Question about Canon NP 7130 Black and White Copier
Need to change the toner cartridge for canon k425 copier
Cogz
  • 1326 Answers
SOURCE: Canon IR210s copier
Are you sure you have the right toner??? It says it is for the IR-200-210 or dose it say IR-330 & IR- 400? If you look on the inside front door cover there are pictures showing how to install the toner, also there are pictures on the box the toner came in and also the display sceen will walk you through on how to replace the toner.. It slips in only one way and push down on it till it locks in then pull the blue tab till it displays "STOP" then push it back in and the push on the black part on the front of the developer unit to release the toner bottle and close the copier back up and lok the blue lever to the left and you are done. Good Luck
Posted on Jul 10, 2008
checkitright
  • 1362 Answers
SOURCE: Canon pc-6RE copier
check the drum for toner leaking, sounds like the drum blade.
the drum is a shiny cylinder inside the machine, open and and see if it has black rings
Posted on Jul 18, 2008
MXM450
  • 62 Answers
SOURCE: need to change the toner/ink cartridge for our cannon 7130 copier
Yes. Open the copier up (push the gray button on the left side) then grab the installed cartridge and turn it clockwise til it meets a mark (they are triangles i believe) then you should be able to pull it towards you.Careful thou, you might get little dirty! for installing the new one just do the same thing but on reverse gear :P (or read the instructions on the cartridge box, ok i needed to say it; my bad)
Posted on Jan 22, 2009
SOURCE: Installing the toner cartridge
release the 'clamshell' and slide it in. I don't know what else to tell you
Posted on Jul 27, 2009
  • 118 Answers
SOURCE: CANON CLC3220 COPIER ERROR CODE E0000001-0003
although the waste container is empty still it show 'THE WASTE TONER IS FULL' cleaned the bottle neck of waste container see to it that the 2transparent round hole area is not clouded by toner .this is the sensor path it should be cleaned(remove one screw to remove transparent cap)
Posted on Oct 03, 2009
How to change toner
Normally the procedure is indicated in the manual. Check the manual of your unspecified printer or copier.
Procedure is different on each device. Just for your illustration, enjoy some videos about how to replace toners on copier:
How to Replace Toner in your Ricoh Copier
SHARP COPIER How to replace toner cartridge
How to Replace Toner in Canon ImageRUNNER Copier
Toshiba copier 2006 toner change
Aug 07, 2015 | Office Equipment & Supplies
Canon pc 941 copier cartridge issues
Just to clarify, you are stating INK? The Canon PC941 uses an OEM (Original Equipment Manufacturer) Toner Cartridge. Canon toner cartridges for PC941 printer are supplies produced by the same manufacturer that makes given piece of equipment. Toner cartridges produced by Canon are called OEM. Remove the toner from the machine and then use cotton swabs and alcohol to clean around the roller wheels of all drawer areas. Be sure to unplug the equipment before attempting to clean the wheels.
Jan 25, 2012 | Canon PC-941 Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
I have a canon k425 and i was wounding how to get it set so i can use it . it is a used one and i dont know how to set it up to use liptki@uniontel.net
Plug it in, replace the ink cartridge, attach paper trays and start copying. This unit does not attach to a computer, it is a portable copier.
Dec 04, 2009 | Canon Office Equipment & Supplies
Cannon ImageClass mf6590 toner cartridge issue
I have the same question. If you get an answer please send me a reply. aste2426@aol.com Thanks!
Sep 22, 2009 | Canon ImageClass MF5770 Laser Copier...
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Jun 25, 2009 | Canon imageCLASS D320 All-In-One Laser...
Canon pc980 copier...changed toner cart. now the image it produc
Cartridge is defective. I suspect it was a 'compatible' or remanufactured unit vs. an original. Replace it and it will work fine.
Apr 20, 2009 | Canon Office Equipment & Supplies
Color toner
try this on the screen you touch system moniter then consumables this should gine you a divided screen on top toner levels on bottom should say change each toner select the ones you want to change
Nov 04, 2008 | Canon imageRUNNER 210S Copier
Canon NP 7130 Black and White Copier Logo
53 people viewed this question
old marine
old marine
