Lap opt heats up a lot when playing games and it slows down too
  • 95 Answers
It is because all the hardwares are functioning at their peak. Check if you can hear the spinning of the fan when you play. It would slow down as the games use a lot of memory and processing speed which wud slow down other applications. If its getting extremely hot, contact the dealer from where u have purchased as it can lead to hardware failures which can be expensive and time consuming to replace.
Posted on Jan 27, 2009
  • 47 Answers
During game play, CPU( Processor) and GPU ( Graphic processor have to work alot so it heats up. Normal activity :)
The lap top power supply goes off automatically while working sessions
It seems the game giving lots of pressure to your problem and there might be some dirt which is blocking your processor to cool down, So first I'll suggest you to Clean the Processor FAN dust properly and apply heat sink paste on top of the fan.
Aug 04, 2012 | Acer Computers & Internet
Why does my new iPad get so hot when I play games on it?
Hi Jessica,
Much to your chagrin I bet, there's not too many options besides "play it less" if you want to cool your new iPad down. If the heat is an issue for you now it is probably going to continue to be an issue for you later.
Having said that, there are a couple ways I have used that seems to cool down the iPad by a few degrees:
  • Turn down your screen brightness. This is the best way for you to avoid heating issues. Your new iPad probably came out of the box with brightness turned all the way up. If you turn that down you will notice a decrease in heat immediately.
  • Use Wi-Fi instead of 4G LTE whenever possible. Now obviously you can't do this everywhere, but whenever possible you should access the internet via Wi-Fi and avoid riding your 4G LTE chip. That baby is power hungry and will heat up quick.
  • Give your A5X chip a break. In less technical terms, try not to play graphics heavy games (like Infinity Blade) for an extended period of time. Like you said in your question, that's when you experience the most heat discomfort. If it is at all possible for you to take even a short break (like 10 minutes every hour) from gaming, it should do a lot to keep the heat down.
I hope that helps you out!
Mar 27, 2012 | Apple iPad HD
My pc's Front fan is giving bad sound and its speed increases while playing game and give sound but at normal using like chating playing songs it works oK now what to do any one plzz
When you are playing a game, your CPU has to work a lot and a lot of heat is released. To cool it down, the fans run at a high speed making that bad sound. Playing a song does not require a lot of CPU work. To reduce this get a additional fan which can control heat without making noise. Make sure your CPU and the Heat sinkers present are free of dust.
Dec 28, 2010 | Dell OptiPlex GX620 PC Desktop
Toshiba m115-s1061 very slow on the internet. what can i do to make it faster
  1. Keep it cool. Despite its name, you lap is not the best place to put a laptop. Laptops generate a lot of heat, which can have a severe effect on your laptop's performance. Try not to use it in a hot room. Never set it on a bed, pillow, upholstery or anything else that is soft. Instead, place your laptop on a hard surface like a table. If you like using your laptop in bed or on the couch, try putting a book or a thick magazine in your lap and then setting the laptop on top of that. Every ten minutes or so, turn the book over so the surface never gets too hot. This will absorb the heat.
  2. Step2Shut down unneeded programs before using power-hungry software like games or large spreadsheets. The more programs you have running at the same time, the worse your computer's performance will be. Most computers have a lot of unneeded programs running in the background from the moment you boot up your computer. Shut them down manually using Ctrl+Alt+Delete, or download a freeware application that will shut them down for you. If you have Wndows Vista, you can also access the start up configuration by selecting "Run" from the accessories menu, then typing "msconfig" in the box
Jan 24, 2010 | Toshiba Satellite M115-S1061 Notebook
My laptop slows down game play when the fan kicks on after about 20-30 minutes once the CPU heats up. It's to the point that I can't play games. Any thoughts?
You are burning up your computer and as you continue to do that, it will slow and slow until you kill it.
Those are my thoughts.
It might be that if you turn off everything except your game and assure a clean, clear air path, you may slow down the demise of your computer.
Not what you wanted to hear, Im sure.
a
Oct 10, 2009 | Dell Latitude D600 Notebook
Game moves too slow
There can be three reasons
1. The game requirements does not match your laptop requirements.
OR
2. There are lots of temp files/junk on the laptop which slows it down
OR
3. There is something running while you are playing such as virus scan, logged in your MSN/yahoo/AIM
Aug 29, 2009 | Empire Interactive Flat Out Ultimate...
Automatic shutdown problem with my DELL laptop
Sounds like you need more ram,,or your processor is too slow.
Jan 19, 2009 | Dell Inspiron 6000 Notebook
Slowing down suddenly when gaming
Hi rajiv2612.
Suggest you check for any software update's from GeForce for you're 8600 GT. Also check for any software patches for the game (s). (Include windows update service as well).
The normal stuff like running windows system defrag & disk cleanup utilities should be run once a month for gamers.
Lastly, if you feel heat may be an issue. Open the PC case & leave opened while playing the game that seems to slow down the most. If the game does not slow down (After checking & updating all of the above), than maybe you need to add a 3" fan to the case, so fresh air blows directly onto the 8600 GT.
Good Luck!
Mike
Jul 14, 2008 | XFX NVIDIA GeForce 8600 Graphics Card
Graphics slow down when viewing many items on screen at once or when watching replays on games!?
the fix i believe is to have a HD TV
There are some game issues with the ps3 and tv output.that sony could not fix.
it sucks to be sony
Jul 06, 2008 | Sony PlayStation® 3 (60 GB) Console
TOSHIBA LAP TOP A135-S4656 SCREEN WENT BLANK BLACK
over heated the video area in it will have to cheak video card inside or motherboard chips on it got to hot when u play games on labtops u must ua labtop cooler never set it on your bed
Jan 27, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
