Question about Acer 22" X223w LCD Monitor
Specs for monitor x233w - Acer 22" X223w LCD Monitor
A450N needs new monitor - what monitor specs are required?
Any monitor will do unless you are trying to get one with the built in speakers that you have. Just make sure the monitor has the same type of connection that you currently have (VGA, DVI, HDMI, etc).
Apr 23, 2012 | HP Pavilion a450n PC Desktop
I need to get a foot stand for my acer x233w 22" monitor. the acer company is useless. i have googled this and located nothing at all, anywhere. can you tell me where i might buy a stand? please help...
I have the same monitor (i really like it a lot), same problem: Monitor does not sit up high enough, and i needed it much higher.
I'm thinking the middle of the screen should be just about eye level.
I tried this and that but had to settle for about 20 or so large books 'n' magazines underneath my monitor, it doesn' look sexy but it certainly does the trick.
Jul 06, 2011 | Acer 22" X223w LCD Monitor
We have just got a LG M198WA TV. Our question: Is it a digital tv with tuner?
You have just go an LG M198WA monitor. Not a tv.
You can see full specs at;
http://www.lg.com/uk/it-products/monitors/LG-lcd-monitor-M198WA.jsp
Clink on the tabs in the info bar to get Spec, features etc.
Apr 15, 2011 | LG M198WA 19 in. LCD TV
Out of range error
Out of range message means that the video resolution signal the monitor is receiving is not supported by the monitor. How do you hook up the DVD player to this monitor since it does not have composite ot component video inputs?
Spec: http://techwiki.hardwarecanucks.com/product/1NjEyNzUxMzgzMzE/ASUS-VW192T/#spec
http://s807.photobucket.com/home/budm/allalbums
Jun 28, 2010 | ASUS VW192T Monitor
Need P9NK60ZF
SPEC for STP9NK60Zxx: http://www.alldatasheet.net/view.jsp?Searchword=P9NK60ZFI
Mouser and DIGIKEY do not have them instock, you may be able to find cross from the spec I provide.
Jan 25, 2010 | Envision EN-9250 19" Flat Panel LCD...
Need AC Adapter for CTX JT156A2-2 Monitor or voltage & polarity specs for same...Thanks
the specs you need are usually embossed on the monitor near the power socket or on a label on the rear.
Sep 09, 2009 | CTX Televison & Video
Can a macbook pro work with a hannspree 28" LCD monitor?
I cant see why not, On you TV you have incomming port called HDMI, on your mac you have an outgoing port called MiniDislay for DVI.
You can use that port whit an adapter to make it to a real DVI, the you need another adapter to reform the DVI to HDMI. It can be done, its a little bit tricky, but it can be done.
here is the spec on your mac
http://www.apple.com/macbookpro/specs.html
And here are the spec for yor tv
http://shopper.cnet.com/lcd-monitors/hannspree-hf289hjb-flat-panel/4014-3174_9-32915918.html#info-5
Good luck to you
If you find my answer helpfull, dont forget to vote
Dec 14, 2008 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Hyundai n71s monitor
This monitor is sensing information from your computer regarding the configuration. The computer is trying to do the same thing. First, boot the computer in safe mode. This will set the output of the computer to VGA specs. The monitor should work with this spec. If not, then check your connections and try to reset the monitor to factory specs.
This monitor has only a limited number of resolutions and refresh frequencies that it supports. Be sure that your computer is configured to one of these standards.
Beyond that, try on another system, if possible. If it works there, it could be your video card is not compatible with the monitor/monitor not compatible with video card. I had someone give me one of these and it works perfectly. I tried other resolutions and the problem with it shutting down shows up.
Solution: run 1024 x 768 at first, then try to switch to 1280 x 1024.
Jul 09, 2008 | Hyundai Electronics ImageQuest N71S 17"...
Acer 22" X223w LCD Monitor Logo
79 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
