Question about Magicard Rio Card Printer
File Error (c600)
Today, the ribbon snapped in our Rio, which i fixed the usual way by rejoining the rollers. But since i have done this, i am unable to print any cards, although there is no warning lights and the status monitor indicates as "Ready".
I have tried reinstalling the drivers and printer software with the newest software available on the Magicard website but still no printing.
I think it is some sort of communications error because after 5 mins of doing nothing i get the error c600 (file error).
Any advice would be great.
Thanks in advanced.
Richard Watson.
    Scholar:
  • 71 Answers
Hi There,
I'm sure this must be a coincidence.
When the ribbon snapped, did the printer report and 'Out of dye film' error on the PC (via the Status Monitor)?
Did you install the latest version of the driver (V6.02 is compatible with both Rio 1 and Rio 2)?
You can download this here;
http://www.magicardonline.net
Just enter your printer's serial number in the QuickSearch box.
If you are updating to a later driver version, please make sure you choose 'Update driver files' rather than 'Add a printer when give the choice (you will need to restart your PC).
I hope this helps.
Regards,
MC.
Posted on Mar 31, 2009
Printing lines on cards
Hello Richard,
Sorry for the delay in replying to your request.
You may have already resolved your issue by now.
The advice below may help others with the same issue though.
In the case of a damaged (scratched) printhead, the lines always run along the cards longest length (landscape), and are always in exactly the same place.
They are normally White, and usually very thin (just a few pixels wide). You would also see the line on the used dye film too by unwinding some film from the take-up spool (at the front of the printer).
Sometimes in the case of older out-of warranty printers, it is easier / cheaper just to avoid that are of the card using the card design. The image can also be rotated 180 degrees in the driver's Printing Preferences. However, if the card design has a solid colour background, or the White line is in the centre of the card, printhead replacement may be the only option.
Depending on which Rio model you have (Rio, Rio 2, Rio2e, or Rio Pro), different printhead assemblies are available as a field replaceable unit. Part numbers are below;
Magicard Rio - FG/M9005-794
Magicard Rio 2 / Rio 2e - FG/M9006-630E
Magicard Rio Pro - FG/3652-0160
All are available from your local Magicard dealer / reseller.
Prevention is better than cure;
  • Replace the sticky cleaning roller in the cleaning cassette as regular as possible.
  • Only use good quality blank PVC card stock (no sharp edges, or burrs)
  • Clean the printer regularly using the appropriate cleaning kit;
    Rio, Rio 2, Rio 2e (Cleaning kit part number: M9005-761)
    Rio Pro - (Cleaning kit part number 3633-0053) *
    Rio Pro - (Sticky roller kit (5 rollers +metal shaft) - 3633-0054)*
    * A sticky cleaning roller is supplied with every new dye film
Kind Regards,
MC.
Dec 03, 2013 | Magicard Rio Card Printer
Magiccard Rio printer is giving error code 24:24
Error code 24:24 means that the sensors need to be replaced. This requires sending the printer back to MagiCard for them to replace the sensors.
Mar 01, 2013 | Magicard Rio Card Printer
The printer ribbon keeps breaking and when it does
The printer needs to be cleaned and the cleaning roller (the cylinder thingy that comes wrapped) may need to replaced. You will know if it needs to be replaced if it looks dirty.
Jul 29, 2010 | Magicard Rio 2e - Ethernet - Single-Side...
I have a problem with the keyboard on Dell C600 laptop. It seems like the left part of the keyboard is disabled. No respons on 1,2,q,w,a,s,z,x,Esc. I purchased a new keyboard on eBay, but it didn't fix the...
The C600 keyboard connector is a ribbon cable with a push down to connect block. When one side of the keyboard keys do not work it is usually because the pins in the keyboard socket do not make a good contact with the ribbon cable.
Remove the keyboard and visually inspect the pins in the connector.
If necessary you can prise them back into the correct position using a sewing needle or something similar to get behind the pins.
Make sure you discconect the power supply and battery before you attempt.
Jul 31, 2009 | Computers & Internet
How to install a ribbon in an IBM selectric II typewriter
Pull the orange lever located on the carrier to the side. Make sure the ribbon passes through the ribbon lift guide next to the platen. The ribbon should go behind the the thick part of the guide and through the fingers to the inside on the outside of the guide. There is a wire (usually with a white platice roller on it) sticking up from the carrier. Maker sure the ribbon goes aroung the outside of the wire. Snap the ribbon down on the carrier then close the orange lever back in place.
Jun 26, 2009 | IBM Office Equipment & Supplies
Error condition
Have you tried to reset the printers defaults?
Aug 13, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Need help w/ink
Hi...This calculator takes a IR-40T ink roll.
Turn off the power.
Open the top cover,
There is a flat tab on the ink roller, lift up, remove.
Hold the new roller by the tab, line it up in the slot and snap in.
Turn on the power and test.
If it doesn't work you might not have it snapped in properly or all the way.
Good Luck........
Squipps
Jan 08, 2008 | Casio HR-100TEPlus Calculator
Magicard Rio Card Printer Logo
195 people viewed this question
Top Magicard Office Equipment & Supplies Experts
Safe-Card ID...
Tom Chichester
Are you a Magicard Office Equipment and Supply Expert? Answer questions, earn points and help others
