Question about KitchenAid Kitchen Ranges
Kgrs 807 thermal fuse replacement
Oven door will not open
4 Suggested Answers
SOURCE: Oven door locked
Funny, I had the same problem. turned out the interlock switch was failed. Its a real pain to short the switch ,so you can open the door to replace it .
Posted on Mar 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: How do I replace the oven temperature
Unplug the range.
Open the oven and look on the top left back wall of the oven to see the sensor protruding out. Unscrew the 2 screws holding the sensor and CAREFULLY pull it out.
Unplug the wire connector. Plug in the new sensor and CAREFULLY push the wires back inside.
Replace the screws.
Turn on the oven and bake me some cookies.
Posted on Apr 01, 2009
SOURCE: I have an RS696 series Oven that needs a thermal fuse
You model number doesn't have a fuse. You'll need a whole new board to fix it.
www.oc-repair.com
Posted on Feb 09, 2010
Whirlpool self cleaning oven Model RBD245 door will not open after self cleaning cycle
Whirlpools are notorious for tripping the thermal fuse on the back of the oven but there is a thermal fuse to the control board also on most electronic control models. It is a good chance you will need to replace both fuses.
Oct 04, 2014 | Ovens
Oven door won't open after cleaning
The oven shut down before self cleaning completed without a model # this is what I can tell you the TOD thermal overload fuse opened cannot be reset if you have no display then the thermal cavity fuse opened buy a set of feeler gauges from the auto store take one go to top of door in the middle between between door and body push to left door should open.
Sep 24, 2014 | Whirlpool Ovens
Replaced 20A fuse - now have blinking lights
either the cutoff is open circuit or closed circuit if you get any reading at all it is good. I would look at the control panel look for overheating components. Tap any relays to release them if they arced inside. Whenever a microwave blows a fuse it is time to replace the huge capacitor at the back and possibly the magnetron. I resurrected my Sharp R9H66 Microwave Convection Oven easily. Had to replace the magnetron twice in the last 5 years
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
My KitchenAid Architect Series II Electric Range after I ran the self clean option the oven door will not open and the display does not light up, the top burners work just fine, tried ressetting the b
Hello Gene,
On the back of the oven is a thermal fuse that probably went outduring the sefl clean cycle,ya would need to pull the oven out and remove the back panel to test it, That thermal fuse is not resettable and must be replaced,it probably looks something like this 11_15_2011_7_41_32_pm.jpg
GENE
Nov 15, 2011 | Kitchen Ranges
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
After self cleaning the display is blank and door is locked
Which thermal fuse did you replace?
There are 3.
This manual will help you diagnose the oven.
Thermal fuses are explained on page 3-2.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/7d69e72584ddde3385256a7e00524e76/$FILE/8178007.pdf
Jul 11, 2010 | Whirlpool RBD305PDS Electric Double Oven
Model KEDT105V F-2 and F-3 flashing and beeping then turn the oven off? MOlson
Hi
The error code F-2 means that oven temp is too high; you need to :
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Error F-3 means you need to open oven temperature sensor/thermal fuse and replace oven temperature sensor/thermal fuse.
Please revert for any further assistance and Do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 25, 2009 | KitchenAid KESC307 Electric Kitchen Range
No power and door locked after starting self cleaning cycle
Thermal fuse went out by door latch and thermal fuse on back of oven probably tripped too; once failed they need to be replaced. This is probably a job for the repairman as something caused fuse to go out in the first place; unless resolved it will recur. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | KitchenAid Architect® Series II KEBS208S...
I keep getting an f3 code n my wall oven what does that mean ? and can it be repaied easily?
Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fusef3 falure code means oven temperature sensor or thermal fuse you have to check the oven temperature or the thermal fuse for possible replacement.hope this helps pls dont forget to rate as fixyaa .thanks and Godbless
Nov 23, 2008 | Whirlpool Kitchen Ranges
Oven door locked
did you interrupt the cycle if you did hit cancel but if you were running self clean the door wont unlock till the oven senses its safe to open can take 30_40 min im online now so you can reply and will help
Dec 31, 2007 | Frigidaire PLCS389DC Dual Fuel (Electric...
Open Questions:
Kitchen Ranges Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
