Question about Unknown ProLectrix 80-4998 Windsor Wall or Free Standing Electric Fireplace,WallMountedBowFront Panel,Flame Effect,Safety Thermal Cut -Off,Free Standing Base
Manual prolectrix fireplace - Unknown ProLectrix 80-4998 Windsor Wall or Free Standing Electric Fireplace,WallMountedBowFront Panel,Flame Effect,Safety Thermal Cut -Off,Free Standing Base
I need a manual
Try google.
Humidifiers Instruction Manuals at Bionaire.com.
www.bionaire.com/...manuals/humidifiers/humidifiers-manual.html
Browse our Humidifiers Instruction Manuals to find answers to common questions about Bionaire® products. Click here to view on our FAQs now.
[PDF]Crane Owl Cool Mist Humidifier Owners Manual - Sylvane
Dec 18, 2015 | Humidifiers
How do I clean the dust from an Amish fireplace
This shut down is a safety feature on the unit so it doesn't over heat.
You need to remove a cover that's in the back on the bottom and
take compressed air to blow out the dust. Concentrate on the
blower especially. Best done out doors.
This is also a good opportunity to see if the blower still turns
freely. If not it'll need lubed or replaced.
Sep 01, 2014 | Unknown Heat Surge Amish Crafted...
How to make ice cream?
You want to make ice cream with a fireplace? Interesting.
Jul 30, 2014 | Unknown ProLectrix 80-4998 Windsor Wall or...
Unit turns itself off
It's dusty inside. I came he to find out how to clean it
Mar 12, 2014 | Unknown Heat Surge Amish Crafted...
My heay surge stove will run for awhile and then shut down
The heater is thermostatically controlled, so once the room temperatures reaches the heater's preset temperature, the heater cycles off. This is normal.
However, If the heater goes off BEFORE the room reaches the preset temperature, suspect a high temperature safety switch that may be tripping. Does the heater come back on after it cools down?
Oct 08, 2013 | Unknown Heat Surge Amish Crafted...
Heat surge fireplace
Customer Service
1-800-924-7964
Mon - Fri: 8:00am - 9:00pm EST
Sat - Sun: 9:00am - 6:00pm EST
custserv@heatsurge.com
Oct 12, 2012 | Unknown Heat Surge Amish Crafted...
What should my humidifier be set at for the winter?
Hi, Jennifer:
I'm no expert, but those who are seem to agree that the first thing to check is your evaporator panel. Aprilaire recommends replacing it annually--so if you haven't replaced it recently, that would be the first step to take. Next, check the power supply to your Aprilaire unit. Turn the humidistat to 0%, and then turn it slowly back toward 35% until you hear a click at the unit. If you don't hear a click, you'll want to check that the unit is in fact getting electric power (you may want to get an electrician or furnace tech to do this). If you do hear the click, the next thing to check is whether you have sufficient water flow to your Aprilaire unit. On mine, I had to adjust my water supply saddle valve, as well as the inline valve on the discharge side of the solenoid (see prior post from this morning)--and this seemed to clear the lines and restore water flow. Once you achieve proper water flow, you will probably want to set your humidistat at 35% for winter temps of around 20 degrees F--but be sure to adjust it downward for colder weather. Comments, anyone?
Dec 13, 2008 | Aprilaire 700 Humidifier
Unknown ProLectrix 80-4998 Windsor Wall or Free Standing Electric Fireplace,WallMountedBowFront Panel,Flame Effect,Safety Thermal Cut -Off,Free Standing Base Logo
Top Unknown Humidifiers Experts
Mack Baxter
Dennis
Are you an Unknown Humidifier Expert? Answer questions, earn points and help others
