Question about Electrical Supplies
Low voltage readings on Generac Centurion 3250 Generator
110 and 230 outlets only show 50 volts
CarlGehrke
  • 169 Answers
SOURCE: generator wont put out enough voltage, only get 107 volts, is this a voltage reg. problem
This problem is either that the engine RPM is too low (most likely), or that there is something amiss in the voltage regulation. Get yourself a DMM that measures Hz, plug it into the output and see if you get 61.5 Hz, if not look for the adjustment on the governor spring. On some Powermates this is a screw that pressed on the governor arm, on others it's a little tab the governor spring attaches to that you bend. Do this at no load. FWIW 61.5 Hz is also 3750 RPM of the engine.
Posted on Dec 01, 2008
CarlGehrke
  • 169 Answers
SOURCE: Generac Guardian 17.5KW Generator dies
If this is one of the big "taco cart" portables you need to check that the vent on the gas cap is open when you're running the engine. In the center of the gage on the gas cap is a little knurled knob, turn it counter clockwise (lefty loosey), about a half turn or so and run the generator.
If that doesn't solve your problem add to it here, otherwise please give me a rating I'm trying to build a little credibility here and could use the help.
Carl
Posted on Dec 02, 2008
CarlGehrke
  • 169 Answers
SOURCE: 20KW Guardian Generac does not produce 12 volts to run engine
The problem is that the printed circuit board inside the generator draws a little current from the battery even when the generator is not running. Over the course of a few days this can make the battery weak enough to be unable to get recharged by the built in running charger which results in not enough power to run the electronic governor on the generator. Usually the spark plugs will work even with a fairly low battery.
Most of the Generac generators come with a built in trickle charger that runs off of the transfer switch load terminals. If your built in charger isn't doing the job it's either broken or you have the wrong sort of battery installed in the generator.
Regards,
Carl
Posted on Jan 26, 2009
  • 83 Answers
SOURCE: three year old coleman 5000/6250 generator. High
Your RPM's are too high. There is no voltage regulator in coleman generators (generator is actually made by generac) and is 100% dependent on engine speed. There is a screw under the tank when your looking in from the recoil side. It controls the governor arm. Screw it in and it incresses the rpm, out decrease. Plug something in that draws a decent load while setting the rpms since you want it to put out 120 and 240 underload. Your idle voltage does not matter.
Posted on Apr 02, 2009
mydogisk
  • 50 Answers
SOURCE: Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Posted on Apr 13, 2009
How do I hardwire this unit for an in home use installation?
You would need to have a stable 12 volt DC power supply that plugs into a 120 VAC outlet. You can google these, and they come in quite a few varieties. The most expensive are the variable voltage "lab grade" ones, then the bench grade fixed voltage variety, and then the cheap consumer grade 12 volt 1 or 2 amp device designed for CB's and small 12 volt devices. But this will not work, because you are transmitting and could be putting out 40 or 50 watts with that thing. So you will need a good 10 amp to 20 amp dedicated transceiver power supply, unless you just plan on receiving in which case you only need a couple of amps and the cheapie will do. It's always better to have more amperage in a power supply. You then need to think about issues like back-up power with a gel cell 12 volt battery, which also would allow you to use the cheapie supply, because you would have plenty of current to XMIT from the battery. Schematic shows a very basic 12v - 30 amp supply. Good luck!
Dec 15, 2015 | Kenwood Used Tk-880 Uhf Fm Transceiver...
My generac rv generator runs bu no voltage output.
Try putting 12 volts across the commutator at the brushes. Ust a low current battery nor a car storage battery.
Good luck,
Marty
Jul 16, 2014 | Generac 5754 4.8 kW 120/240 Volt PrimePact...
I have a generac 6500 mega force, that has a 60v output on the 120v outlet and 120v on the 240v outlet, the regulator board has a blue wired that acording to the wiring diagram was to be hooked up to one...
You need to run tests on your alternator. We have made some videos to show you how to do this on our website. It is very easy!
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
We also hold some parts for generac generators if you need them. You can purchase them on this web page:
https://www.generatorguru.com/generac/
If you need any more help, please contact our Engineers. They will be more than happy to assist you with repairing and parts supply!
https://www.generatorguru.com/ask-the-guru/
We are always happy to help!
Regards,
The Generator Guru Team
World Leading Supplier of Parts and Spares for Portable Generators
Mar 18, 2017 | Electrical Supplies
How to connect a dryer
Hi Sheliah,
I'm an electrician and would like to help you. Assuming you're in the U.S. and this is an electric dryer (not gas), you will need to find a 240 (a.k.a. 250) volt / 30 amp circuit to connect it to for it to work. This would be connected to a double pole 30 amp circuit breaker in the electrical panel. There is no simple residential "adapter" to change voltage, current or number of wires - besides the old 3 wire grounding plug adapter in you grandmother's junk drawer. (What is a 50/250 volt dryer? - did you mean a 30A/250V?)
Your dryer should have a 4 wire cord with a 4 prong plug on the end - and it will need to be plugged into a matching outlet. The old electrical code allowed you to change the cord to match the outlet, but now it requires that both the cord and the outlet be a 4 wire type. The old 3 wire cord type is no longer permitted to be used when the dryer is moved or replaced. Of course, 3 wire cords are available everywhere and it is unlikely that anyone will turn you in for changing the dryer's 4 wire cord back to a 3 wire cord type (but I just wanted to tell they way it is supposed to be done). What you do - is your business.
If you have a gas (or LP) dryer, you probably only need a 120 volt / 15 or 20 amp outlet - they look like the standard types - but I think you'd have simply plugged it in and walked away if that were the case.
I hope this helped!
Apr 07, 2014 | Dryers
Low voltage out 79.2 volts
Randy, connect up your volt meter and try manually reving up the engine. Even a few hundred RPM can make a big difference in the generator output.
If that resolves the problem, then you need to adjust the high speed settings on the motor.
Mar 03, 2014 | Electrical Supplies
My generac generator is producing low voltage
check voltage input at voltage regulator, then check output from
the regulator.
Nov 07, 2013 | Generac 5622 GP Series GP5000 6,250 Watt...
Need adjustment procedure for a Generac Centurion generator, carb and regulator under full load
Before you adjust anything, suggest you verify gas line for proper pressure and importantly volume. Pressure for gas should be 5 to 7 inches and propane 11 to 14 inches W.C. Also make sure the line to the generator is sized properly and the gas meter is a high volume unit (if NG). 90% we find the problem with generator sunder load that otherwise are fine are fuel related. Good luck.
Sep 19, 2012 | Generac Power Systems Centurion by 16000...
Electrical Supplies Logo
54 people viewed this question
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
