Question about Tally Line Matrix T6090 Printer
Need part numbers to order parts
Paper motion sensor faulty
The problem is with sensor calibration,activate the TECH-ASSES
mode pressing ENTER + LF switch simonteniously,than calibrate the paper motion .
upadhyay
 girish
Posted on Oct 15, 2007
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
Go to appliacepartspro.com.
Posted on Jul 20, 2007
Need to replace plastic rod that feels paper feed & transfers motion to start swich for shredding.Parts diagram would help with part numbers.Thank you
Fixya has no parts or parts lists for things, only people trying to help. Find you make, model, and serial number off your machine and look the company up on your internet search engine (Such as Google or Amazon).
God bless your efforts.
Feb 22, 2016 | Office Equipment & Supplies
Brother mfc8440
yes there was a sensor switch, which can be broken and faulty that needs to be repair or replace.
Sep 07, 2008 | Office Equipment & Supplies
Tally T6212 paper motion fault. Replaced top tractor with paper motion sensor. Found motor not turning at all. Replaced paper motor and power distribution board but its still not turning motor and not...
Did you check the different voltages coming (or should come) out of the power supply?
When a display works, will not implicate the power supply is working correct. It is too long ago I worked with these kind of printers, but I don't think the stepper motors need a capacitor. The caps can be defect, and can cause the loss of one or more output voltages.
Jul 09, 2014 | Office Equipment & Supplies
Service call C0650
Error code C0650 Konica Minolta bizhub 160 Black
Faulty scanner home
position sensor.
• The scanner home position sensor (PS100) does not go
from HIGH to LOW when the scanner motor (M4) is energized
for a given number of steps after the sequence to
bring the scanner back to its home position has been
started at the end of a scan motion and during re-shading.
from LOW to HIGH when the scanner motor (M4) is energized
for a given number of steps after a scan motion has
been started at the end of a PS100 home check scan
THANK'S
Jun 26, 2013 | Konica Minolta bizhub 160 Black Drum...
Paper moving fault
If the paper is moving freely in the printer and you are not experiencing any paper jams etc it may be possible the error is being indicated falsely.I would recommend firstly to ensure the tractor feeds on the printer are clean and free from a build up of paper dust etc. As the paper motion sensors are located on the tractor feeds.
If after the printer is cleaned the error is still see the problem may be related for a setting for the Paper Motion Threshold in the printer. this is the point at which the printer detects an error. This value is dependant on a number of factors; Paper Type, condition of the printer etc.
  1. Put the printer OFFLINE
  2. Press and Hold down LINE FEED and ENTER until TECH ACCESS ON is displayed (approx. 5 seconds)
  3. Press the MODE button
  4. Press the DOWN ARROW until TEST is displayed
  5. Press button 1
  6. Press the DOWN ARROW until DIAG is displayed
  7. Press button 2
  8. Press the DOWN ARROW until PMOTTHR is displayed
  9. Press button 3
  10. Press the Either ARROW to set the value to 170 and then press ENTER to save the value.
Once you have completed the above sequence press and hold down the LINE FEED and ENTER KEYS to turn tech access off, you can then test the printer. If the above does not clear the message try increasing the value further.
If the problem persits you may have a faulty paper motion sensor.
Nov 23, 2011 | Tally Line Matrix T6050 Printer
All my tractors are okay but my printer still giving me a paper motion error?
you need to clean paper motion sensor first,
check its connection on logic board
clean the connector of sensor,
if you can then please post u r problems with printer model then i can explain it more.
Mar 21, 2011 | Tally T6218 Matrix Printer
C020 ON ESTUDIO 4511
There's a paper jam while the paper is trying to exit the printer. The definition of the error is saying that the leading edge of the paper has reached the exit sensor, but the other end of the paper hasn't yet. Because it's jammed...
It could just be a regular paper jam that needs to be cleared, or it could be a faulty exit sensor or a faulty registration roller, or registration sensor. I'd try clearing the jam thoroughly, and then try printing again. If it's a recurring error then you may need to call someone to replace a faulty part...
Jan 27, 2011 | Toshiba e-STUDIO 4511 Printer
Error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
Tally Line Matrix T6090 Printer Logo
198 people viewed this question
Top Tally Office Equipment & Supplies Experts
Alexey Krenvalk
Alexey Krenvalk
Clive
Clive
Shawn DuRee
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
