Question about Fujitsu 24C1 Air Conditioner
System will not start up.
We have a three pipe fujitsu heat pump system running 7 indoor units. 6 ceiling cassettes and 1 wall mount. All ceiling units seem to operate ok however the wall mount is flashing the power led constantly (red) and the green and yellow flash three times together then stop then three more times and so on. The outdoor unit does not come on.(A090MPBMF). We have power to the outdoor unit. We have tried a restart,by shutting down the whole system then starting the outdoor unit and then the indoor units with the same results. We have checked for phase reversal. The machine is less than a year old and was not installed by ourselves. The indoor units are all remote controled. Firstly can you tell us what the fault code is flashing and secondly any suggestions as to the cause and how to rectify. Many thanks.
    Problem Solver:
  • 14 Answers
This is a signal fault between the indoor and outdoor first make sure the dip switches are set start with the unit closest to the condensor set as unit 1 then next unit as 2 and so on the dip switches are inside the indoor unit on the pc board if you check the manual it will tell you which swithes to set, if this wasnt done when the units where installed they would have never worked i would also check the signal wiring between the wallmount and the splitter box / bc box and make sure there isnt a loose connection when you have ruled this out id say more than likely it is a faulty indoor board on the wallmounted unt
Posted on Apr 08, 2009
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
When I turn the heat on my wall unit the air door closes and the cooling light flashes 7 times. Will cool but will not heat.
Pls check indoor to out door 6 wirings. May be interchanged by mistake.
Example- Black wire in N with indoor but connected in C with out door.
And also check whether the sensor wire from indoor to out door has connected.
Tnx
Nov 15, 2013 | LG LMU187HV LMN096HVT LMN096HVT 21 SEER...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
AC unit
You should post this question in the air conditioner section so the proper experts will see it.
Sep 05, 2012 | Fujitsu Halcyon ASU9RMLQ Mini Split Wall...
I am looking to buy a mini split ac/heating 1 ton unit. I want to know how high from the floor does the unit have to be to cool and heat a 10 x 20 room?
Hi, when you buy your split system, the indoor unit will mount on your wall off off the floor a distance that the factory has made it for. With an 8' to 10' ceiling, it would be about 7' off the floor. This all depends on the refrigeration plumbing coming from the outdoor condenser to the indoor unit. It will tell you all of this on the installation kit for this unit, as the plumbing for the freon pipes are already pre-made for a certain height. A 1 ton, (12,000 btu) unit will have no trouble cooling a room of this size, so check with the manufacture on the height it will be.
Shastalaker7
A/C, & Heating Contractor
Jan 04, 2011 | Goodman Heating & Cooling
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
381 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
