Question about Intel D845GVSR Motherboard
Windows xp 2 installing problem
What is the foult of any board section
  • sr_koppula1 Jan 28, 2009
    nvram we will keep option yes or no
    chassis option we will keep disabled or enabled
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
120
Posted on Mar 13, 2009
I think Ram Problem cheek it
Posted on Jan 27, 2009
Singer 21 in chess power supply k2629 sSTR chopper
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 15, 2014 | Computers & Internet
I have an hp mini 210-1041nr running win xp and when I start it, the computer tells me Windows\System32\Config\System missing. I tried service pack 3 but it didn't work. Can u please help?
You need to get a Windows XP from someone and follow these instructions:
Windows could not start because the following files is missing or corrupt
\WINDOWS\SYSTEM32\CONFIG\SYSTEM or \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
1. Insert and boot from your Windows XP CD.
2. At the first R=Repair option, press the R key
3. Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
4. Enter in the administrator password when requested
5. cd \windows\system32\config
6. Depending on which section was corrupted:
ren software software.bad or ren system system.bad
7. Depending on which section was corrupted
copy \windows\repair\system
copy \windows\repair\software
8. Take out the CD ROM and type exit
If that doesn't work or you can't get into the repair console then With the XP disk you choose to install Windows XP and when you choose to install over the current XP installation you will be given the option to repair the current Windows installation and you won't lose all of your data.
Mar 01, 2011 | Computers & Internet
I can not load Windows XP on my D815EFV it loadup to 13%
Hi, this could be your XP disk is damaged or your hard drive isn't set up correctly. For your hard drive, it must be sectioned and formatted before XP can be installed. If you need help with this process, come back to me.
Jul 23, 2010 | Intel Desktop Board D815EFV (BOXD815EFVLU)...
My lap top will not turn on giving error message windowssystem32congfigsystem
Copy \windows\repair\system
Copy \windows\repair\software
And Thanks.
Mar 18, 2010 | Computers & Internet
WINDOWS XP DON'T RECOGNIZE A PRODUCT'S LICENCE COMPATIBLE WITH XP
Check if this liscense expired or not? or my be this is not correct version so some boards doesnot accept it.
Feb 28, 2009 | Lenovo ThinkPad T400 - Intel Centrino 2...
No sound after installing windows xp
You will need to download the latest Windows XP driver. You can download this from the motherboard manufacturers website under the support section. All you will need to do is lookup your board model # and all available files & drivers will be listed for you. Hope this helps & please rate this solution fixya. Thanks.
Feb 04, 2009 | Intel Motherboard
Windows Xp sp 2 installation problem
check the cpu fan or remove it then put it again
Nov 08, 2008 | Intel D845WN (KD845WNPAK10) Motherboard
About windows setup
Hi niket_shah, sorry but you're board Asus M2N-MX, does support Win XP SP2.
Chances are that while installing windows updates one or more updates failed. People like myself know from repairing PC's which updates need to be installed first. If you're Win XP SP2 did not or would not install than either the Win CD is not a valid Microsoft Win XP SP2 CD or (You have a copy) & there is something wrong with the CD. After a fresh (New install) of Win XP with SP2 there is more than 90+ updates for SP2 which must be downloaded through windows update program. Or you're windows will not function properly.
Just to show you what versions of windows the M2N-MX board does support. Click the link listed below. Once the link loads click the + sign next to Audio. Scroll down the page an notice the different Window version listed for you're board.
http://support.asus.com/download/download.aspx?modelname=M2N-MX&SLanguage=en-us
To recap this issue. The problem is either the WinCD or possibly you're hard drive. Make sure you allow windows to perform a full format before installing window. (Not a quick format).
Mike
Apr 12, 2008 | ASUS M2N-MX Motherboard
Audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Aug 29, 2007 | E-Mu 0404 Sound Card
Intel D845GVSR Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
