Question about Bernina Activa 140
General up-keep and maintenance for activia 140?
We are a small but energetic art college and in the course of the year our sewing machines take a bit of a bashing. Can you provide basic maintenance instructions for the activia 140?
    Problem Solver:
  • 11 Answers
Clean, clean, clean the bobbin race area, oil the designated oiling spots (if there are any), and change the needle for each new project (or 6 hours of sewing). I'm not a Bernina user but have sold another swiss brand and in our training the need to clean and CHANGE THE NEEDLE was stressed heavily. Many users will leave the needle in place until it breaks, sewing through thick and thin, knits and wovens. And there is always going to be lint building up in the bobbin race area which will eventually "felt" up into a wad if left. Simple cleaning is lifting the needle plate, (or opening the front flap if front loading), removing the bobbin case, and brushing around the whole area carefully with a small soft bristled brush. Then oiling (with quality light machine oil), running gently for a few seconds unthreaded, then reassembling. Also wipe down the exterior of the machine with a damp cloth and clean between the tension disks by sliding a single layer of fabric into them.
Posted on Oct 07, 2009
Does the 6235 need oiling
Oh YA! Indeed they all should have a 'tuneup' now and then.
What do they check??
GO to GOOGLE and search for: sewing machine service checklist
Next go to "IMAGES" and see MANY checklists of items to accomplish during a service!
Here is ONE example of a nice checklist!
http://www.amefird.com/wp-content/uploads/2010/01/Sewing-Mantenance-Check-List-2-5-10.pdf
and there is this great list too!
Learn Preventative Sewing Machine Maintenance
And ONE more:
Basic Sewing Machine Maintenance Tips From an Expert
Anthony
Jan 30, 2018 | Sewing Machines
Thread getting caught below and locks up machine.
Tale the metal case out that holds the bottom reel, there should be a tension adjustment screw, use a small screwdriver or thin knife, turn it anticlockwise, should loosen the thread, this should sort it. Clean out all the bits of thread of course.
Dec 24, 2014 | Sewing Machines
Do not know how to replace spool pin and spool cap
It looks like it might just snap into place. Of course that means you have to remove the broken bits which may require a drill, small bit and needle nose pliers.
Sep 10, 2012 | Brother XR-65t Mechanical Sewing Machine
Hello! I'm a beginner at sewing and recently inherited an Elnita 130 sewing machine. Does anyone know how I can find a manual for this? I have searched a number of websites selling sewing machine...
You can check this out. Doesn't list your model, but it is most likely similar to the 120 and 140. Usually, the only difference between one model and the next is one will have a few for stitches or added functions. The basic operation is probably the same:
Elna 110 120 140 Instruction Manual
Elna Sewing Machine Manuals Instruction and Repair Manuals
May 25, 2017 | Elna Sewing Machines
How do you thread an Elnita 140 sewing machine that is really old but can still work?
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
Apr 02, 2010 | White Sewing 1888 Mechanical Sewing...
Oiling a pacesetter
No oiling by the user.
Computerized machines are lubricated and sealed in the factory.
If you are the original owner, you could invalidate your warranty if you go beyond the maintenance routine described in the manual.
To keep the warranty, your machine is to be serviced by an authorized Brother tech on a regular basis - once a year if it gets heavy use.
General maintenance, per the manual, will keep the machine in good working condition.
Mar 31, 2010 | Brother PC-6000 Pacesetter
How do i oil my bernina 801?
Please do not oil anything with WD40, it is an alcohol based cleaner hense why it's flammable. No where on the container will it say anything about lubricating, it will merely dry out your machine. We use it, but only to clean metal parts... we then clean it off and let it evaporate for a day before applying oil.
There are two key points I suggest customers can do themselves to help lengthen the life of their machine. One is your hook and the other is the needle bar...
Hook - Open your bobbin door, removee the bobbin case/bobbin. On the upper left corner there is a small latch, push in the latch and your shuttle race ring will fall down forward. You can now remove your stainless steel hook. You need to keep this hook clean and the lip it fits back into clean and void of lint and debris. On the back of this hook or the "lip" that the hook fits back into apply a small amount of hook/sewing machine oil.
Needle Bar - Open up your head cover, the needle and needle bar clamp is attached to a long stainless steel rod that travels vertically inside your head. All sewing machines have a needle bar that looks like this. This bar travels thru two brackets attached to the frame of the machine. Rotate your handwheel and clean the needle bar well of debris. Rotate the handwheel so that the needlebar is in it's highest point and apply a small amount of oil to the upper and lower bracket of the frame, rotate the handwheel so the needlebar slides back down and therefore lubricating it and the inside of the brackets.
Hook oil or sewing machine oil is relatively inexpensive from all quilt, sewing machine, repair shops. Be sure to take your machine in a minimum of every three years for proper cleaning and lubricating of all the other parts (This is of course for average home sewing machine use 8hours a week)
Dec 02, 2008 | Bernina Artista 180
Problem After Oiling
More than likely the machine is okay but when you do the embroidery the presser foot is not all the way down and it has no tension. The other possibility is that the thread is not in the take up lever all the way or is slipping out.
sewman7
May 19, 2008 | Brother LS-2125 Mechanical Sewing Machine
New Home sewing machine instruction manual 2039 (Jenome)
I will quit being lazy and find my manuel today...... i thought I could save time and look online. No such luck. If you have an email address I will send of fax or mail to you. I feel bad for everyone looking for it. So I will check in a few days to see if you still need it.
Lisa
Sep 30, 2007 | Janome Harmony 2039 Mechanical Sewing...
Sewing Machines Logo
248 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
