My panasonic typewriter only types 34 characters and then starts a new line...
I dont have a manual and I don't know how to reset margins and i just found this in my attic. halp. please. And all the help I had with margin reset from online is so confusing and i try it and the thing still just goes from side to side when i turn it on and then back to the middle. :c
  • 3,594 Answers
You most likely have the right margin set there and auto return on,
DickyO
Posted on Jan 25, 2013
  • 77 Answers
SOURCE: margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
Posted on May 26, 2007
SOURCE: reset left margin
Turn machine ON and return to what is set as the left margin. then press the MAR REL key (upper left side) one time and then press the BACKSPACE the number of times to get where you want to set the left margin.
Once you are at the desired position for the LEFT MAR then press LEFT MAR ONE time and it should be set OK.
Hope this solves your problem, sneaky pete
Posted on Jun 24, 2008
  • 3594 Answers
SOURCE: reset margins
Go to the R. margin, press but don't hold the mar rel key, space to desired location, press R MAR, DONE.
DickyO
Posted on May 27, 2010
Testimonial: "thank you! it worked!"
  • 3594 Answers
SOURCE: Need to change margins
Go to the stopping point, press but don't hold the margin release, space or backspace to the desired location press L. or R. margin key depending on which you are setting.
DickyO
Posted on Jul 23, 2010
SOURCE: L.C. Smith & Bros. typewriter No. 5 Margin setting
Make sure the carriage lock switch isn't on (presuming it has one). A carriage lock switch prevents the carriage moving when in transit (say, inside its case). These switches are usually located on the right hand side of the carriage, slightly underneath.
Gordon
Posted on Jan 12, 2011
Stops typing mid line
Type to the stopping point, press the margin release key space to the desired location, press R. margin key.
Jan 08, 2014 | Olympia Mastertype 3 Typewriter
I have a panasonic electric typewriter R330 and it only types about in inch then stops how can i fix it?
The right margin is probably set. Hit margin release( MR) and see if it types, if so reset your right margin. Also something could me binding or caught in the path. maybe a correction ribbon or something is blocking it.
May 30, 2012 | Panasonic Refurbished Kx-r330 Typewriter...
I know this is a long shot, but I want to increase the amount of characters I am allowed on my Panasonic KX R200 electronic typewriter. As it was given to me secondhand, I am short of the manual, and am...
There should be a margin release key. It may say MAR REL or Be 2 vertical lines with arrows or a key with mar rel printed above it that requires the use of the code key. When you stop press MAR REL space to desired R. margin mlocation press R. MARGIN KEY.
DickyO
Oct 16, 2011 | Office Equipment & Supplies
Dont know how to set margin on my panasonic T30 electronic typewriter
Go to the margin you wish to reset, Press mar rel key (some say MAR REL some just have two vertical lines and arrows), Space or backspace to desired location, press the L. or R. margin key.
DickyO
Sep 29, 2011 | Office Equipment & Supplies
KXR00 I have a panasonic elfec electronic typewriter r200 and I don't have a manual. I am having trouble setting the Left & Right Margins Regaards Lesley
I have a manual...
To clear margins and have do the following: depress the "return" key so the carriage returns to the left margin. Then depressed the "code" "tab clr" keys.
To set margins and tad do the following: clear your margins in tabs using the steps above. Depressed space bar until you reach the desired left margin. Depressed the "L. MAR" key... you're left margin is now set. Depress the "space bar" until you reach the first required tab stop. Depressed the "tab set" key... your first tab stop is now set. Repeat steps 4and 5 for each tab stop required on the writing line up 13 can be set on each line. Depress the spacebar to move the carriage to the desired right margin. Depressed the "r. mar" key. Finally depress the return key.
May 28, 2011 | Office Equipment & Supplies
Reset margins
DickyO
May 27, 2010 | Nakajima AE-710 Typewriter
k24674
