Question about Sony RM-VZ320 Remote Control
Can't find On Demand button for Verizon FIOS - Sony RM-VZ320 Remote Control
Can i use a Bright House Surfboard Router for Verizon FIOS Internet?
If you can reset all the parameters, however if you know all the info I would suggest that you use something like a Belkin. You need the IP "name" for you, the connection password, and you really need to know what you are doing.
The only ISP that cannot easily be used with another modem is Sky as they deliberately use a different encoding. Yet again another reason NOT to use sky, it is difficult to monitor, and to use other equipment.
Aug 02, 2014 | Motorola SURFboard Computers & Internet
I can't seem to remotely connect and view my lorex cameras. What am i doing wrong...it was working fine till I got Verizon FIOS
You may need to reopen the ports necessary for the Lorex to be available for remote viewing. You should be able to look at the function on the Lorex menu to get the port numbers, then call Verizon to have them forward the ports. Without port forwarding, your video stream is being blocked at the Verizon FIOS Modem.
Feb 01, 2013 | Lorex Home Security
Can't get full screen on Vizio VA19LHDTV10T
This is either due to some incompatibility or change of format of picture. Also the color system should be same like PAL/SECAM etc.
Aug 03, 2012 | Vizio VA19LHDTV10T 19 in. LCD TV
Verizon fios remote codes for samsung receiver
I have the Samsung Sound Bar WS1R model. I tried all of the Samsung codes; TV, audio receiver, and audio amplifier. The DVD code 3918 worked for my Verizon FiOS remote. Program it to your AUX button and it will control the volume while your other buttons; channel, menu, etc work the set top box. I hope it works for you too!
Feb 20, 2010 | Samsung Audio Players & Recorders
Windows Networking Issue
FIOS and DSL use different modems and or gateway devices. Sounds like you were using a DSL gateway device with networking setup and when you moved to FIOS, the tech did not duplicate your network on your new FIOS gateway. OR you had a 3rd party router e.g. Linksys that was removed from the setup when FIOS was installed.
Either way, Verizon is who you should contact. Just tell them your network went down after you moved from DSL to FIOS. Dont mention Microsoft or Livewebtv.
Sep 21, 2009 | Dell Inspiron 1525 Notebook
Picture goes bad when playing Verizon Fios DVR or On Demand
I had issues when I set an SD override for the box, it would sometimes display as bad input when switching to HD content(as well as display all menus in SD even with HD mode in settings.) Turning that off in settings (also turned off "modes" which has no description) stopped it and gave me guide/menus in HD.
Apr 04, 2009 | Sharp Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Sony RM-VZ320 Remote Control Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
