Question about HP Serial adapter (17302A)
HP 1730 Monitor
The desktop has changed from horizontal to vertical, how do i change it back?
  • amag83 Dec 09, 2007
    HP 1730 Monitor
    My monitor turned off after about 2-3 hrs. I notice that the resolution has gone so dark that it seems that its off but it is really on. I can't get it to brighten up again. I know that the brightness and contrast options are all the way up because I checked them before it went out. What else can it be?
  • Anonymous Mar 23, 2008
    If the screen is on but appears to be black then how can we go to properties and adjust it at all?
The screen turns around bu i cant changfe the settings
Posted on Jan 25, 2008
  • 944 Answers
It depends on your graphics card driver. If you are using windows xp, go to "control panel", "Display", select the "settings" tab, and click "advanced". You should get a properties page, one of the tabs should be "Rotation" - change to what you want, then apply changes. If you are unsure why the screen changed in the first place, check on the "rotation" page for a description of the hotkeys - most likely there is a hotkey set to rotate your desktop which has been inadvertently pressed. If not windows XP, then the procedure is most likely similar. Hope this helps, please ask again if you need more info :)
Posted on Jul 20, 2007
HP 1730 driver windows 7
what i know is that monitors don't need drivers. if your monitor is new then i believe it is already windows 7 ready.
what you need to do is check the VGA cable if it is damaged. try replacing a new one. Hope this helps.
Jun 21, 2012 | HP 1730 LCD Monitor
I have a (HP L1730) flat panel monitor that im trying to use with my HP Compaq 6910p Laptop. When I power on the monitor,there is a quick 1 second flash of my desktop on the screen,then it goes to a black...
Does it do the same when it is hooked up to desk top PC?<br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial"><a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: Arial; mso-fareast-font-family: 'Times New Roman'; mso-ansi-language: EN-US; mso-fareast-language: EN-US; mso-bidi-language: AR-SA"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a></span>
Aug 24, 2010 | HP 1730 LCD Monitor
I have a hp monitor that can change from horizontal to vertical but when i turn it it doesnt change screen postion. how do i fix this
If you go to the HP support website (hp.com/support) you can download the application for your monitor that automatically switches the resolution and orientation upon swiveling the monitor form horizontal to vertical or vice versa.
Feb 06, 2010 | HP Computers & Internet
Monitor screen is showing sideways....in other words, the vertical is horizontal and vice versa. How do I make it go back?
If your video card has installed software go into the application and find the display property you should be able to change it through there. If not find the display button on your monitor and try that feature.
Dec 29, 2009 | Acer AL2216WBD LCD Monitor
Monitor is vertical display instead of horizontal display
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor display is vertical instead of horizontal
What Video card are you using?
WIN XP
Right click Desktop>>>Graphics Options or
Right Click Desktop>>>Properties>>Settings>>>Advance
and change the rotation to NORMAL
For Intel Video card go to GRAPHICS Properties
For ATI Video card go to CATALYST
For NVIDIA Video card go to PHYSx
Oct 09, 2008 | Dell Computers & Internet
Desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
(If that doesn’t work, try Ctrl-Shift-R)
May 31, 2008 | Acer X193W LCD Monitor
I recently received my Samsung Computer Monitor as a gift. I installed the driver, and as I was going through the color alterations, I noticed I couldn't change the H nor the V values, and I could not...
Horizontal and Vertical controls have little to nothing to do with the software drivers on the machine your monitor is connected to. Those are functions that take whatever output they receive and change the way that it displays that content.
My initial thought is to allow the auto-adjust feature arrange the picture for you, and then attempt to change horizontal and vertical values. If they still do not function, then I would suggest returning the unit to the distributor you purchased it from as defective and request a replacement.
Hope that helps.
May 01, 2008 | Computers & Internet
Display on monitor has swapped from vertical to horizontal
Type ctrl-alt then use the up, down, left, and right arrow keys until it's where it's supposed to be. If that doesn't work, right click on the desktop, select graphics properties. Then there should be a display settings, there you'll see where you can change the rotation of the display.
Aug 08, 2007 | Hyundai ImageQuest ImageQuest Q15S...
HP Serial adapter (17302A) Logo
2,178 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
