Question about Gbc Combbind C110E Electric Binding System
Manual combbind c110 jammed - Gbc Combbind C110E Electric Binding System
I am looking for travelmate c110 keynoard to replace the current keyboard.
http://www.cdsparts.com/p-37-new-acer-travelmate-c110-series-keyboard-kbt2707001.aspx
This is a place to buy a new one. Let me know if you need any more help. Hope this helps.
Mar 07, 2011 | Acer TravelMate C110 Tablet PC
How do i turn an acer travelmate c110 on and off
Here is a link to your manual. It's really hard to see the latch from the picture but I would try pressing in the top front button and raising the lit at the same time or sliding the top front slider to the right and raising the lid at the same time. (top front means on the upper lid facing you) good luck. http://www.elhvb.com/mobokive/edwin/laptops/Acer/TMC110SG.PDF
Oct 30, 2009 | Tablets & eReaders
The machaine jammed and now will not work. i have taken it apart and removed all of the jammed material. when the machaine is turned on, it goes stright into paper jam mode. There is an electric humming...
the machine still thinks it is jammed. the humming is probably the motor trying to turn, it can not beause it still has a jam? . you may need to remove the power cord from the wall. remove the shredder fro the stand. flip it over. remove the bottom cover and manual trun the cutting heads to unstick them. you may need a tech
Oct 21, 2009 | Office Equipment & Supplies
Acer travelmate C110 & Acer projector X11602
Hi Andrew,
you can try changing the output of the travelmate, to VGA Or External Device.
ensure you have the correct output lead from computer to projecter. Then on your keyboard you should have a button that changes the output. i.e numerical 5-6-7 or 8. usually says LCD/VGA et,c.
failing this try altering the output in the systems bios setup.
you can enter this by pressing F2 Or esc at bootup.
if your unsure, and none of this helps, i,d suggest visiting acers site. and downloading the user manual(s)
Mike @ Compurepair.
May 22, 2008 | Acer TravelMate C110 Tablet PC
Gbc Combbind C110E Electric Binding System Logo
29 people viewed this question
Top Gbc Office Equipment & Supplies Experts
George Mclaughlin
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
