Question about Geha Primo 2700 (Cross-Cut) Shredder
Officemax shredder overload light won't go off
OfficeMax Shredder OM01288 Manual
Camille what do you need to know about your shredder?
they are pretty universal and pretty standard in what and how they do it. please share a little more information?
Aug 11, 2016 | OfficeMax Office Equipment & Supplies
Shredder doesn't shred.
Shreader wont cut will reverse ok
Dec 17, 2012 | Office Equipment & Supplies
My OM02750 overload light goes on even with a single sheet? How do I fix this?
I have a OM02750 out of warranty exhibiting the same symtom. I opened the unit (power disconnected) and found some bad solder joints on the bottom of the circuit board. Re-soldered them and now it works.
Nov 17, 2010 | OfficeMax 0M96431 Shredder
OfficeMax (0M96431) Shredder\r\n ATTENTION LIGHT STAYS ON SOLID -... Answer Failed: retry attention light stays on solid - won't take paper in or go into reverse - have emptied bin, cleaned... (More)...
Have the unit serviced by a office machine technician. This sounds like there may be a problem in the gear drive, which you will not be able to access or repair.
Aug 14, 2010 | OfficeMax Office Equipment & Supplies
My OfficeMax shredder OMO 1288 wont stop running!
your auto insertion sensor (electric eye) is probably dirty or malfunctioning. clean or replace the "eye" or disable auto-reverse on jamb feature.
Apr 03, 2010 | OfficeMax 0M96431 Shredder
Office max shredder, says bin full but its not, only half full
I had the same problem. I found that the sensor on the shredder is light sensitive. The viewing window in the bin was letting too much light in and was triggering the bin full light to turn on. I covered the window with a piece of paper and then restarted the shredder.It worked fine after that.
Feb 08, 2010 | OfficeMax 0M96431 Shredder
My shredder motor will run but not accept anything to shred. Any suggestions
probably has a broken gear, don't know if parts are available for it. i would try calling officemax.
Nov 11, 2009 | OfficeMax 0M96431 Shredder
I want to register warranty for om00733 shredder
officemax.com or mail in the card it came with
Apr 03, 2009 | OfficeMax 0M96431 Shredder
Geha Primo 2700 (Cross-Cut) Shredder Logo
20 people viewed this question
Top Geha Primo Office Equipment & Supplies Experts
k24674
Are you a Geha Primo Office Equipment and Supply Expert? Answer questions, earn points and help others
