Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
My bissel vacuum model 61c5-w smells like its burning an loud how can i fix it
  • 389 Answers
SOURCE: bissell lift off, brush won't move smell burning rubber belt fine
OK - so your brush roller is jammed. And yes, the belt is melting! Unplug the machine, remove the belt (you will need another new one anyway) then see if you can turn the roller by hand. If it turns freely without you doing anything else, then you may have put the new belt in incorrectly. However, you will probably find you can't turn it, or it's hard work (it should rotate freely). Remove the roller and check the bearings - there may well be something tangled up at one end of the roller. If you can get the roller rotating freely, all should be well.
Good luck
Posted on Mar 08, 2009
landsend
  • 1066 Answers
SOURCE: Bissell smells like it is burning
I'd take it back ...
Posted on Apr 03, 2009
  • 4 Answers
SOURCE: Bissell Lift-Off Turbo power outage
We experienced the same thing. There are several filters on the vacuum cleaner that need to be cleaned out regularly (monthly in the user's guide). But the reason ours was shutting down is a protective circuit that cuts power for 30 minutes to avoid burning up a motor when there is a clog. Our clog was in the hose on the back of the cannister. One end of it can be lifted out of the bottom. The other end locks into place on the top (by rotating the ring on the end of it). It is the path for the hair and debris to the bagless cannister. We found that the top end of that hose was clogged with hair preventing anything from going into the cannister. So if your cannister is not filling, that's probably your problem. Easy to remove the hose and it's only about 18" long, so find something to stick through it and force out all the clogged debris and hair. Good luck!
Posted on Jun 07, 2009
  • 4 Answers
SOURCE: Troubleshoot Bissell Lift-Off Revolution Pet Vacuum Cleaner
Probably a hose clog. Check the hose on the back of the cannister. Most likely clogged where it attaches to allow debris into the cannister. If cannister is not filling up, that's a sure sign. To remove from top of back of cannister, just turn the ring on the end of the hose to release. Take it outside and push a long thin object through it to force out the clogged hair or debris. The motor is designed to shut off the vacuum cleaner for 30 minutes when this happens to avoid burning up your motor.
Vac Belts
  • 701 Answers
SOURCE: Last time I used my Bissell Pet Hair Remover
When you smell burning like that it usually indicates that the belt is worn and slipping on the motor shaft. You probably need to change the belt. You can get the belts for your model here:
Bissell Pet Hair Eraser Belts
Posted on Nov 12, 2009
How to fix my Bissell vacuum it sounds like a really loud airplane about to take off its isn't that old .
It has a two year warranty so just return it. Sounds like a motor fault unless you have something caught in the drive belt or the brush roller. Tip it over and remove the base plate.
PowerForce® Helix™ Bagless Upright Vacuum' BISSELL®
https://www.bissell.com/powerforce-helix-bagless-upright-vacuum-1700Main Information. Product Title: Powerforce® Helix Bagless Upright Vacuum ' 1700. Model: 1700. Similar Models: 17003, 17004, 1700R, 1700U, 1700V. Quantity: 1. Warranty: 2 year limited. Register. Register Your BISSELL® Product ... Bissell 17003 Google Search
Mar 27, 2018 | Bissell Vacuums
My dog chewed the plug completely off my Bissell vacuum, model 61C5-W. Can I fix it myself, and where can I find the replacement cord?
The power cord should be a standard 3 wire cord. Any hardware store. Just buy the length you want. You will have to remove some covers/plastics to get to where the cord connects inside the vacuum. Look for screws holding panels in place. Once inside, you'll see how the cord is attached. Just replace the old with the new. Not critical which of the flat prong wires goes to + and - but be sure the ground wire (usually copper) goes to the ground screw and not a hot connection.
Oct 15, 2013 | Vacuums
Last time I used my Bissell Pet Hair Remover vacuum it smelled like something was burning and it left a black mark on the carpet. What should I do?
Nov 11, 2009 | Bissell Upright Vacuum - The Pet Hair...
My vacuum makes a really loud noise when I turn it on. It was working and now it smells like something is burning. I check the belt- it looks ok.
The belt may look okay but it still can be stretched or worn and can be slipping on the motor shaft and thats why you have the burning smell. I would try changing the belt. Here is a link to the manual and a link to the belt you need:
Bissell Momentum User Guide (PDF)
Bissell Momentum Replacement Belts
Oct 31, 2009 | Bissell Vacuum - Momentum Cyclonic 1 ea...
I have a bissell proheat
I would take it to a repair shop and have them look at it, most of the newer models are not serviceable by the consumer and would void any warranty if there is one, but most of all, don't let your daughter borrow ANYTHING. And have her pay for it!
Sep 12, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
93 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
