Question about Kohler Forte entertainment remote valve sink faucet with Sidespray ...
Kohler 1048033-5-d faucet leaking, can't remove the handle even after removed the small screw
  • 148 Answers
SOURCE: Kohler Forte Single Handle Faucet Leaks
you will have to replace the ball assembly with a repair kit
1 turn the water off under the sink (hot and cold)
remove the handle ( you may need an allen head wrench to remove a hex screw or you may have to take a channel lock pliar and unscrew achrome
nut over the ball mechanism
after the handle comes off there is usually some type of lock nut that you must remove to remove the ball mechanism
remove the ball (usually chrome or brass(ther are usually little springs and rubber washers under ball
take ball and washer to ACe or lowes and match the pieces (usually sold as a kit
follow directions and installl
turn water on and pat yo!ur self on the back !
Posted on Jan 05, 2009
  • 34 Answers
SOURCE: Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Posted on Feb 05, 2009
  • 5 Answers
SOURCE: Replaced single handle shower faucet with rite
u hve to adjust the temprture ring i think u put it all the way so u lock it ,
Posted on Dec 27, 2009
  • 25 Answers
SOURCE: how do I remove the handle from a Fairfax(R)
U have to get a handle puller from a plumbing supply store. My husband is a plumber. he says that's all u need to do!
Posted on Jan 04, 2010
  • 83 Answers
SOURCE: Kohler Finial K-310 Widespread Lavatory
should be able to turn the bottom piece under handle and it comes off along with handle..dont think theres a little "cap" that comes off at top of handle..but mite try prying it off it just has an o ring holding it in place and screw will be under that
Posted on Nov 25, 2010
How do you remove the lever of a kitchen kohler clairette faucet, it seems to be stuck
On the front of the faucet handle, there is a small plastic cover with an emblem on it. Gently pry it off with a sharp knife blade. Next you will notice a small "allen" screw head. Remove it by turning it counter clockwise until it's loose. (lefty loosie - righty tighty) Lift the handle straight up to remove.
Jun 23, 2014 | Kohler K-15160-7 Coralais single-control...
How do I get the handle off so I can tighten it up to eliminate wobble
look for a small hole in the bottom of the faucet handle,, it holds a allen type or a slotted screw for retaining the handle,, ( more than likely on a moen or Kohler its going to be a allen head,) ,, remove that and your handle should come off
Sep 16, 2011 | KOHLER Forte Widespread Lavatory Faucet...
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
Dripping bath faucet circa 1985. Can't ID model but appears to have 2 screws holding front of casting to main body for disassembly . Faceplate is square in shape and black in color HELP!
  • 1 Close the hot and cold water valves in the cabinet beneath the sink to shut the water supply off to the bath faucet.
  • 2 Remove the bath faucet's handle to access the valve cartridge. The faucet handle is removed by first detaching the handle's insert cap using the tip of a screwdriver or utility knife to expose the handle screw. Remove the handle screw with a Phillips screwdriver, then pull the handle off the valve cartridge stem.
  • 3 Loosen and remove the cartridge valve nut with an adjustable wrench. Some faucet models retain the valve cartridge with a snap ring and are removed with snap ring pliers.
  • 4 Pull the old valve cartridge out of the bath faucet base, using pliers.
  • 5 Insert the new replacement valve cartridge into the faucet housing and replace the nut or snap ring removed in Step 3, using an adjustable wrench or snap ring pliers.
  • 6 Reinstall the faucet's handle onto the valve cartridge post, then secure the handle's screw, using a screwdriver.
  • 7 Replace the insert cap into the handle to cover the handle's screw hole.
  • 8 Turn on the hot and cold water valves beneath the sink to restore the water supply.
  • Jun 15, 2011 | Kohler Plumbing
    How do I open the body of K-10430 apart to replace the valve cartridge kit that's leaking
    The handle has a allen set screw loosen that until the handle comes off then the bonnet nut will unscrew revealing the bonnet cap and washer the cartridge should be under that most kohler's require a special tool to remove cartridge(turn water to faucet off prior to working on faucet,also note how everything is removed it needs to be replaced in same order especially the cartridge,also you should use plumbers grease to coat all seal when replacing everything).
    Jun 03, 2011 | Kohler Model 10430: Fort® Single-control...
    Leaking from handle, how does the handle come off?
    There is a small set screw on the handle it may be covered with a small cover that needs to be removed to reveal the set screw.
    Mar 04, 2011 | Kohler K-10270-4-BV Forte Two Handle...
    Hot water handle hard to turn.
    depends on which model faucet you have...
    some handles are removed by removing a screw in the top of the handle hidden under a small decoritive cap
    some handles are removed be removing a set screw using an allen wrench in the side of the handle usually under a small rubber plug
    Jul 07, 2010 | Kohler K-16102-4-AF Revival Widespread...
    Water leaking at handle when turned on
    1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
    First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
    If not please go to step 2 in removal of stem
    2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
    May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
    I have a single handed Kohler Vinnata kitchen faucet that is leaking from the handle. Cartridge has been replaced and hasn't stopped leak. What now?
    turn off water remove handle and check retaining nut remove cartridge and check o-rings for damage or replace replace and tighten cartridge check for leak
    Nov 04, 2009 | Moen 7437 Chateau Single Hole Kitchen...
    Nov 12, 2008 | Kohler Forte entertainment remote valve...
    Kohler Forte entertainment remote valve sink faucet with Sidespray ... Logo
    171 people viewed this question
    Top Kohler Plumbing Experts
    Mike
    Donni Steen
    Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
