Question about Whirlpool WED8300S Dryer
Whirlpool dryer wed8300swz error code 11
Well it looks like 11. There are just two slashes like two ones beside each other. There is nothing else. Also when I try to find model# WED8300SWZ the model number that comes up wants to put a 0 and not a Z.
  • 17 Answers
SOURCE: Error Code
Here's some magic help on the dryers: I have a duet sport- Whirlpool hides the complete service manual inside the cover at the bottom front of the machine- remove the bottom 2 screws, drop the cover & you have all test & service instructions--- (:
Posted on Dec 16, 2007
SOURCE: Whirlpool dryer model LEQ8800JQ won't start when push start butto
I posted today (Jan 2, 2009) that I had same problem. Handyman tested for blown thermal fuse, etc and everything was fine. He said I have to replace the timer switch .. well guess what - I fidgeted with the start button (on/off) hard a few times while simultaneously pressing & releasing door switch and it did the trick. In my case the problem was most likely with the start button. Dryer is working fine now!
Posted on Jan 03, 2009
  • 744 Answers
SOURCE: My whirlpool gas dryer keeps coming up with E1
The E1 code means there is an open thermistor. This thermistor is located on top of the blower housing. Access it by removing the bottom panel on the front of the dryer. This device is not repairable, so unless it's just a loose connection or the device is not firmly mounted, it will need to be replaced.
Unplug the dryer before you work on it!
Posted on Mar 28, 2009
  • 512 Answers
SOURCE: whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
Controlfrk
  • 304 Answers
SOURCE: Looking for the age of Whirlpool electric dryer
Link Below will give you the ability to calculate your manufacture date from the letters in the SERIAL number.
Whirlpool Date Codes
Posted on Sep 10, 2009
WHAT IS THE F1 ERROR MESSAGE
F1 error code is a miscommunication between the control board and the rest of the machine. Check for any loose or damaged wires. If no loose or damaged wires are found, replace the control board and this should clear up your problem.
Oct 22, 2015 | Whirlpool Cabrio 7.6 Cu. Ft. 11-Cycle...
What does F1 mean on a whirlpool cabrio dryer
You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool duet sport dryer control panel will turn on but nothing happens after that. thecontrols change and everything but no drum rotation, no heat. and every once in a while I get the f-01 error...
you have a blown fuse if you remove the front lower cover you will see a white long fuse about 2 inch long it is bad after you put the new one on it will work but you need to keep the front off and turn on the dryer and look at the heater and see if it is lighting up red all over if not the heater needs to be replace it is shorted out and that is what made the fuse blow
Nov 02, 2012 | Whirlpool WED9371YW Duet Electric Dryer
I have a whirlpool duet washer with error code f 11 please help!!!!
The F11 error code means "Motor control unit error". If there is nothing wrong with the wire harness, then looks like the motor control unit (MCU) has to be replaced.
But...
I would FIRST replace the door latch/lock assembly it has cleared this problem for some people and is the cheapest part for this problem.
It can be found here:
http://www.repairclinic.com/PartDetail/Door-Switch-Assembly/1094190
Mar 20, 2011 | Washing Machines
Whirlpool duet dryer error code pf
The error code means that the unit suffered from a power failure.just make sure that all the wiring is good there is nothing loose and the circuit breaker is in good shape you should be able to turn off the dryer unplug it for a few minutes and the plug it back in this should clear the fault code.
Feb 26, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
F 11 error code on whirlpool duet washer.
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
Kenmore he4 dryer 110.85089400
What does the error code 4E mean in your manual? - If you dont have the manual look under any cover.. they usually have one inside the unit for whatever tech works on it..
May 17, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
43 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
