Question about Ctm Health & Beauty
Scooter battery charger hp8204b problem. Yellow light does not come on, onlythe red one. Also at the opposite end there's a switch 0 or I. Whick position is correct?
Pretty much said everything in the question, thanks.
  • 118 Answers
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
Posted on Nov 27, 2008
my-mobility
  • 9 Answers
SOURCE: have a harsh jerking movement while using
This is a common problem often caused by the potentiometer(pot) in the centre of the Wigwag (Accelerator.) This part takes a lot of “abuse” and the pot causes an intermittent electrical connection resulting in a very jerky ride. Try spraying a contact cleaner spray in the pot but most often the potentiometer will need to be replaced by a technician. Regards Chris…
Posted on Jun 22, 2009
gewiz
  • 1263 Answers
SOURCE: Scooter batteries will not charge. Green light on
ok, this could be a dodgy connection with the batteries or the charger is at fault ?
1. try another charger
2. check the batteries if possible on another scooter.
3. check the connection on the battery and the charge socket connector.
Regards
GeWiz.
Posted on Oct 01, 2009
  • 23 Answers
SOURCE: electric mobility scooter says charge is full but won't run
This sounds she has tripped her circuit breaker. It works just like the one on your house, when you ask too much of it it suddenly goes 'pop' and seems to be dead.
Looks like you have the same scooter as mine, it should be a little white button on the back of the base. If you follow this link, it will give you a pdf version of the older model pride victory manual, (Mine is a three, they are up to about 10!) See fig. 8 on page 20 and 'Circuit Breaker' on page 21. Also, Page 33 has the troubleshooting info. Hope this helps.
http://www.rentascooter.com/downloads/_manuals/pridemobility/Pride%20Victory%20Owner's%20Manual.pdf
Posted on May 06, 2010
SOURCE: Mobil Line Battery Charger for Stairlift not working
check the sensor at the top of the track and make sure it is not loose.Just had this problem,can be fixed with a screwdriver for free.
Posted on Mar 28, 2011
Hp8204b charger staying on yellow even after overnight charge, why?
Hi that is strange yellow led is charging mode ...if possible try another charger it could b faulty or there might b a fault with the little computer (control box) the charging circuit is connected to control box .....if the batteries r faulty this might b the problem test batteries with a load tester U can buy them of E/BAY APROX cost $39 this will give U an accurate reading on the condition of the batteries. .,good luck
Oct 15, 2016 | Health & Beauty
Tip
Charging your power chair or scooter the correct way can make them last
Whenever you need to charge your power chair or scooter get into the habit of charging overnight. The battery level indicator lights will tell you if your chair or scooter needs charging. Whenever the lights are down into the yellow and especially if they are in the red. If you have the off-board charger, plug the charger into the charger port in the front of your joystick and then plug the charger into the wall socket or turn the on/off switch on and let it charge overnight. When you get up in the morning the charger should have a red light(power) and a green light illuminated (indicating fully charged) Always turn the charger off or unplug it from the wall socket before you unplug it from the chair or scooter. Never have the power on to the charger when you plug or unplug it from your chair or scooter. Whenever you get new batteries always give your batteries a full charge before use and then if you use the chair daily charge it every night. If you do not use your chair or scooter daily charge it at least once a week. Never leave the charger plugged in and on for more than 24 hours. Your batteries should last you 3-4 years if you charge them correctly.
on Sep 20, 2010 | Health & Beauty
My HP8204B Pride Battery Charger stopped charging. When I plug it on the red indicator light is on but charging light does not show activity and does not charge. The batterie is fine and in good...
Hello Anonymous,visit the Manufacturer.Who better to ask advice than from the Makers,they will have some link via (Contact Us),Maybe click on (Search Site) & email them.I hope this helped,Colin
Jul 25, 2014 | Pride Health & Beauty
Mixer is not connecting to pc
usb driver chip is bad, must of hot patched it to many times...
Apr 08, 2014 | Behringer Xenyx Q1202 USB Mixer
Tune up
sparkplugs, air filter change and oil change.
pretty simple, took me about an hour to do everything.
Mar 21, 2014 | 1989 Toyota Camry
Charger not working fan not stay on and yellow light
You have the 4-amp charger version. If you have the U1 batteries on your Pride you can replace the charger with a 3-amp version after you have your batteries load tested and tested for internal resistance. Verify batteries are good and "finishing voltage" after charging is proper. (14.4volts per battery)
Nov 09, 2013 | Pride Health & Beauty
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
Health & Beauty Logo
471 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Dan Apthorp
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
