Question about Maytag Dishwashers
The spring on the door of my Maytag MJD 3005 dishwasher has failed. Can i fix it myself?
  • 76 Answers
SOURCE: maytag mjd 2005dishwasher
Try what my wife does. She uses the individually contained detergent/rinse bubble packs (tab packs). No messy granular detergent and easy to simply place inside the silverware basket. Your dishes should wash spotless, like ours. ZT3000 "Beta tester of "0"s and "1's"
Posted on Aug 19, 2007
SOURCE: maytag dishwasher mdb5000awa leaking
replace lower arm.
Posted on Jan 08, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Posted on Oct 06, 2008
  • 258 Answers
SOURCE: neff dishwasher door - think the spring has gone
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
Posted on Jan 15, 2009
SOURCE: maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Posted on Jun 25, 2009
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
We have a Matage dishwasher Model MJD.3000AAW. There is an error message: E4. What do we need to do?
Hi, the E4 error means the water heater element does not work properly or the filter mesh is blocked. Most likely the heating element burned out/thermal fuse or Clean the filter mesh to resolve the problem.
Jun 22, 2011 | Maytag Dishwasher
My maytag MJD 2005 is getting partway through it's wash then tripping the house safety switch or circuit breaker
The most common problem that would make that happen is the motor going bad...
heatman101
Apr 30, 2011 | Maytag Dishwashers
Maytag mjd 2005 when started on normal gives a once-every-two-seconds "wash". Seems to pump out some water each time. When turned off and on again 'normal' button lights and the same thing happens. Will...
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
Maytag MDBH950AWB handle/latch failed.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Neff dishwasher door - think the spring has gone
Oct 16, 2008 | Neff 24 in. S5456 Built-in Dishwasher
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Door open and closing problem
My dishwasher model DU3003XL0 has a similar problem. It happened yesterday. I had opened the door all the way, and then I heard a loud clunk sound. I suspect it is the spring mechanism in the door, and am ordering new springs, and hope to fix it myself.
Wish me luck.
Apr 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag mjd 2005dishwasher
Aug 19, 2007 | Maytag 24 in. MDB9750AW Dishwasher
Dishwashers Logo
48 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
