Question about Electrolux Ergorapido Ultra Cordless Vacuum Cleaner EL1019A
HOW DO I KNOW IF MY ELECTROLUX EL1019 IS CHARGING
My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
Apr 04, 2013 | Electrolux Zb4106wd Rapido Wet And Dry...
The blue light doesn't stay on. What do I do?
Hi Alec from VacuumSpot here. In Australia these are sold as the ergo rapido. The most likely culprit is the charger itself we sell loads of Electrolux Ergo Rapido Chargers basically the best bet is to measure the output of the charger to see if it is working properly (watch video) if it isnt then simply replace the charger. If it is then replace the vacuum handset - Electrolux have made the handsets real cheap so you dont have to do a repair on battery or motor.
Oct 26, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
How do I know if it is charging
On your stand there are blue lights that show when it is charging the vacuum. If plugged up with out the vacuum on the base the lights do not show. Once you set the Vacuum on the base the blue lights indicate that it is charging.
Dec 21, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The blue lights on the charger base for the pronto stick vac go out after about 5 seconds and the vacuum is not working. What do I do?
check that the contacts are connecting and are clean of debris. If they are you can check the charging plug to confirm it is putting out 15v if not replace the charging plug. this is a common problem. you can get parts online at http://www.vacpartswarehouse.com/Electrolux-EL1000B-BZ-Pronto-Stick-Vac-s/3734.htm?gclid=CKDFg_3Jv7kCFc4-Mgody1wAjg
good luck
Oct 21, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
Do you know of anywhere I can get an electrolux repair manual for the 1205 model - I need to replace a motor. I have the motor Arthur Gaucher
Electrolux does not make their service manuals available to the general public or non-Electrolux service personnel.<br /> It
Feb 24, 2010 | Electrolux Vacuums
Electrolux ZB271RF Is the glass thingy, in series with the batteries, a resistor or a fuse? I borrowed a multimeter and it reads 0.5 megohms.
I figured the glass thing was a slow blow fuse.
Why it blew in the first place I'm not sure, as the batteries and motor are okay.
I bought something similar from J-car and whacked it in, it's been working like a charm ever since.
It was probably caused by the canister being too full & the motor running unloaded that caused the over current protection to do it's job.
I just hope it wasn't a resister that limited the charging current to the batteries. I guess if I see a small mushroom shaped cloud of smoke when i put it on the charger, I'll know it was.
Jul 13, 2008 | Electrolux Vacuums
Electrolux diagrams and schematics
Sorry, I don't, but you cn look on line or phone book for Aerus Electrolux. But if they will ive you any info, I don't know. Sorry I couldn't help you out.
Jun 17, 2008 | Electrolux Epic 6500 Vacuum
Electrolux Ergorapido Ultra Cordless Vacuum Cleaner EL1019A Logo
156 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
