Question about Perfect Fitness Perfect.situp Sit-up Machine
I put the back blade in on wrong side and now cannot get it out to reinsert, how can I get it out?
When i turned it over the label was on that side, and now the neck support will only go on backwards
I replaed the blade drive mandrel and reattacheed the blade and the blade does not freelyturn t is so bound up tht I cannot turnit manually
okay check see if brakes is on the mower, not the tractor but the blades of the mower deck if not then take belt off of the new mandrel side and try turning blade by hand. should turn freely if not mandrel is bad but unlikely. sounds like you changed wrong side mandrel I presume you have 2 blades and mandrels. or when you installed it back on. the belt may be bound up between a guide and pulley just kind of look things over before a tear apart. and then do your tear apart one step at a time then check blade to see if it turns does not seem serious you may have put belt on wrong, I have done it my self. hope this helps major note do not do this with engine running cut you hand off in a flash.
Aug 13, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Printing avery labels
Black ink printing on the reverse? On the wrong side of the page? I hate to ask, but is it possible that the labels just need to be turned the opposite way when you put them in the printer?
Mar 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
Changing blade drive assembly on agc2 model two problems may have put blade drive assembly on backwards. on the blade release assembly on the other side the three pieces came apart trying to...
Ok the silver metal plate goes on first then the black latch will connect to the hinge, there are two small holes either side of the latch where two spring ends poke through then simply screw it back on, not sure if you can put the blade drive on the wrong way.
If your still having trouble give us a call and we can talk you through it www.angliaclipperservices.com
Jul 21, 2011 | Andis AGC2 Hair Trimmer
I have a used Cub Cadet Model #144-664-100 that I purchased last year and used half of the summer and ran great but towards the end it wasn't cutting very cleanly. So I took off a mower blade, which was...
Have you tried running it with the blade back on? It may be ok as there is a braking system built into the pto clutch that makes the blades hard to turn by hand. Regards Phil
Apr 15, 2011 | Cub Cadet Lawn Mower Deck Drive Belt...
2000 BUICK REGAL MY WIPER BLADES (DRIVER SIDE) WENT OFF THE WINDSHIELD THE OTHER NIGHT. WHEN I PUT IT BACK IT DID NOT WORK PROPERTY WHAT COULD BE WRONG DO I NEED TO TAKE IT TO A DEALER?
i`m not sure what you mean by it not working properly i assume that you mean it goes back and forth like the passenger side, but it doesn`t clean the window and you put the blade on the arm correctly then the wiper may be damaged and you will have to replace the wiper blade.check and compare the installation of the driver`s side to the passenger side wiper and correct the installation of the blade
Mar 08, 2011 | 1999 Buick Century
I put a new blade on and when I turn it on it vibrates. Why?
Most likely there is some dirt or a label between the blade and the shoulder on the arbor preventing the blade from being perpendicular to the shaft. Or maybe there is a label on the blade causing it to be out of balance. Or maybe the hole in the center of the blade is larger than the arbor, so it does not center itself (it should be a nice slip-fit.)
Apr 30, 2010 | Craftsman Saws
I have a Ford F250 XL- While plowing today I notice that the truck was swaying to the left but didn't think anything of it, thought it was the wet snow. Then while back blading some snow, I noticed that...
check both front lockouts,1 side or the other could have broken,unlock 1 side and reach underneath and try turning the axel on the other side-----if it turns all the way around, then replace that lockout,if it doesnt turrn then try unlocking that side and lock in the other side and see if you can turn it,if so then replace that lockout.if not then something might be wrong with the transfercase to the way it engages
Jan 19, 2010 | 1998 Ford F250 SuperCab
I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Dec 29, 2008 | Intermec EasyCoder 3400 Thermal Label...
Put on mower blade for black and decker lawwn mower
Hi, unplug the spark plug wire.turn the mower on its side, in the middle of the blade there is a bolt. Unscrew the bolt on blade to take it off, and to put it back on, put blade on first and bolt it back together.
If this doesn’t work for you, please write back.
Thanks
Sep 22, 2008 | Black & Decker 19" Electric Lawnhog...
Inserted cassete in wrong way in Sony camcorder CCDTRV68, not ejecting cassette Error codeC32:20
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Dec 24, 2007 | Sony Handycam CCD-TRV68 Camcorder
Perfect Fitness Perfect.situp Sit-up Machine Logo
Top Perfect Fitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Perfect Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
