Question about Bionaire W9U Humidifier
Gurgling sound I Have a Bionaire W9U humidifier thats making a gurgling sound. We havent used it in about 3 yrs ( Vinegar ?)
  • amblerjl May 11, 2010
    I have a W-6 with two tanks and it has gurgled from day one. It is the water and air exchanging places. Water going out of the tank and air going in. That is how it is suppose to work. The tank has a sort of vaccuum in it which allows the water to go out a slow rate and air to replace it thus the gurgling noise. I guess some units are more quite then others. Mine acutally sounds like my cat barfing up a hair ball.
  • 114 Answers
The gurgling noise is the water going into the base. since you haven't used it in so long your going to hear some weird noises at first then they should go away. but before using it make sure that all dust particals and everything is cleaned. if you have any more problems please let us know.
Posted on Sep 04, 2009
My humidifier made gurgling sounds so I opened it again and there was water in between the two halves. Is that normal?
what you are doing wrong is not reading the user manual before you used it
if you don't have one down load a pdf version from the net
Jul 06, 2016 | Humidifiers
Making gurgling sounds and spitting water. Do i just need to send it back, it's only a few months old
Before I returned it I would clean it thourghly and refill with clean water and about 1/4 teaspoon of table salt. Run it thru a full cycle and see if that helps. You can also rinse it out and refill with a 1/2 cup of vinagar and run again.This shoul help loosen and clean any mineral deposits. Hope this helps. Thank you.
May 20, 2011 | Vicks V3100 1.2 Gallon Humidifier
My vaporizer is making a quiet bubbling/gurgling noise. This is only the second time that I've used it, but I can't seem to find the instruction manual. What could this mean?
That is very normal...the sound is the water being turned to steam which is the "vapor" that comes out...
Everything is okay and perfectly normal.
heatman101
Mar 30, 2010 | Vicks V150 Humidifier
Steam not released through spout but trapped
is the spout clogged? Try running vinegar through it, CLR is a good product, but may stay the plastic, if not eat it, so I recommend vinegar to clean the deposits that plug things up, it may smell a bit, but usually works. Once cleaned, use distilled water to keep it from happening again, or just clean regularly with vinegar.
Feb 28, 2010 | Bionaire BU4000-UC Humidifier
How to clean bionaire bcm4530
the easiest way to clean the unit is to fill the unit with vinegar and water. it takes 1 cap full of vinegar per gallon of water. run all the water out of it. now if you don't like the smell of vinegar what you can do is take some bleach let it sit in the take for about 20 minutes. wipe out the rest of theunit with water and then rinse the tank very thoroughly before placing it back on theunit. once you have done that the unit will be cleaned. now ifyou don't want to do either one of those options. you can always call the manufacturer or check around and local hardware stores and they will have cleaning solutions taht don't have any smell or anything to them and you can put that in your unit as well. if you have any more questions please feel free to ask.
Jul 08, 2009 | Bionaire Cool Mist BCM4530 Humidifier
Looking for manual instructions to clean vaporizer with vinegar
all you need is a capful of vinegar mixed into the water and it will clean it like new again
Feb 21, 2009 | Bionaire Warm Mist BWM0400-U Humidifier
My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
May 19, 2008 | Humidifiers
Humidifier stopped working after cleaning.
It started working again on its own. Not much of a solution!
I think some water must have got into the electronics and then once it dried, the humidifier started to work again.
Christiaan
Feb 07, 2008 | Bionaire Warm Mist BWM0400-U Humidifier
Bionaire W9U Humidifier Logo
621 people viewed this question
Top Bionaire Humidifiers Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a Bionaire Humidifier Expert? Answer questions, earn points and help others
