Model #sts2891 DVD player disc compartment won't
ric2k06850
  • 72 Answers
SOURCE: DVD recorder won't format discs or record
check what kind of blank dvd your dvd recorder accept.
Posted on Jun 07, 2011
  • 894 Answers
SOURCE: A dVD disc got stuck inside of the dvd player and
Well it might just be a little glitch with the dvd player to causse this problem so unplud the DVD
player from the wall outlit and let it stay unplugged for about 30 minutes to see if it fixed the problem and there is a small button on the rear of the dvd player that allows the disc's to pop out but you need a small flat head screwdriver to do that. Lastly if zero luck it will need to be repaired then. DOn't take it apart it could make thuings worse.
Posted on Aug 22, 2011
  • 159 Answers
SOURCE: dvd player won't read Widescreen formatted
Pull it's power plug out for 10 minutes then reconnect and switch on and see how it is then.
You may need to run Auto Set-Up again.
Posted on Sep 26, 2011
SOURCE: dvd won't play my dvd's. keep saying no
Memorex MVD2016BLK Progressive Scan DVD Player, Black (Electronics)
suddenly began having problems - stuttering, claiming 'wrong disc', stuck in standby and unable to get it unstuck....was torn between throwing it out the window and buying a special cleaning disc. Instead went to the Memorex site and found the reset procedure, which WORKED! Try this for your frozen MVD2016. Reset procedure:
1 Press and hold power button
2 Unplug unit from electrical source without releasing the button
3 Keep holding button for 60 seconds
4 release and reconnect.
5.watch your DVD.
Read more: http://wiki.answers.com/Q/How_do_you_fix_a_memorex_DVD_player_mvd2016blk#ixzz1giqZM7I7
Posted on Dec 16, 2011
  • 5 Answers
SOURCE: DVD won't read in DVD player
If it is scratched try putting toothpaste on them
Posted on Feb 22, 2012
LOST REMOTE
look down the back of sofa or recliner ,DEEP places
Sep 29, 2015 | Televison & Video
Vizio DVD/bluray player won't work
not clear in the video the detailed problem. ok if dvd player won't read cd tried to insert other cd's which not the same region. if still won't read you can use a disc cleaner to clean the laser lens which too dirty or sticky .
Oct 06, 2012 | Televison & Video
PET941D/37 won't load dvd says no disc
Some DVD players are proprietary. See if it will play in other devices. If it is a burned copy the player may not like that brand of DVD.
Apr 23, 2012 | Philips PET941D/37 9 in. Portable DVD...
Won't PLAY ANY DISC DVD PHILIPS model- dvp3126/98
Dirty or bad optical pickup in the player----bad: cheaper to buy another than replace the part.
Apr 17, 2012 | Televison & Video
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
Magnavox MPD850 dvd player won't play, only display no disc
The problem is in the laser pickup assembly, over time the laser becomes weak until it can no longer read the disc, but you can buy a DVD cleaning kit that might breath more life into the player, if no! cheaper to replace the DVD player.
Mar 17, 2012 | Magnavox Televison & Video
DVD drawer won't open after playing a film. Film plays fine, but now we can't get the darn DVD out!
Disc have something sticky attached on top (label ,specially rental discs') so when you try to eject disc get stuck on tray of spindle motor.Top cover need to be opened in that case in order to remove disc
Aug 23, 2011 | ESA E4000 DVD Player/VCR
The dvd player will not read the disc
If it won't read any disc you put in, consider getting a new DVD player, the eye is most likely gone bad. If it is only one disc that you can't read i would suggest a Scotch DVD Cleaner kit. Cleans and Repairs discs, helps prevent skipping and mistracking, and repairs minor surface scratches improving disc audio and image quality.
Jul 28, 2011 | Cyberhome CH-LDV1010A Portable DVD Player
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
