Question about Proform Nordic Track Elliptical Resistance Motor 184141
No resistance on my weslo momentum 630 elliptical
Pushing the arrows for resistance and nothing changes
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Resistance on elliptical acting weird
1) tight the bolts tension for magnet and clean very well. and proof..if the fail
2) go to test the magnet, use again the magnet from your refrigerator magnet, for attraction and repulsion. If do not pass the TEST replace the magnet in any Hardware such home depot, etc.
God bless you
Posted on Aug 30, 2012
What is the problem?
It sounds like a power supply regulator board problem. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 26, 2014 | RCA L22HD31 22 in. LCD HDTV
Weslo Momentum 7.0EX Elliptical weight lmit
Dear Sir:
You must read your instruction manual, but the promedium is 250lbs for
elliptical machine.
By that reason Read CAREFULLY your instruction manual.
If you do no have go for free download: www. fitness.manualsonline.com
sincerely. God bless you.
May 03, 2012 | Exercise & Fitness
Need to replace the drive belt on my Weslo Momentum 610 elliptical
Which version of the Momentum 610 do you have? Here is a drive belt for the WLEL14051 and WLEL14052. There are a few slightly different model numbers for the Momentum 610 listed here that do not have drive belts listed in their parts list, so it is possible that the first link works for those two, but I could contact them to make sure.
Apr 30, 2012 | Weslo Exercise & Fitness
Need a weslo momentum 710 elliptical manual
go www.fitness.manualonline.com or www.iconservice.com or www.retrevo.com
Apr 18, 2012 | Exercise & Fitness
Weslo Momentum 950lost resistance. Servo motor for C-magnet works fine. What else might I look for?
Dear Sir:
This would be a problem with your 1) tension motor 2) pluggin bad contact.
3)mechanism need a service
Apr 17, 2012 | Exercise & Fitness
My weslo momentum 7.0 ex elliptical machine display stopped working. It won't power on even with new batteries.
Removethe bolts or screws securing the console to the upright assembly. Lift theconsole and confirm that the cable connections are secure. Remove the coverfrom the console's battery bay and install a fresh set of batteries. Replacethe battery cover.2
Detachthe ends of the pedals from the crank axles. Remove the left and right discshields and side shields. Inspect the interior of the base unit and locate theflywheel.3
Inspectthe flywheel as it turns. Locate the magnet installed on the flywheel. Turn theflywheel until the magnet passes in front of the nearby reed switch. Loosen thescrew securing the switch in place. Rotate the switch to reduce the gap betweenit and the magnet. Tighten the screw.4
Replacethe left and right disc shields and side shields. Reattach the ends of the pedalsto the crank axles.
ernesto cuadramanagua, nicaragua
Mar 07, 2012 | Exercise & Fitness
How do I fix my crosstrainer, magnetic resistance has stopped working
This happened to me and I took the wheel mechanism cover off to discover the tension motor cable had come out of it's pulley guide- so there wasn't enough tension left in the cable to pull it away from the wheel- quite an easy fix for me- hope it is the snake for you!
Feb 15, 2012 | Exercise & Fitness
I have a Vision Fitness T9600 and when I start it, it doesn't go any faster than .5 mph. When I push down on the arrow keys, nothing happens. The elevation doesn't repond to the pushing of t
You must measure the 8' 12 vDC Voltage to display from the terminal from Controller board motor.
If there are the Console Board is faulty. However tight very well and cleaned it with electronic spray cleaner.
If there are NOT, the controller board motor is faulty, some IGTBs are faulty. REPLACE
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
How to Determine If Treadmill Console Is Broken
Nov 26, 2017 | Exercise & Fitness
Udraw spongebob
Hold down the up arrow and it will pop up all the brush sizes
Dec 27, 2011 | THQ Udraw Studio for Nintendo Wii
Proform Nordic Track Elliptical Resistance Motor 184141 Logo
46 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
