Printer is giving the error that the printer in queue,but their is no printout
  • 47 Answers
Your spooler has been exhausted. Try to install a fresh copy or re-installing printer will fix it
Posted on Jan 27, 2009
  • 495 Answers
You can use the following commands:
1) Open command prompt(Press windows key + R)
2) net stop spooler
3) net start spooler
Restart your device once.
Document sent to printer doesn't show up in print queue. Test page goes to queue, but gets "error printing". Troubleshooter doesn't find anything. Driver is newly installed. What can I do to fix?
Is the printer selected on your computer?
Is it plugged in and switched on at the power point?
Is the printer turned on at the printer?
Does the light come on on the printer?
If all the above happens then :
Look up changeing printers in "help".
Because you did not give any information about your computer operating system I can not give any further details.
Feb 23, 2016 | Epson Stylus CX8400 Series
49.000ff error
49.xxxxxx errors can be caused by various things. 1st thing to do is clear the print queue. A corrupt print job in the queue will give you the error. Disconnect the network cable and power cycle the printer.
Could be a firmware problem. Upgrade the firmware. Could be bad memory. Might be bad formatter board.
Try powering off the printer and rebooting the computer. Power up the printer, if no 49 error, you should be good to go.
Jul 21, 2014 | HP COLOR LASERJET CP 3505 N PRINTER
Canon goes on offline. mac
HI,
you better go to printer and faxes,right click on canon printer and select USE PRINTER ONLINE AND
once again right click open the printer and cancel the prints jobs which was already in queue.
then put Refresh button and get the printout smoothly.
May 27, 2011 | Canon Office Equipment & Supplies
Printer will not stop printing-just replaced cartridges
hello, it seems that you many pending printouts or they are in queue, double click the printer icon on the task bar, and then select the file in queue and CANCEL... turn off your printer for about a minute and turn it on, just repeat the process.....
Mar 12, 2010 | HP DeskJet F380 All-In-One Printer
I'm having trouble making printouts, from the computer. I keep receiving "delete-error-offline" messages, in the big "print" box. I have no idea why it's doing this or what to do about it. All I want to do...
Printer (and print queue) is in the middle of being delted but cannot be done until the printer is set back online.
Start > Settings > Control Panel > Right-Click Printer > Use Printer ONLINE > Restart computer and try to remove printer again
-=/ Daft Tech /=-
Oct 23, 2009 | HP Officejet 4315v All-In-One InkJet...
Document goes to the print queue, then errors
To start with You check the data cable is properly connected to your printer than you open the printer dialogue box and remove the documents pending in the queue and retstart the computer and before giving the print command select the printer that you are going to use(if more printers are connected to the computer).if all this does not work i suggest you to reinstall the printer after uninstalling it
May 27, 2009 | Office Equipment & Supplies
Hanging print queue on Canon iR2200-3300
my ir2200-3300 canon printer m/c ip adders change automatically in 2-3 days pl. solution my problem?my email ID sudesh_trivedi@yahoo.co.in
Nov 20, 2008 | Office Equipment & Supplies
Prin queue problem
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Aug 31, 2008 | HP DeskJet F380 All-In-One Printer
59 people viewed this question
jasbo
jasbo
