Drive E isn't opening
In my machine drive E isn't opening when i'm clicking instead notepad is opening & even regedit also has been disabled. I postulate some one to help me.
Karthik
  • 47 Answers
Your computer is affected with virus. Scan your computer with microWorld anti virus. There is also a script which can restore orignal registry entries.
Posted on Jan 27, 2009
I have a HP Deskjet 2480 and I just just installed it. When I try to scan I get the following error message: "The scan cannot be performed because another program or computer is using the networked...
This problem is related to Firewall settings. If I guess right, you've installed the Outpost Firewall with the Hp Software. Look at the right-side of the taskbar, you'll see a light-blue icon of Outpost Firewall. Right-click the icon and select "Disable". Now, open "My Computer" > double-click C:\ drive > Program Files > Agnitum > Outpost Firewall > locate and open "machine.ini" > Notepad will open up, now locate the line in the notepad text "EnableContentHandler=True", now replace the "True" with "False", and save the file.
Now re-enable the Outpost Firewall from the Taskbar. You'll be able to scan now.
Good luck.
Thanks for using FixYa.
Aug 15, 2010 | HP Office Equipment & Supplies
Tip
How to Protect Your USB from Receiving Virus
If you want to protect your USB from receiving unwanted files i.e. virus, worm, spy, trojan etc than you are at the right place.
What I'm gonna tell you is that how to setup your registry to stop a computer from saving files to your USB (It'll block all of them)
If you have windows XP with SP2, then you can disable the writing option to USB drives. This trick is very useful if you have virus in your computer and want to copy files from a USB Drive but don’t want to transfer virus to the USB. Follow the given steps to disable the USB writing option:
To edit the computer registry, first you should log onto your computer with administrative rights.
First click on Start button and type “Regedit” in Run option.
Here locate the location to:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControl
Here in right side panel, click right to create a key with the name “StorageDevicePolicies”.
Now in left side panel, select “StorageDevicePolicies” key, again right click to create new DWORD value then label it “WriteProtect”. Set its value to “1?. But again to enable writing, set its values to “0?.
Now close the registry editor
Note: If it won't work then restart your pc
Alternative way:
TO TURN ON THE PROTECTION
open notepad and copy and paste the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies]
"WriteProtect"=dword:00000001
Now save the file with the extension ".reg".
Double click on the file you just saved. In the pop-up window click YES and then OK.
That's it your USB is now protected
To TURN PROTECTION OFF:
"WriteProtect"=dword:00000000
That's it your protection is now disabled.
on Jun 27, 2010 | Computers & Internet
Tip
The DVD disc drive icon has dissapeared from my computer.
Try first disconnecting power cable for ten minutes, if computer is a laptop also remove the battery at the same time. This will
If there is a disk inside the DVD drive, remove the disk.
Try doing a system restore, here you get instructions for XP, Vista is similar: How to perform System Restore on Windows...
If all this does not work open the BIOS setting menu at startup and check if the DVD is detected.
In BIOS also ensure that the optical driver is not manually disabled, and that SATA port (if using serial ATA DVD) or PATA channel (if using IDE) is not disabled.
If DVD is not detected in Bios, and the DVD and/or PATA/SATA channel/port are not disabled, then you need to replace the DVD drive unit.
In that case check the DVD drive data and power connection. Eventually try extracting the DVD drive and putting it back in place.
IF DVD is detected in bios, then the problem is a corrupted Windows registry.
In that case go to Start menu, open the Run dialog box, and type Regedit in the Run box.
The registry editor will open.
lick the Start button, press run and type regedit.
Before doing the procedure, save a copy of the registry. Click File, then Export using the menu at the top of the Registry Editor Window:
  1. In the Registry Editor window open the HKEY_LOCAL_MACHINE folder.
  2. In the HKEY_LOCAL_MACHINE folder, open System.
  3. In System open CurrentControlSet folder
  4. Open Control folder.
  5. Open Class folder.
  6. In the Class folder open the folder {4D36E965-E325-11CE-BFC1-08002BE10318} .
  7. In the right panel click to select UpperFilters registry entry.
  8. Delete the UpperFilters registry entry from folder .
  9. Click Yes when asked to confirm delete.
  10. In the right panel select LowerFilters.
  11. Delete LowerFilters registry entry.
  12. Click Yes when asked to confirm delete.
  13. Close Regedit.
  14. Restart the computer.
on Mar 25, 2010 | Microsoft Windows Vista Ultimate Edition
Pen drive insert disk problem.
I think there is a virus that has disabled your pen drive please follow these steps to try and remove that disability for the pen drive.
1. Click Start, and then click Run.
2. In the Open box, type regedit, and then click OK.
3. Locate, and then click the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\UsbStor
4. In the right pane, double-click Start.
5. In the Value data box, type 3, click Hexadecimal (if it is not already selected), and then click OK.
6. Quit Registry Editor.
Hope you like my solution.
May 25, 2009 | Lexar 64MB FLASH MEMORY DRIVE USB 2.0 -...
My computer does not have a AutoPlay feature in it so I can insert and run my Cd-ROM PC games. It must have come with one but I can't find it.
Enabling AutoPlay on a data and audio CD (Windows XP)
  1. Open My Computer or Explorer
  2. Highlight the CD-ROM drive, right-click the CD-ROM drive and click properties.
  3. Click the AutoPlay tab. Within this section you will be able to specify all Windows AutoPlay features.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 26, 2008 | HP Computers & Internet
Tip
B.A. Regedit
Any of you that do websites and like to open .html and similar files in notepad to edit scripts, this is the coolest windows registry edit ever you can download the zip file with the .reg in it (run it and it automatically adds itself to your registry) or do it manually.
CODE
http://www.geocities.com/ichbindeingott5/winxp-notepad.zip
Manually: regedit and navigate to HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*\Shell add the key "notepad" it's default value should be "open with notepad" now, under "notepad", add the key "command" it's default value should be (with the quotes) "c:\windows\system32\Notepad.exe" "%1"
ok, exit regedit and go right click on ANY file...
you new option: Open with notepad.
I know this one works on XP and 2000, you can PROBABLY enter it manually on windows 9x, but I have not tested that.
I know maybe not everyone cares... but this was fun for me because I love tweaking my computer and it makes some web design stuff easier for me :D
on Dec 23, 2009 | Computers & Internet
Problem in Windows XP sp2
Type the following text in notepad
REGEDIT
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer]
"NoFolderOptions"=dword:00000000
Save this file as recover.reg [.reg is extension for regfiles]
Double click on it.
Log off is essential.
Mar 15, 2008 | Microsoft Windows XP Professional
Drive not open duble click, open with (error)
u disable autorun using this microsoft tools ,u download from using this link,it is jst 150 kb
http://www.microsoft.com/windowsxp/downloads/powertoys/xppowertoys.mspx
all the best ,prasanna
Mar 03, 2008 | Microsoft Windows XP Professional for PC
Windows xp service pack 2
Hi 1. Click Start, click Run, type regedit in the Open box, and then press ENTER. 2. Locate and click the following registry key: HKEY_LOCAL_MACHINE\System\CurrentControlSet\Services\CDRom 3. To disable automatically running CD-ROMs, change the Autorun value to 0 (zero). To enable automatically running CD-ROMs, change the Autorun value to 1. 4. Restart your computer. NOTE: This method disables automatically running CD-ROMs. If you want to disable automatically running CD-ROMs depending on the CD-ROM that you insert in the CD-ROM drive, you can press and hold down one of the SHIFT key while you insert the CD-ROM. This may help. Good Luck
Sep 12, 2007 | Microsoft Windows XP Professional With...
Problem in opening the registry window
try typing regedt32 in the run box and see if this works
Aug 19, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
David Payne
David Payne
