear view of the sky above you and the unit (e.g. High Rise buildings).
In order to speed up the location of satellites signals, you need to update your unit A-GPS Satellite locations database on a regular basis via 'Tom Tom Home' (which should be installed on your PC or Laptop). You can download the latest version of Tom Tom Home from the official site.
Without A-GPS and the unit not being in regular use, your unit may take a very long time to find suitable satellite signals. My own TomtOm One, without an up to date a-gps database has taken over 15 minutes to locate the required signals even in a relatively 'open' air location!
Hope it helps and clarify the issue.
Jun 12, 2011 | Tomtom ONE GPS Receiver
Tom tom will not switch on when i try to charge it the led light does not come on i have hardly used my tom tom
What is your charging method? In car or house hold plug? Suggest that charger is not working (Green) if light on Tom Tom (at bottom near charger lead) is not lighting. Check your charger and see if you have an indicator light on it showing it is on. If yes, plug in Tom, then press and hold the "on" button for 15 seconds constinuously. Tom Tom should reboot.
May 01, 2011 | GPS
My tomtom won"t turn on
If you have a tom tom from the GO models
they hace a reset button you can press with a pin were the mount fits.
When you plug in the charger the green light should come on to say it is chargeing.
Try the car adapter to charge the tom tom
Dec 13, 2010 | Tomtom GO 700 GPS Receiver
We have a 330-s tom tom and there is not plug to connect into the
The wall charger is not standard, you have to buy it...
Apr 10, 2009 | Tomtom GO GPS Receiver
try charging the tom tom fully and then reset while it is charging. a tom tom will not reset unless the new battery is fully charged which may take some time if you only have a car charger.
please give me a fixya! rating if this helped.
Apr 04, 2009 | Tomtom ONE 3rd Edition GPS
Need to replace wall charger for portable dvd -PDV-702
Well, you could bring it in to radio shack and have them check what type of tip you need, and then just buy a universal charger with that tip included.
Jan 10, 2008 | Durabrand Portable DVD
How do I recharge my Tom Tom One?
I talked to TomTom support about recharging. They say that the unit uses more power than it gets, but if you turn the power off while the car is running, it will recharge.
Aug 28, 2007 | Tomtom ONE GPS Receiver
GPS Logo
44 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
