Computers & Internet Logo
Posted on Jan 27, 2009
NO Audio out put
Hi
This is pitambar Mahanta .
I have problem with my Dell poweredge 600sc server system.
There is no audio sound out put.
Can you please give me any idea & how to fix the problem ?
Pitambar.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 15, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1096
Points
DellNO Audio out put - 2_bing.gifpoweredge servers are not needed for sound. DELL support will notsupport any sound cards or care anything about your audio issues. Youwill not find audio drivers because again, a server's purpose has nothing to do with audio.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 17, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
622
Points
I had the same problem with my Dell 400SC - basically it's a driver issue with Windows Server2003. You can download and FORCE the install of drivers for the integrated sound card, or just buy a little cheap card or (like I did) use USB speakers as these work a treat.
I did a write up covering all the OS version on my Poweredge - hope it helps
http://www.projex.com/blog/dell-poweredge-400sc-a-tale-of-craigslist-dodgy-xp-server-2003-and-a-beautiful-vista
Dell Poweredge 600SC running WIN SBS 200 boots to a black screen
The failed boot could be from a number of issues, mostly hardware failure. I would start with the processors. If the system is using 2 cpu, I would remove the 2nd cpu, reboot checking to see if you still get the black screen. If you do, remove cpu 1 and put cpu 2 in cpu 1 slot are retry. If the system boot, replace cpu 1. If not, move to check ALL the memory cards installed.
This could be a lengthy process. What hardware/software changes was made before the issue started? Worse case, the server may have reached its end life and need to be replace all together. I would also recommend reaching out to HP support for more information about your system.
Good Luck
N.I.T.
What operating system can be installed on Dell PowerEdge 600SC Server
depending on the amount of memory and processor speed i have installed windows 2000, windows XP. Linux, windows 200 server and windows 2003 server. it all depends on hardware requirements.
2answers
How or where in the BIOS do I switch video source to PCI? Old Dell PowerEdge 600SC. Attempting to install new video board.
Most servers (including the 600SC) were not designed for use with add-in video cards, thus, there is no jumpers or BIOS setting to disable the onboard video.
What audio driver to i need for my dell poweredge 600sc server running windows server 2003? Is there a direct link? I search and have not found anything.
dell poweredge servers are not needed for sound. DELL support will not support any sound cards or care anything about your audio issues. You will not find audio drivers because again, a server's purpose has nothing to do with audio.
Can't install Windows Server 2003 on a Dell Poweredge SC600 Server, says invalid partition.
NTFS Will support up to 2TB Partition Size
255 file name length and nearly unlimited file number :)
Skype ID amit.bhardwaj4
2answers
Dell Poweredge 600SC stops on a gray screen during Windows Server 2008 installation.
have you tried updating acpi settings in your bios, or better still switch it off in there. Or you could try updating the bios to the latest version
1helpful
I want to add a sound card into the PCI Slot, but already have a USB card in. Is there an extender or Riser that allows the use of two cards? The ports within the cards need to accessed from the slots on...
I put in a sound blaster sond card in my Dell 600cs from Wal-mart takes the newer soundblaster card is notched to work with 64 bit slots i have a pair of Poweredge 600cs nice workstations one is dedicated for data recovery. sound blaster live will not work
Hope this helps same way for adding nic cars use server cars have the noch to fit.
No Sound !
did you installed sound driver...if not then install it then sounds will come
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
