Question about Vacuums
I need a owen manuals for a nikken clean hepa system nkap100
Air clean hepa system
2 Suggested Answers
SOURCE: Nikken Air Purifier, Model NKAP100:
Under the front panel, under and to the right of the control panel is two holes, one the size of a pencil eraser and below it is one the size of a dime. In the hole (the size of a dime), is a pin hole use a paperclip and poke the hole. It will reset the filter light. We had the same problem, and couldn't find the manual. Our Nikken rep was No help either.
Posted on Jul 20, 2011
Vacuum hepa gets hot
Carol,
Have you checked to make sure that all of the filters have been cleaned so that you have good air flow? The HEPA filter is your final exhaust filter and if your motor is getting hot because of poor air flow, it will cause the HEPA filter to get hot as well. Hope this helps!
Aug 02, 2015 | Fantom Vacums Vacuums
How do I clean duracraft hepa 200 DA5020 unit
Hepa's aren't designed to be cleaned and reused. If you get one wet the fibers will not return to their original state and then the ability to filter the air is compromised.
Dec 31, 2014 | Vacuums
I need to clean the post HEPA filter on the bottom of my Dyson DC 18. How do I go about doing that?
If it is one that can be washed instructions will be in owner manual or even on the outside of the ring that holds it in place, did that recently for a friend and if air is blocked there low or no suction and in some cases unit will shut off and seem to have total loss of power, motor overheats and thermal relay or breaker trips.
The unit had marked it could be washed in soap and water in the sink, look for instructions as if not meant to be washed it could be ruined.
Dec 11, 2012 | Dyson Slim DC18 All Floors HEPA Bagless...
Nikken Air Purifier, Model NKAP100: Change Filter red indicator stays lit after new filter has been installed
Apr 20, 2011 | Vacuums
The bottom filter under the canister keeps popping out everytime I vacuum. This is really annoying. The bottom looks sort of dirty but I'm not sure how to clean it.The top looks very clean. I know I need...
This is a pretty clear indication that your filter is clogged and needs to be replaced. HEPA filters are different then say pre-motor filters, or sponge filters. Because they are usually the last filter before the air is exhausted, it's usually catching very tiny microscopic particles. Because of this, trying to determine if the filter is dirty or clogged can be difficult, if not impossible on HEPA pleated exhaust filters.
The fact that your filters continues popping out, indicates that the air is not being able to pass through the filter as it's supposed to, and is instead the air is having to try and find a different way to escape, causing the force of the back up of air to blow the filter out.
I think if you replace this filter, it should fix the problem completely. Because this filter is designed to capture microscopic particles rather then large particles, washing this filter, or getting it wet is not advised, and wouldn't be an effective way to clean it. You really will need to replace the filter soon, but if you'd like to try and prolong the life of your filter, you may use an air compressor, and blow from the top of the filter (the area that looks clean), and clear the microscopic particles, and dust out of the filter this way. If you suffer from breathing issues, asthma, or allergies, I would highly advise against doing this without a mask on. The dust that will come out is extremely fine dust that can cause people with the above conditions to suffer greatly. Doing this outdoors is highly recommended.
An air compressor can certainly prolong the life of HEPA filters, but again, sooner or later you'll need to replace the filter.
If you're in need of buying one of these filters, you're in luck! We carry these filtes on our site, and they are in stock. Here's a link back to the filter on our site if you need to order one. We offer free shipping, 60 day returns, free return shipping, and no restocking fees. Please feel free to reply to this solution by using the comment box at the end of this solution. If you found my solution to be helpful, please be so kind and rate my repair, or leave feedback for me. This is greatly appreciated by the FixYa community, and is really what keeps repair professionals like myself to keep answering free questions, and not just the premium questions which we get paid to answer.
http://www.govacuum.com/10662-Hoover-303172002-Windtunnel-T-Series-Replacement-HEPA-Filter-Cartridge.aspx
Thanks so much,
Chris Jones
GoVacuum.com
Jan 07, 2011 | Hoover UH70120 WindTunnel TSeries Rewind...
What filters do i need for the eureka the boss bagless vacuum w/widetrack modal 4495
There is a Cassette Micron Filter 60696.If you have a HEPA cartridge filter you need EUREKA's HEPA part 61500.In earlier models there is a micron filter instead of a HEPA filter--for that you need EUREKA's Micron part 60801. But if you have that HEPA filter, the manual says you have to use the HEPA filter to achieve the closed HEPA filtration system again.
Dec 10, 2010 | Eureka 4495A Bagless Upright Vacuum
Can not get filters
While you are looking for a new filter, you could do this(as written in the instruction manual):
1. Hold the HEPA filter
by the edges and vigorously
"TapClean" the HEPA Filter
dirty side down on a hard,
flat surface until no more
dust is observed falling out
from between the pleats of
the filter.
2.
We recommend washing the HEPA filter
once a month or when suction
appears to be reduced. Let the HEPA
filter air dry completely for 24 hours.
3. Rinse the non-woven pre-filter and let
it air dry completely for 24 hours.
4. Insert the non-woven pre-filter.
5. Reinstall the HEPA filter in the
vacuum.
Have a good day.
GB
Nov 06, 2010 | Euro-Pro EP602 Bagless Stick Cyclonic...
Filter cleaning
use an air gun from a air compressor, that is what i use with mine-Lance
Oct 20, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Cleaning filter on the Dyson Slim
You don't have to clean the HEPA filter (underneath the canister in that clear part) - if you break that clear part you will cause damage to the machine and it won't **** anymore as the air will escape. There is no need to remove it or replace it, it is a lifetime filter. You only have to clean the blue filter that is inside the top of the canister/dirt bin.
Mar 24, 2009 | Dyson Slim DC18 All Floors HEPA Bagless...
Want to replace HEPA post filter
http://www.dyson.com/customercare/manuals/us/dc07_manual_us2007.pdf
here is the link to your owners manual. scroll down to page 6 it shows you the filter to clean and how to take it aprt.
Jan 08, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
224 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
