Question about Craftsman Air Tools & Compressors
Craftsman Compressor 919.158210 oil capacity
Bought used, no owner manual. Need to know oil capacity on unit?
hdpanama
  • 65 Answers
SOURCE: owners manual ruined. what type of oil do i fill w before use
you should be able to find the manual online if it's available if not Sears would I'm sure be able to tell you.
Posted on Dec 20, 2008
SOURCE: Owner's manual for Ionic Breeze GP
does anyone have (I hope) a free manual for an ionic breeze quadra? I have had this fo awhile but lost the manual
Posted on Jan 21, 2009
SOURCE: compressor will not build pressure
Posted on Feb 28, 2009
  • 89 Answers
SOURCE: My craftsman 3 gal. air compressor, 921.153101 won't compress air
I WOULD TRY DISCONNECTING THE PIPING FROM THE HEAD DOWN TO THE TANK AND SEE IF ITS BLOWING AIR. COULD THE COMPRESSOR BE RUNNING BACKWARDS - YOU WOULD HAVE HAD TO CHANGE THE WIRING IN THE MOTOR.
VALVES IN THE HEAD COULD ALSO BE BROKEN. YOU CAN REMOVE THE INTAKE AND IT SHOULD **** YOUR FINGERS AT THE OPENING. HOPE THIS HELPS.
Posted on Mar 14, 2009
Schmead10
  • 650 Answers
SOURCE: Need Owners manual for older Craftsman Radial Arm
Here is a site to have the manual Emailed to you
http://www.sawmanuals.com/ Hope this works for you.....Please rate.......
Posted on Apr 14, 2009
17ARCACK099 manual
here is link for owners manual
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0709180.pdf
oil capacity is in the engine manual. Get model # off of the engine tag and look that up for your engine oil capacity.
Jul 11, 2014 | Craftsman Garden
What type fork oil is used in 1986 yamaha maxim 700 and how much in each fork
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Fork oil capacity
85 XJ700 Fork Seal Replacement Tips and Tricks
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Jul 03, 2012 | 1986 Yamaha XJ 700 X Maxim
I need a manual for the Craftsman Walk behind mower #917.388930. The main thing I need to know is when changing oil what is the capacity? SAE 30 non detergent I assume. Thank you.
No, you do not use non detergent oil. You must use only SAE high quality detergent oil with API service classification SG-SL . Use SAE 30 weight or 5W30 if you use the mower during cool conditions below freezing. I highly recommend you use Synthetic oil in this air cooled engine and change your oil once each year. The oil capacity is 20 ounces. You can see the owner's manual at this link. Just click Manual Location and put in the captcha and click submit. No need to sign in or register. http://www.hammerwall.com/Manuals/Craftsman/Description/917.388930/Craftsman%20Walk%20Behind%20Lawn%20Mower%206%20HP%2021%20Inch%20Rear%20Discharge/L0605486/
Jun 27, 2011 | Craftsman Garden
I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
Aug 16, 2010 | Craftsman Air Tools & Compressors
Oil type & owners manual
here is the oil you need. Manual is NLA. Eric http://www.kmart.com/shc/s/ProductDisplay?sid=KAx20061023x272xTier3&aff=Y&vName=Tools&CustomerMemberID=tfc_-_9_1_090811_cbdc17f8236de8319108ad3e858ffcf6&catalogId=10104&sName=Air%20Compressor%20Accessories&AirTools=&cName=AirCompressors&partNumber=9990000031945111P&storeId=10151
Aug 02, 2009 | Craftsman Air Tools & Compressors
Oil capacity for craftsman air compressor circa 1978 model #106..
I have a 2hp craftsman air compessor with a two cylinder pump, Here is the info from my manual as far as oil capacitity:
Remove oil fill plug and slowly add
a compressor oil until it is even with the
top of the oil fill hole. NOTE: Do not
allow oil to be lower than 3/8"
from the top at any time. When filling
the crankcase, the oil flows very slowly
into the pump. If the oil is added too
quickly, it will overflow and appear to
be full. NOTE: Crankcase oil capacity is
approximately 16 fluid ounces.
I buy my compessor oil from Lowes in the tool department. It comes in 16oz and sells for about $3. I wouldnt worry about how many ounces it holds but rather that the oil level is to top of filler hole. Lowes also sells a synthetic oil for about $7 and is recommended for severe conditions (hot / cold / used all day). Good Luck!
Apr 25, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Mar 28, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
No owners manual
CONTACT A SEARS SERVICE CENTER NEAR YOU OR CALL THEYRE HELPLINE. THERE SHOULD BE SIGHTGLASS OR CROSSHATCHES ON THE DIPSTICK. HALFWAY THE SIGHTGLASS WHEN SHUTOFF IS MINIMUM - I LIKE 3/4. HOPE THIS HELPS
Mar 13, 2009 | Craftsman Air Tools & Compressors
Owners manual ruined. what type of oil do i fill w before use
Dec 19, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air Tools & Compressors Logo
150 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
