Have Canon printer but wont print as states 'yellow' needs replacing..there is plenty of ink in the yellow but the light keeps going out & comes up with same answer..any ideas?
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came withthe printer. When the software program asks you to connect theprinter to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
My MX 700 won't print. I replaced thje yellow and magenta cartridges an dit keeps telling me that the yellow still needs to be replaced
Press on the pushmark.gif mark on the ink tank until the ink tank snaps firmly into place. reseat it again then turn off the power then restarts most of the time this fix the issue
Dec 02, 2013 | Canon PIXMA MX700 All-In-One InkJet...
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
The black ink keeps drying up and will not print out black print
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Jan 03, 2013 | Canon Cli526 Black Cyan Magenta Yellow 3x...
Canon MP510 wont print. Error message B300 or
May I know the exact error messages in the printer screen. If it's green and yellow lights that are flashing you need to push more the two cartridges that you replace....also try to clean it using the printer program installed in your computer....good luck and hope it will help....
Mar 31, 2010 | Canon PIXMA MP510 All-In-One InkJet...
The light for the magenta cartridge on my iP3500 printer goes off
The cartridge, as well as all ink jet cartridges has a chip inside that tells it how much ink is in the cartridge. Your cartridge is LYING, except it prevents you from printing without all cartridges working. ( same for my 6 color epson ). You need to replace the cartridge. I get my cartridges at a yahoo store called Inks4less. They have good quality for cheap.
There was a study done, analizing the amount of inks left in inkjet cartridges when they indicated empty, and the range was 7% to 25% ink still left.
Oct 03, 2009 | Canon PIXMA iP3500 Printer
Canon iP4500 not printing yellow
take the print head with all the cartridges still installed out of the printer. take a soft microfiber cloth and gently wipe the exposed surface on the bottom of the printhead. You should get some ink to wipe off the printhead.. reinstall and retry your printing.
May 31, 2009 | Canon Pixma iP4500 InkJet Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Yellow color light keeps going off
Yeah its a pain in the rear - only solution I have found is bite the bullet and replace the ink tank. They have have a chip and if the chip goes bad you are screwed. Mine likes to go out on the cyan tank. Great product Canon.
Jan 27, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon pixma refill is not recognized
Dear nedaa,
You need to deactivate ink level detection function to keep your printer working after refilling the cartridge. Click here to know more how to deactivate ink level detection function.
Source:
Canon Inkjet Printer Forum
Canon Manual & Tools Dowload
Jan 17, 2009 | Epson Stylus 2200 InkJet Photo Printer
MY Canon Pixma MP 500 Printer won't Print.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 15, 2007 | Canon MultiPASS F60 All-In-One InkJet...
48 people viewed this question
jasbo
jasbo
