Question about GE DCSR483EA Electric Dryer
GE dryer i have a GE front load dryer 220v . the timer has malfunctioned and hence the drer is not help me find the part. model no. 572D520P003
  • 159 Answers
If you can get the correct model number of the dryer I can find the part number for you. the number you have in not the model number of the dryer. look in the door or on the back of the consol for it and get back to me. thanks
Posted on Aug 10, 2007
Don't have money to buy new dryer timer ($85-$95). Can I just put a 220v timer between panel and 220 outlet?..
there is an issue with the amperage load on the timer..most dryers require a 40 to 50 amp connection to work properly.. using a timer thats not as heavy rated will catch fire from overheating!!!!!dont want to burn the house down...
Jan 23, 2013 | Dryers
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
Sep 06, 2012 | GE Dryers
Ge front load dryer model # dsxh436a6ww started to vibrate and make load noise. dryer works and it is not of balance.
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 24, 2009 | GE Dryers
Short drying time
probably will have to replace timer motor with one that has a longer run time.
Jul 07, 2009 | Maytag MDG16CS Gas Commercial Dryer
Dryer Shuts off with full load
ok so it runs for the full time set when on timed dry. auto from optimum or less dry runs quickly, correct?
Auto runs on yours by advancing the timer whenever the thermostat is satisfied with the temp coming out. This has a wire that runs from the heater to a resister mounted in the console area then to the timer providing the power to run the timer motor. Most commonly the heater is the cause. GE dryers have 2 elements side by side that operate indepenently but if one goes out the unit will still heat but the circuit for auto is like the heater is off advancing the timer.
the heater is located behind the drum on the wall. first measure the resistance on the resister, i believe 1.4 k ohms see diagram behind it.
to get to heater, remove 2 phillips screws inside door opening top holding top down. then lift top and slide to left if plastic console. to unhook from console. remove 2 screws holding front to cabinet, disconnect wires at bottom left on panel. reach inside on bottom (2 hands may be necessary) pull tensioner arm to right and hook on motor side, it will stay there till pushed. you will get red grease on you. Now you can pull the drum straight out, its a tight fit up front you can remove a side screw to help. you now have an excellent view of the heater. any breaks in either coil?
May 03, 2009 | GE DBXR463EDWW Electric Dryer
Timer / heater malfunction
The heater coils or going bad. It has two wire rings that heat up. One are two has burned out.
Jan 17, 2009 | GE DCSR483EA Electric Dryer
The Drum turns, but no heat, is it ok? Different machine, same problem. I've switched out the timer, thermostat/fuse assembly, and element. Though the feedback for this machine was great when I bought...
check your breaker, sometimes if one side of the 220v breaker trips and not the other then the dryer will run with no heat. if you have a voltage meter then check the outlet itself for a full 220v.
Jun 27, 2008 | Haier XQG50-11 Front Load Washer / Dryer
It could be a malfunction heating element, thermostat or both. In most of the cases it's the heating element. Check with a multi-meter for 115/220V on the heater element tags. In case you get this voltage there, you should replace the heating element. In case you can't read the 115/220V on the heater tags: - Check thermostat's for continuity (you should read a low resistance). In case you can't get any measurement. You should replace the thermostat. Good luck!
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
GE DCSR483EA Electric Dryer Logo
129 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
