Question about Lands Phones
Hi. I own a Nokia 6300 and recently the keypad just stopped working. Its not all they keys, only 1, 2, 3 and the selection button. I've tried removing the keypad and seeing if it works then, but it dosent. Today I tried taking the battery out and leaving it for a while, and putting it back in, and they worked for a minute or so. Please help im not sure if I should get a battery replacement or what.
  • 45 Answers
The problem is probably with the actual keys and not the battery. If the battery was the problem then it would effect the whole phone not just four buttons. Try opening it up and cleaning the buttons with an old brush and leaving it for a while. If that doesnt work then your nest course of action is to take it in to your local shop who will definitly be able to fix it.
Posted on Jan 27, 2009
How do I unblock calls on my Panasonic kx-tga470
Step 1 Press the "Menu" button followed by the "#" key on the handheld unit.
Step 2 Enter "217" on the numeric keypad to access the blocked numbers menu.
Step 3 Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4 Press the key under "Erase" to remove the phone number from the list.
Step 5 Select "Yes" to confirm your selection.
Mar 15, 2016 | Panasonic Lands Phones
How to unblock numbers that have blocked?
Is this for the cordless phone? If so try this..
Feb 09, 2016 | Panasonic KX TGA641 Cordless Phone
How to unblock previous blocked numbers
Nov 12, 2015 | Panasonic KX TGA641 Cordless Phone
Tga641
STEP 1 Press the "Menu" button followed by the "#" key on the handheld unit.
STEP 2 Enter "217" on the numeric keypad to access the blocked numbers menu.
STEP 3 Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
STEP 4 Press the key under "Erase" to remove the phone number from the list.
STEP 5 Select "Yes" to confirm your selection.
Feb 20, 2014 | Panasonic KX TGA641ET 4Line Cordless Phone
How do I put a keypad lock code in my Nokia C7-00
Simply press the menu key and ash(*) key and the key pad will lock it self.
Or press the menu key, scroll to setting, press select key, scroll to phone setting, press select key, scroll to key guard setting, press select key, then you can now choose either theautomatic key guard or you want to use your on code.
When using the automatic keyguard, you specify the the seconds you want your phone to stay before being automatically locked up and presss ok.
Regards.
Jun 16, 2011 | Nokia Lands Phones
How to unblock a number on model#kx-TGA931T panasonic house phone. Number was blocked by accident.
THIS IS HOW YOU DO IT!!!!! EASY VERSION
Step 1
Press the Menu button followed by the # key on the handheld unit.
Step 2Enter 217 on the numeric keypad to access the blocked numbers menu.
Step 3Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4Press the key under Erase to remove the phone number from the list.
Step 5Select Yes to confirm your selection.
Feb 25, 2010 | Panasonic Lands Phones
Pulse and tone
in GE:
TONE/PULSE DIALING
This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for
touch-tone use. To set to tone or pulse dialing:
1. Press and hold the program button for two seconds. You will hear a beep.
2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing.
3. Press the program button again. You will hear a confirmation tone.
Mar 16, 2008 | Lands Phones
Handle Speaker phone stopped working
I'll assume this is on the base station portion. You can try unplugging the power while the phone is in the base, wait a minute, then plug back in. If that has no effect, I'm afraid you either have a failure in the keypad or in the electronics. To diagnose a keypad failure in the base, you'll need to disassemble the base. You'll find each of the rubbery keys momentarily connects two traces on the keypad circuit board when you press a button. You may also find the keypad fouled with dirt, liquid, etc, which could be a likely cause of failure. You can try manually shorting the two traces where the SP/Phone button would press and see if you are able to activate the speakerphone/dialtone. If that works, then carefully clean the keyboard circuit board and the rubbery keys. If that does not work, I conclude you have a bad keyboard circuit board or other electronics in the phone are bad.
Dec 16, 2007 | Panasonic KX TC1713 Cordless Phone
Lands Phones Logo
91 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
