Question about Home
Can't put cistern back togeather - Home
  • 979 Answers
Do you have an assembly handy.
Posted on Jan 30, 2013
Toilet Cistern Sticking
Mechanism that releases and shuts off water should be checked if any part has disconnect or improper connection.
Jul 09, 2013 | Home
Twyford dual flush cistern
replace the whole control unit
There may be 2 problems
the small washer that shuts off the water flow when the level is reached may be swollen and not sealing properly
the section at the bottom has cracked at a thread level
so by replacing the unit you will eliminate both problems
to remove the unit, turn off the water tap, flush the system, holding the button down until all of the water has gone
remove the inlet pipe at the bottom of the cistern
undo the retaining nut under the cistern and lift the control unit out
there will be water in the bottom of the cistern so use old towels on the floor to soak up the water that will run out
Mar 23, 2017 | Home
Can a Grundfos pump fail, letting water out of a cistern?
Glad you got it fixed. Hope you didn't lose all your water in the process, we've been that way at times with our little system (can only afford 450 gal of storage with 650 gal transporter, no well).
Watch those strains on the pipes and make sure any further changes have good one way flow valves for this type system, expense doesn't look so bad when the alternative is being waterless!
Sep 01, 2012 | Grundfos Pumps Grundfos sqflex submersible...
I bought a mgf vvc off a friend and she sed the head gasket had gone so i replaced gasket and had head skimed and put it all back togeather again but car try's to start but thats it it has spark b
The fuel pump incorporates a inertia switch,The switch is next to the ECM,you may have triggered,reset it by pressing the red top.If that doesnt do it the pressure regulator uses a spring diaghram modified by a vacuum signal,remove the vacuum signal (just to start)
Mar 31, 2012 | MG TF Cars & Trucks
I replaced my coupler on my kenmore 80 series washer its all togeather on bottom but putting the pieces back togeather inside i forgot how to put it togeather.
what part are you stuck on?if you have the motor and pump back on next slide the frame back on,tilt the frame so the bottom front panel slides under the front frame part then drop the back down,,ssceck the back corners to make sure it locked in correctly,if you can pull out the side panel tilt the frame back and push the side panel in as it slides down,the sides usually line up,pop the metal clips back in place,plug in the lid switch harness,flip the top console back down and put in the two phillips screws in,plug it in and you should be good to go.
Jan 08, 2011 | Kenmore 15864/15862 Top Load Washer
Low-level Cistern - leaking from syphon back nut.
Assuming the seal washer is inside the cistern and there are no cracks in the cistern itself you could apply a silicon sealant to the seal washer inside the cistern.
Apr 04, 2010 | Plumbing
How do i put back togeather Hobart 300-d mixer
http://www.hobartservice.com/Parts/
Go to this page and click on Hobart Smartparts System. Select Food Machines, Floor Mixers, D300 and you will eventually find parts breakdowns.
Feb 25, 2010 | Hobart D300 Stand Mixer
Need instructions and Switch for twyford close coupled cistern
i presume with lid of u can flush toilet by pusshing switch with finger if so buttons must be spot on when replacing lid can be adjusted inside systern any probs get back
May 07, 2009 | Toto CST414M-51 Aquia Dual Flush Close...
Home Logo
21 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
