Question about Candy Ovens
Candy f2550x convex oven not reaching high temp
Our Neff U1421 double oven has a problem with tripping the main fuse when the main oven reaches 180 degrees. The oven is in manual mode not using the clock timer, can you throw any light on the proble
yes i know exactly whats wrong, one of your high accuracy temp sensors will have gone.
these tell the thermo what the sides & top of the oven temp is.
unscrew the oven from the base unit & pull it out, take the top off & you'll see them little round cylinder looking things with 2 wires coming off them(see link for pic) there screwed to the shell. the one that will have gone will no doubt have burn wires, or connections.
their sometimes called temp switch sensors
http://www.bi-metal-thermostat.com/photo/pl1619154-ip00_ceramic_bi_metal_thermostat_temperature_controller_for_micro_wave_oven.jpg
Sep 29, 2014 | Neff U1421 Double circotherm Electric Oven
Kenmore oven shuts off before preheated
On any gas appliance there is a high and a low limit temp stat which could be indipendant or on the gas valve it's self, that is faulty.
When the oven reaches temp, it cuts out. sounds like faulty over heat stat.
Mar 21, 2014 | Ovens
Volume control candy oven timer
Switch off the oven, leave for 5 seconds and switch it back on.
Candy Customer Services asked for over £100 to have an engineer sent to my house, which I refuse as I thought the oiven was good.
I had to switch off all the electricity in the kitchen but after this 'reset' the oven turned to the normal 'high' volume.
Jan 12, 2010 | Candy Ovens
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Oct 29, 2009 | Whirlpool AKZ159IX Oven
Lock light flashing after cleaning. Will not
OK, what has happen here is, the actual temp sensor has failed during the cleaning process, this has cause a temp that reached a dramatic high range(above 915F-930F). At these temps, there will be major damage that will weld the contacts on the door lock switch mechanism and control board.
If actual over temperature condition occurred: Look for welded relay contacts. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred: Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective. Check door lock switches for faults as well(welded contacts and burned wiring harness)
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Sep 23, 2009 | GE Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Aug 04, 2009 | GE Ovens
Are the units indicated for the oven in Celsius?
Unless it is a very old oven then the temp markings are in Celcius, as is common to most ovens today.
Please rate my comments.
Thankyou.
Jul 15, 2009 | Candy Ovens
Replaced oven heating element, now trips electric
Disconnect the new heater and try it again , if it still trips then your problem is elsewhere, if it does not trip, then it points to the new element being faulty.
If it is fan assisted make sure the fan is running o/k.
Hope this helps.
Please leave feedback.
Thanks.
Dec 08, 2008 | Ovens
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
Ovens Logo
Top Candy Ovens Experts
ashburton
ray gallant
Gaark
Are you a Candy Oven Expert? Answer questions, earn points and help others
