Question about Maytag PYE2300AY Electric Dryer
There's a slight burning smell coming from the dryer drum.
There is a burning smell coming from the drum. The lint screen and dryer duct are clean. The smell is present with or without the lint screen and clothes in the drum. I took the front panel off to locate the smell. It only appears to be in the drum, not the lower section with the heating unit, although the air/smell would flow from the heating unit into the drum and not out the front opening. The inside of the dryer unit (around the heating unit) was very dusty, but there was no obvious dirt on the heating coils. The dryer is 14 years old, but works great except for the new smell.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Posted on Jan 22, 2013
  • 3 more comments
  • Don W. Jan 23, 2013
    The felt gaskets on the front and the back of the drum look good. I couldn't find anything that might be between the drum and the housing. I did notice that the drum belt is shredding and hanging on by less than 1/8" think in some parts. I took the thermostat and the heater out and checked the continuity. Heater was fine. The thermostat was fine at room temp but only turned off at 270 when it's rated at 200 degrees. Would the belt or the thermostat be the problem? I going to put it back together and check the air flow. the vent is clear, but I want to see if the blower is working well enough. need to do it tonight while it's still 5 degrees, supposed to be -8 degrees F. tomorrow morning.
    the air flow coming out of the exhaust was good. Also, I didn't notice the burning smell as much outside at the exhaust.
  • Vince Pilgreen Jan 23, 2013
    I would think the belt would be the problem here. When you said it was coming from inside the drum I did not think it was the belt. But since you smell it in the house and not outside that tells me it really is not in the drum. It is very likely the belt is slipping and heating up. It sounds like you are needing a new belt regardless. I would do that first.
    Thanks Vince, I think I found the smell when I took the dryer apart to inspect between the drum and the housing. One of the blue tumbler bearing kits in the front is worn all the way thru. It looks partly melted. I order the part, hope it works.
    It sounds like you kept looking until you found it. Since the drum was not turning with the ease it should have that may be what has shredded the belt also. I would suggest while you have everything torn apart you go ahead and replace that belt. Good luck!
SOURCE: Maytag dryer: pye2300ayw
I had the same problem last month. My heater element broke in two places. This created an electrical open that prevented the heater from functioning. I replaced the heater element and my problem was solved.
In order to check your heater element: With the machine unplugged, disconnect one wire to the heater element and then use an ohm meter or multimeter across the heater element lugs to read resistance. Infinite ohms = open circuit.
Posted on Nov 04, 2008
SOURCE: Maytag electric dryer INTERIOR ehaust vents have come apart and are obviously not exhausting hor air through the side opening.
take of screws holding door on, and screws opposite door hinges. the front will know be able to take off. just unplug first.
Posted on Nov 07, 2008
  • 5 Answers
SOURCE: Dryer stopped working after 2-3 minutes
Go out and buy you a duct cleaner. It looks like a dome shaped broom. Clean your duct from the outside and if you can from the inside. Also if you use fabric softener sheets, clean your lint filter with soap and water periodically (every 3 months would be optimal) to remove the clear residue the dryer sheets can leave behind.
Good Luck!
Posted on Apr 13, 2009
marka19
  • 1430 Answers
SOURCE: drum rotates and only occasional heat
The problem is the dryer coils are failing. They tend to fail as they heat up. These are inexpensive and easy to replace.
There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Posted on Apr 09, 2010
richroth
  • 9472 Answers
SOURCE: Maytag Neptune Dryer runs for
Check for lint buildup on the "Hi Limit Themostat" located above the heating element. There is a thermostat kit that you can get and replace all three at once. This will make sure your dryer runs safe and up to its required operational limits. The lint buildup may cause the thermostats to get out of the tolerance. Here is a link to the thermostat kit.
The FixYa Team
Posted on Dec 26, 2010
My BaByliss blow dryer smells like burnt when I turn it on and I seen like a spark is it going to work anymore
DRYER SMELLS LIKE BURNING:
Answer:First, Stop using your dryer until this problem is resolved. This is a fire hazard and could cause a fire.
Your issue is more than likely alint build up problem. The lint that comes off of your clothes as you dry them becomes trapped in the dryer itself and in the venting duct that connects from the back of the dryer to the wall.
The first thing to do is todisconnect powerby unplugging the dryer cord from the wall. Slide the dryer away from the wall slowly.Remove the hose ductthat attaches to the back of the dryer. Look inside the hose duct and if you see heavy lint build up, that is most likely your problem. If you have a shop vac vacuum or similar, use the long wand attachment tovacuum out the lintthat is in the duct. The best way to do this is to completely remove the vent duct from the wall and dryer.Vacuum the inside of the ductto clean it out. Alsovacuum in the vent hole in the wallwhere the duct attaches to the wall and remove any lint that may be blocking air flow. Put everything back together and test your dryer to see if the burning smell has been resolved.
NOTE: There may be heavy build up of lint deep in the wall. You can purchase aDryer Vent Cleaning Kitthat may make your job of cleaning the vent much easier. However, it may be best to call a Dryer Vent Cleaning Company as they have the equipment that is needed to remove all lint in the wall that could cause a fire. We know everyone wants to save money and "do it yourself" but when it comes to safety, money should not be an issue.
If the burning smell is still present, you cantake the dryer apartandtry vacuuming out any lintthat may be built up on the inside of the dryer. Do a search for your dryer model name and number onGoogleto see how your particular dryer model is disassembled. If you are not comfortable taking your dryer apart then it is advised to call an appliance repair company as your issue can cause a fire.
There are other reasons for your dryer to have a burning smell. There could be an electrical issue inside your dryer. This may mean that a certain part or electrical board is going bad or is bad. Another common reason for this issue is something is near the heating element inside the dryer and causing the burning smell. If you have an older clothes dryer, it may be possible that the components are past its life span and it is time to purchase a new dryer. If you want your dryer to be looked at by a professional, it may be time to call an appliance repair company to come out and check your dryer.
There are plenty of videos that can help you to determine what may be wrong with your dryer. There are a few videos below that may assist you with troubleshooting and disassembling your dryer.
The belt
In some dryers, a belt turns the drum. This belt can slip off, which can cause it to start melting. Because it is usually made of rubber, it will then produce a very strong, unpleasant burning odor. If your drum is not turning smoothly or properly, and you notice a bad burning smell, your belt is probably damaged.
THE MOTOR
Dryers have motors, and as they age, they can burn out just like any other motor. This causes a very strong burning smell, and your dryer will either not run at all, or it will run poorly and with a lot of noise.
Read more :http://www.ehow.com/list_7173741_causes-burning-smell-dryer.html
Causes of Burning Smell in Your Dryer eHow
Apr 22, 2016 | BaByliss Dryers
Burning smell however, motor runs fine, belt looks good, element heats up, vent is clean. i'm at a lose
Dryers collect lint.
Some, like the one I fixed last month, had a whole wastebasket full of lint inside it where you could not get it out without tearing the whole dryer apart.
I\'m suspecting either lint or some other foreign object is burning.
For your safety, please take it completely apart, or get someone else who knows what they are doing to do so, before you have a dryer fire.
( P.S. The last dryer I just fixed had a worn out felt on the drum, allowing the blower fan to suck lint past the screen and fill the inside of the dryer with that lint.)
Be blessed.
Apr 16, 2013 | Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
My dryers smells like its burning and inside when drying gets really too hot. The air vent going outside is clean. I took off the casing and cleaned the inside of the dryer. The belt seems like its ok....
Lint burns quickly and rarely holds a flame long enough to cause a fire hazard. Metal burning would probably indicate friction on spinning metal, like the motor shaft, or the drum rollers. Plastic/rubber are usually parts that are intended to wear, and can usually be replaced.
Along with the belt, you should also check the idler pulley that takes up the slack in the belt, as well as any drum rollers or nylon glides on the top of the dryer door where the drum rides. Metal, plastic, and lint have distinct smells, and you should be able to determine which one(s) you have by smell.
Lint is a common burner in dryers, and it seems you've looked in some of the obvious places it can accumulate. When you have the cover off, pay special attention to the burner area, and any ducts from the lint screen area. Also, any gaps in insulation where air flows could cause hot spots in the unit. If you can see the flame while its running, make sure its size is not excessive. Flames should not be too low or too high, and should not escape the burner housing.
If you notice soot buildup, your gas/air mixture is off. If you've switched from natural to bottled gas or vice-versa, you may need to swap the burner orifices to match the different pressures of the gas fuel.
May 18, 2011 | Kenmore 74632 Gas Dryer
The dryer smells like it is burning. It is only 2
Cleanout the exhaust duct ... from the lint screen to the outside vent cover.
Mar 03, 2010 | Dryers
SMELLS LIKE ITW BURNING
I highly recommend opening the dryer by removing the front panel.
Unplug the machine, remove the front cover and be prepared to vacuum out the lint build-up inside the housing of the dryer.
Also clean the exhaust duct of lint buildup too.
Sep 12, 2009 | Whirlpool Dryers
Burning smell in in dryer
Take a flashlight and look inside the drum at the holes on the back end of the drum where the hot air comes in. On mine, there is an air deflector on the back side of the drum and the space between this deflector and the drum was packed with lint. The lint blocked about half the holes. I had to take the drum out, remove this deflector by removing four screws inside the drum then cleaning out the lint. The lint was all brown and scorched.
Jun 07, 2009 | Whirlpool LER4634J Electric Dryer
Burning smell when it is on. Dryer still works
Make sure the duct to outside is not obstructed. Number one starter of fires with dryers.
Apr 15, 2009 | Frigidaire Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool dryer
You need to check the dryer INTERIOR to ensure there's no lint accumulations on or around the heating element. The exhaust systems on dryers are not perfect and SOME lint often gets by the lint screen and can start the collect inside the dryer. The lint will begin to smolder and give off an odor if it sits on the heating element housing. Make sure the dryer is unplugged before attempting to access the interior. If the model number you provided is correct, the heating element will be located under the drum on the right-hand side. You will need to lift the dryer top and remove the front panel (with the door) to access the inside and vacuum. Let me know if you need further assistance. I hope this information is helpful to you.
May 08, 2008 | Whirlpool LER5636P Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
520 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
