Question about Heavy Duty Arrow Et501 Electric Staplenail Gun
How do you load nails in the arrow et501
72winneroptonline.net
ARROW BRAD NAILER ET200 jambs all the time. can it be adjusted out or repaired to work?
Arrow Fastener Nail Master ET200 - YouTube
? 0:42
www.youtube.com/watch?v=-Y8OBdU29Qc
May 30, 2012 - Uploaded by Piranhamonkey
I made this video to show how a new, out of the box Arrow NailMaste... ... However, my NEW nail gun, jams up a lot, meaning I have to take the ...
Sep 12, 2015 | Arrow ET200 Electric Brad Nail Gun
Where to find non-marring bumper for arrow et 200 nail brad gun part number 2815
The non-marring bumper for the ET200 nail gun is Part #2815. Send a note together with a check for $1.50 plus $1.00 S&H to Parts/Service Dept., Arrow Fastener Co., 271 Mayhill St., Saddle Brook, NJ 07663.
Mar 26, 2013 | Arrow Heavy Duty Nail Master Electric Brad...
Nail gun has stopped firing nails
make sure that the nails are loaded in straight and packed down tight
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
I just bought a new ET 2000 , loaded it with 32mm nails, I tried it and the nails stick out. How do I select the right size in the nail gun? Sandy
Lowes close by you?
Take your gun to the tools section and ask the man or woman that works there what kind of fasteners you can use.
or
visit www.arrowfastener.com and search your machine.
It should have told you in the box what to use ...oh yea, you tossed those instructions.
I hope this helps you
a
Oct 12, 2009 | Arrow ET200 Electric Brad Nail Gun
How do you load brads into the Arrow t50pbn staple gun?
Look at rear handle and push in tab then pull out load brads. Please Rate Thanks
Jan 08, 2009 | Dynamic Arrow Fastener Co. T50PBN Staple &...
Inserting brads into my Stanley TR250 Staple Gun
I bought one of these guns today and I had the same problem and it took me about 2 hours to figure it out as the instructions were very poor. Here how to load the brad nails:-
(a) Pull the slider bar all the way out
(b) Place the brad nail stick on the left side, IN FRONT OF the slider, NOT in the narrow gap in front of the two arrows where it says "LOAD BRADS"
(c) The nail heads should be facing the handle of the gun
(d) Close the slider and lock it
(e) Try it out. I tried nailing hardboard onto chipboard. The lever at low power only put the nail in about 30%. On Hi power it went in about 80%.
Good Luck
Peter
Jan 07, 2009 | Stanley TR250 H Heavy Duty Heavy Duty...
How to insert fasteners
Already posted in response to a similair question, however repeated here to close off open query!
Good Luck
Peter
Heavy Duty Arrow Et501  Electric Staplenail Gun Logo
37 people viewed this question
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
