Question about Garden
Pulsa-jet adjustable carb I need a diagram
I need a diagram of a briggs and stratton tank mounted pulsa jet adjustable carb on a horizontal crank engine
  • 546 Answers
I'm not able to post a diagram,but I can give you some info-you'll need to-replace the rubber diaphram/gasket if it hasn't been replaced in the last 2 years remove the hi &lo speed needles,give it a cleaning with spray carb cleaner,put it back together,start with needles 1& 1/4to 1 1/2 turns out.it's a basic,simply designed carb.Ah for the good old days!Find a chiltons small engine repair manual for a diagram
.[hint] start w/a full tank
Posted on Jan 22, 2013
Testimonial: "I need a visual for the linkage from the carb to the governor but I'm going to follow through with your suggestion on the diaphram/gasket and get a hold of a Chilton's s.e.r. manual also. Thanks for the input. Scott"
  • 86 Answers
SOURCE: Briggs & Stratton engine on Murray lawn mower
I always replace the air filter if its a paper element, and even if its a foam element I replace it rather than clean it. That said, engine stumbling is rarely and air flow problem - but it could be, so having a new filter assures no air restrictions.
I would drop the carbuerator bowl. On the bottom of the carb, near where the fuel line comes into the engine, should be a nut. Removing this nut allows the bowl to drop off the carb. Some engines the bowl screws off, you will have to look at the bowl. Often the bowl has sediment or sludge buildup inside. Cleaning the bottom of the bowl can prevent that sludge/sediment from plugging the intake tube. Even on newer mower models this is a common problem, the gas line tubing interior breaks down and the inside of the tubing can start degrading - ending up in the bowl as sludge.
After cleaning the bowl, I would add one ounce of fuel line cleaner to a full tank of fuel and run the entire tank of fuel. This will clean any deposits or "varnish" from the interior carb parts. Doing this and the first step will assure your carb is clean and functioning.
If that doesn't help, then I would look at the spacing between the magneto and coil assembly. If you want to do that I'd like you to write down all the model numbers and serial numbers on the engine nameplate, that way I can give you specific directions.
Hope this helps,
Gregg
Posted on Mar 29, 2009
  • 57 Answers
SOURCE: Need linkage hookup diagram for Toro Super
Go to TORO.com and view parts for your model.
Posted on May 19, 2009
  • 166 Answers
SOURCE: Briggs & Stratton Quattro lawn mower
A lot of time when the small motors on these push mowers surge it is a governing spring that is weak or broke. It does not hold enough tension and causes the valve to fluctuate. I have fixed this many time for a relatively cheap amount (under $5).
Posted on Jun 16, 2009
  • 1129 Answers
SOURCE: Briggs and stratton engine surges and slows, repeatedly
There is still either water or debree contaminating the fuel system. Surging is usually debree, empty and flush the tank with gas or Iso alcohol, disassemble carb soak in solvent for 30 minutes blow out the carb passages, reassemble and if the problem persists run engine at top rpm with air cleaner off and block off carb intake with hand, this will stall the motor restart and repeat 4 - 5 times this wiil draw out any debree or other blockage in the carb.
Posted on Jul 25, 2009
hunter19_46m
  • 7482 Answers
SOURCE: 4.5 hp Briggs& Stratton push mower will not run
You need to rebuild your carb. The diaphram in the carb has gotten hard and is no longer acting as a fuel pump to pump the fuel to the carb. Get a rebuild kit and a compressor (for compressed air) to blow out the jet passages. It is an medium to easy job, just watch the small parts. ----------------------------------------------------------------------------- Hint: Before you remove your fuel/air jets, bottom them out first and count the number of turns it takes to bottom them out and mark it down for each fuel/air jet. When you go to reinstall the fuel/air jets bottom them out and then back them back out to the number of turns before removal. That way the fuel/air jets are set to the right number of turns when it was running right. Good Luck, I hope this helped Please rate me...Thanks
Posted on Jan 04, 2010
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
Were is the caburetor jets
depend on the engine. some briggs have the carb mounted to the gas tank. If your equipment is older, say about 20-25 years old the carb may have screws(idle mix, high speed mixture). Sometimes the main jet is the bowl nut.
Sep 05, 2012 | Briggs & Stratton Garden
Surging problem on 10 HP Briggs & Stratton rear mounted engine on @86 Snapper mower
Dirty fuel in the tank, breather in the filler cap blocked, or partly blocked main jet in the carb, if there is a fuel solinoid on the base of the carb check its function by removing, when the ignition is turned on the plunger should retract into its housing,
May 28, 2012 | Briggs & Stratton Briggs Stratton...
BRIGGS AND STRATTON MODEL # 91202 MANUAL TO FIX...DISCONTINUES RUNNING STARTS THEN IMMEDIATELY STOPS .INSTALLED NEW PLUG. NO CHANGE . GAS SUPPLY? HOW FIX
diaghram on the side of the carb facing towards muffler 4 screws when you take them out be careful there is a diaghram you replace, spring saver, and spring make sure they go back in the same order, whenever these engines or any horizontal with pulsa jet carb doesnt start it is usually because of diaghram I ran alcohol go karts and you have to drain the alcohol after you are done running karts and they will eat them up quicker than normal gasoline
Jun 23, 2011 | Sears Home Security
Briggs 3.5hp model 94212 0319E1 0206113A , on a lawn edger..unit unused /stored last nov 'til now..had gas stabilizer in tank..wudnt start..removed/cleaned carb..flywheel had rust on magnets/sanded, will...
Stills sounds like a carb problem to me. Did you make sure all the jets were clean and open? Some of these carbs have a main jet adjustment screw on the bottom of the carb, if yours does try opening it up a 1/4 turn at a time to richen the fuel mixture until it runs properly.
May 03, 2011 | Briggs Stratton IC Horizontal OHV Engine ...
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling...
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Oct 07, 2010 | Mtd Heavy Machinery
Craftsman 19.5 HP Briggs and Stratton engine. Will not start. will start with starter fluid and then stalls. It appears no gas is getting to the carb.
disconnect fuel line from carb and crank engine. NO FUEL-check in-line fuel filter, kinked line, trash or water in bottom of fuel tank. FUEL- gas is stale, has water in it, or carb has sediment in bowl, bottom jet or idle jet.or float could be stuck shut.
Feb 09, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Need carburetor adjustment
I had a similar problem with my 23 hp briggs. While cleaning the carb I found that the great gas we get today had eaten the seal around one of the jets in the throttle body causing it to fall out. Replaced the jet and now runs like a champ. Hope this helps.
May 05, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
470 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
