Question about Garden
Electric self start problem with my bike
Can anyone help me out for the problem with my bike self start.
it is new unicorn and its self starting mechanism is not working.
  • josh1111 May 11, 2010
    need more info
  • 97 Answers
Check battery and make sure its charged.
check all wiring connections for corrosion and continuity.
Posted on Mar 19, 2009
Bike engine stopped
This problem may have many reason but you can try one of the solutions, when suddenly engine stops and kick rod is going smooth without resistance try push and start by directly in 2nd gear or 1st gear and after it starts keep the engine running by giving small revs for a min....
Apr 11, 2014 | 2005 Honda Unicorn
2011 Honda CB Unicorn Dazzler rebuild starter motor
Hi, Sachin for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.marathonandmore.com/honda-unicorn-bike-service-manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Honda CB Unicorn Dazzler 2011
Honda Unicorn Wikipedia the free encyclopedia
Nov 15, 2013 | 2011 Honda CB Unicorn Dazzler
Brand new honda unicorn making engine sound and vibration
Hi, Anonymous and the usual suspects are:
1. Wheels and or tires worn or damaged.
2. Engine/transmission/vehicle not aligned properly.
3. Primary chain is badly worn or links too tight as a result of insufficient lubrication or misalignment.
4. Engine to transmission mounting bolts loose.
5. Upper engine mounting bracket loose.
6. Ignition timing incorrect due to a poorly tuned engine.
7. Internal engine problem flywheels have shifted.
8. Broken frame.
9. Stabilizer links worn or loose.
10. Rubber mounts loose or worn.
11. Rear fork pivot shaft nuts loose.
12. Front engine mounting bolts loose.
13. Worn out or broken universal joint on shaft drive models.
Common Bike Problems Solutions Mileage Performance Brakes Electric Start
Unicorn noise problem
Service Manual Honda Unicorn
Honda CB UNICORN DAZZLER 2010 Owner Manual
Oct 15, 2013 | Honda Motorcycles
My honda unicorn not start in gear with self start button?
Change the clutch switch its less than Rs. 50....
Aug 28, 2012 | 2005 Honda Unicorn
2011 Honda CB Unicorn stalls while riding in the rain
Hi, Marindra_18 moisture, condensation, rain, or bike washing can make the bike run sluggish, not able to rev, and misfire. Older bikes, engine configuration, and exposed electrical components are at the front of the line for acting up. During the diagnostic procedure spray Electrical Contact Cleaner on corroded wire connectors/pins/sockets etc. and apply a liberal amount of "DIELECTRIC" grease to the mating harness/wire connectors. WD40 works great for eliminating suspect areas in your quest to find the real offending gremlin.
For additional insurance you can spray a High Temp Clear Coat on the most vulnerable areas it will work like Scotch Guard does on fabric. Fabricate a rubber or plastic splash guard to deflect water coming off the front wheel getting to the front cylinder spark plugs. The design should be adequate for its purpose with the least amount of airflow restriction to cool the cylinders. The usual suspects are:
1. Air filter soaked with water.
2. Water in the fuel system gas tank and carburetors.
3. Wet ignition coil packs.
4. Spark plug boots wore out or loose allowing water to enter.
5. Spark plug cables old and cracked check for spark leakage in the dark.
6. Spark plug wells filled up and drain holes clogged.
7. Water in a wire harness that has exposed open ends and have a sharp bend or crimp allowing the liquid to form its own pool of potential threats to chaffed wiring.
8. Sensitive fuel tuners and downloaded ECM remaps may get confused with the abnormal cylinder temperature difference in a V-4 engine configuration.
If your bike will not run right or even start after going through the checklist, despair not, letting it sit for a couple of days in a warm environment is like an eviction notice for the Gremlins and then your bike will be back to its old self.
Rain stalling my bike
Bike Stops in Heavy Rains
HONDA UNICORN CBF 150 BIKE WORKSHOP SERVICE REPAIR MANUAL Download Manuals... $15
https://www.partsfish.com/page/oem-parts-for-honda
Jun 17, 2012 | 2011 Honda CB Unicorn
I have just recently bought Second hand model of Honda Unicorn Bike without self start.Then the problem I faced it with yesterday is that ,suddenly the kick rod completely got loose and there was no...
Hi, Akommidi you need to take your bike to a Professional Honda Technician and have it "PROPERLY" repaired I would call my local dealer or highly reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Apr 26, 2017 | 2005 Honda Unicorn
Spark plug cap
Well there is no problem continuing using the bajaj spark plug cap,this can probably happen due to hot from the engine,and the cap DISINTEGRATION.I advice you to use the bajaj cap see how long it last compare to your original unicorn cap.
Mar 03, 2010 | 2005 Honda Unicorn
I have honda unicorn-2005 model. Sometimes kick become free and i am unable to start it. Then i have drive the bike manually in first gear and start it by releasing clutch at substantial speed
first check about the clutch plate, if it is down or not? if it is good then check for the valve of the engine. it need replacement.
Jul 12, 2009 | 2005 Honda Unicorn
Engine knocking problem of Honda Unicorn 2005 make
I too have a similar problem. I couldnt find any solution. If you have found it please let me know.
Mar 28, 2009 | 2005 Honda Unicorn
Garden Logo
559 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
